Author Topic: Bulk Saw Chain  (Read 3521 times)
Offline wiam
Bulk Saw Chain
« on: March 18, 2004, 11:21:07 AM »
Where is the best place to buy reels of chain.  What is your choice of brand?
William
Offline oldsaw-addict
Re: Bulk Saw Chain
« Reply #1 on: March 18, 2004, 01:26:50 PM »
The best place is the one that has what you want when you want it for a good price, My preference of chain is Windsor 50A chisel chain. I have a round ground SANDVIK 50A chisel chain here somewhere.
Let there be saws for all mankind!
Offline jokers
  • Chainsaw Freak
Re: Bulk Saw Chain
« Reply #2 on: March 18, 2004, 04:28:09 PM »
Jeff Sikkema at http://www.snssawshop.com cuts a good deal on bulk chain or you can try Commercial Cutters Direct at http://www.commercialcutters.com.
Oregon chain has always worked well for me but Windsor(another Blount/Oregon brand) and Carlton are respectable brands also. Stihl chain is a little harder but it doesn`t justify the huge price in my mind. Sabre chain, if you can find it is excellent.
Russ
Offline Rocky_J
Re: Bulk Saw Chain
« Reply #3 on: March 18, 2004, 05:18:38 PM »
I've never done rolls of chain, I don't use enough to make it viable. I did, however, just get a box of 18 loops of chain from Jeff Sikkema. For a couple different saws, and this should last me through the summer I hope. I've been getting a .325 chisel chain from him that is equal in hardness to Stihl RS in my opinion, and for half of what my local Stihl dealer charges. I'm not sure but it might be Carlton, ask Jeff. I don't care what name is on it, I trust Jeff to send me good stuff and he hasn't let me down yet.
I have rarely been happy with Oregon chains, too soft. :-/
Offline Kevin
Re: Bulk Saw Chain
« Reply #4 on: March 18, 2004, 05:41:27 PM »
I'd like to see a hardness test done on the different brands of chain.
That would be a good one for Sawmill & Woodlot.
Re: Bulk Saw Chain
« Reply #5 on: March 18, 2004, 07:43:18 PM »
Maybe I should start buying more carlton brand chains for my saws, the oregon chains are just too dang soft for me.I've had a chain or two that wouldnt even stay sharp for a whole cut through 6" dia. saplings, the chain was an oregon go figure. The carlton chains stay sharp better than oregon chains in the warm weather of florida better than Oregon chain does, I think the oregons were made for colder weather operation because of their softness. I never really though about the hardness of the metal before but there is a difference now that yo uguys  brought it up.
Offline Oregon_Rob
  • NW Oregon
    • Not open yet, but soon I hope
Re: Bulk Saw Chain
« Reply #6 on: March 18, 2004, 07:56:13 PM »
Kevin,
I have been thinking the same thing. We have a hardness tester at work, i will have to see if it could be set up to do saw tooth. If it can, i would be willing to run some samples, if i could get some help locating different brands.
Of course, i would need full loops of 3/8 .050 with 72 driver :D
I will check into it next week.
Chainsaw Nerd
Offline Rocky_J
Re: Bulk Saw Chain
« Reply #7 on: March 18, 2004, 08:01:38 PM »
Rob,
PM me or email me with your mailing address if you are serious about this, I would be willing to invest twenty dollars for an unbiased comparison. I could be talked into supplying a Stihl RS chain (which will most likely be your baseline for grading all the others).
Offline Brian_Rhoad
Re: Bulk Saw Chain
« Reply #8 on: March 18, 2004, 08:43:17 PM »
I get 100' rolls from Bailey's. www.baileys-online.com
Their Woodsman Pro chain is as good as any other brand out there. 100' is about $200-$220 depending on what size you need.
Offline Hunter
  • Dolmar/ Efco/Redmax/ Silvey Grinder Sales
Re: Bulk Saw Chain
« Reply #9 on: March 19, 2004, 11:07:52 AM »
I buy all my chain here where I work. If you are looking for 100ft rolls, let me know what kind you wnat and I will check price for you and I will also check to see whats on special.
Hunter
Jmccomas@insight.rr.com
614-554-2169
Dolmar / Efco / Redmax / Silvey Grinders Sales
Offline jokers
  • Chainsaw Freak
Re: Bulk Saw Chain
« Reply #10 on: March 19, 2004, 01:12:09 PM »
Woodsman Pro is Carlton isn`t it?
Any chain that dulls when making a 6" cut in clean would has either been damaged or improperly sharpened. Even when Oregon was selling Cord Cutter chain with no chrome it would not dull anywhere near that quickly. I don`t mean to offend with that statement but if you find yourself in this scenario, you need to ask yourself why.
Russ
Offline jokers
  • Chainsaw Freak
Re: Bulk Saw Chain
« Reply #11 on: March 19, 2004, 01:20:18 PM »
Oh BTW, it`s not the hardness of the base metal in the chain but the thickness of the chrome plating that determines the length of staysharp. With the thicker chrome of the Stihl chain you can possibly maintain a working corner close enough to sharp to cut effectively, longer than you could with an improperly sharpened Oregon that will seem to go dull as soon as it touches wood. To each their own. I prefer two loops of Oregon for the price of a single loop of Stihl chain and I`ve never had an issue with sharpness or durability once I learned how to file properly.
Russ
Offline Sawyerfortyish
  • Bigger they are the more mess they make
Re: Bulk Saw Chain
« Reply #12 on: March 19, 2004, 04:13:27 PM »
Woodsman Pro is Carlton chain and that is what I use on my firewood processer it seems to run longer between sharpenings than Oregon or Stihl chain. I would like also to see someone do a test to compare chain hardness.
Offline Duane_Moore
  • the heck with edit it.
Re: Bulk Saw Chain
« Reply #13 on: March 19, 2004, 07:33:21 PM »
 :) ya ain't gona belive this, the door bell just rang.(it Dark here) and there was the fed-ex man.  1 roll of 20RC woodsman pro and a bunch of bars. the spool was 199.99 and a free file guide. ordered a bunch of the carlton Pro-champ bars. 19.95 each. didn't think could go wrong? 34" bars for 24.95,  well tell me.  Duh---Duane ;)
village Idiot---   the cat fixers----  I am not a complete Idiot. some parts missing.
Re: Bulk Saw Chain
« Reply #14 on: March 20, 2004, 05:25:07 AM »
$24.95 for a 34" bar, well I think thats avery good deal on bars.
Offline Preston
  • The Only Good Tree Is A Stump!
Re: Bulk Saw Chain
« Reply #15 on: April 01, 2004, 07:11:50 AM »
Hi Wiam
My suggestion would be madsens they will usuaslly beat baileys prices that I have seen in the past you run acrossed a special from them in any kind of chisel or round file chain for only $189.00 for 100' foot role! There web is www.madsens1.com/mainmnu.htm There prices are very competitive and seen they will beat allot of other peoples prices!
Preston
Preston
Bulk bar and chain oil
Started by Southside on Forestry and Logging
Last post December 26, 2013, 10:13:12 PM
by 1270d
Has anyone purchased bulk bar and chain oil ?
Started by sweetjetskier on Chainsaws
Last post April 06, 2013, 08:31:09 PM
by bill m
Making up from bulk chain
Started by Qweaver on Chainsaws
Last post July 08, 2017, 12:43:18 PM
by sawguy21
where do you buy your chain? or bulk order chains?
Started by Wildman Ben on Chainsaws
Last post June 29, 2016, 12:18:34 AM
by Big Wood
