Tally-I/O
Author Topic: split blade edger blades  (Read 2452 times)
Offline Jason_WI
  • He who dies with the most toys wins.
« on: March 17, 2004, 02:57:26 PM »
Anyone know of a source of split blade edger blades that are 10" , 20 tooth carbide square chisel with a 2.5" arbor dia and a 2 5/8, 4 bolt spacing bolt pattern.
Norwood wants 100 bux a piece for these.... Seems kinda high since all they did was cut them in half with a band saw - cut line not so straight :D
Jason
Norwood LM2000, 20HP Honda, 3 bed extentions. Norwood Edgemate edger. Gehl 4835SXT
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
Re: split blade edger blades
« Reply #1 on: March 17, 2004, 03:15:43 PM »
  And you can't do the same, because ??? ??? ??? :D :D
Offline FeltzE
  • Fayetteville NC, Stop by and visit some time!
    • Feltz's Sawmill
« Reply #2 on: March 17, 2004, 03:59:30 PM »
Jason it sounds like what I have on my Baker Edger, Give them a call I think they quoted me 70 something or so per blade. I need to send my blades out to be retipped.
Eric
Offline Jason_WI
« Reply #3 on: March 29, 2004, 06:29:18 PM »
After calling a few places and getting price quotes it seems like 100 bux each is the going rate.
One place I called wants 22 bux to bore the 2.5" dia arbor hole plus 6 bux for each mounting hole. On top of that they want 50 bux a blade.
Time to fire up the 14"x40" Rockwell lathe and make me some edger blades.
I found that Freud has industrial rip blades that are 10", 18 tooth with a 3/16" kerf for 38 bux from Amazon. I will give these a try and post results.
http://www.amazon.com/exec/obidos/tg/detail/-/B00004T7PY/103-1422750-2006227?%5Fencoding=UTF8&coliid=I1VUIU5D3SCQSH&colid=QDQ15JPQIJAL
Jason
Offline Bibbyman
    • Warden Sawmill
« Reply #4 on: March 30, 2004, 08:55:36 AM »
Might try Lonny at Morgan Machine
318-994-2725
I just bought a new set of 12" split carbide blades for $75./set Don't know if the rest of the specs are what you need.  Just have to ask.
Sawing since '94
Split blades for WM EG200 Edger
Started by customsawyer on Sawmills and Milling
Last post September 17, 2019, 04:37:54 PM
by scsmith42
New Blade Design for Baker Twin Blade Edger
Started by YellowHammer on Sawmills and Milling
Last post April 28, 2019, 07:02:21 AM
by customsawyer
Edger Blades
Started by wetdog on Sawmills and Milling
Last post November 04, 2012, 08:55:10 AM
by richard lane
Edger Blades
Started by Kevin_H. on Sawmills and Milling
Last post December 30, 2005, 08:50:34 PM
by Ron Wenrich
