Author Topic: Need input  (Read 2400 times)
Offline Merles Okie
Need input
« on: October 18, 2012, 07:52:36 PM »
Would like to say hello.  This is my first post (been lurking way too long).  I'll start with a little history about myself. I was born and raised on a large cattle and farming operation in Muskogee county Oklahoma.  Couldn't wait to get away at 18, but after way too long in Texas, I'm back where I started.  A few years ago I purchased an adjoining 80 acre creek bottom that has been untouched for the past 60 years.  I bought it because it has a mother-lode of large, mature hardwoods (walnuts).
Last year I purchased a new Timberking 1400 to use in both my woodworking endeavors and to build my wife's dream home.
Now for my dilemma and the question for you experienced woodsmen.  Because the land was abandoned for so long, I now have literally 100's of 8-12" diameter native pecans.  These trees look like utility poles.  They are 35-40' tall before the first limbs, and have very little upper story.  I need to remove most of these trees in order to access the large, mature hardwoods.
What do I do with these pecans?  I could cut them for firewood, chip them up for smoking or mill them.  If I mill, what's the best end product...structural timbers, framing lumber?  I'd appreciate your suggestions and input.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: Need input
« Reply #1 on: October 18, 2012, 07:57:58 PM »
MO......welcome to the forum.
Have you checked in your area to see what kind of a market there is for Pecan? I believe I would do that before I just went "nut" crazy and started dropping them.
Offline thecfarm
Re: Need input
« Reply #2 on: October 18, 2012, 07:59:25 PM »
Welcome to the forum,Merles.Any market for pecan logs? I prefer to sell the logs.Seems to be if it's cut into lumber,it has to be stored,covered,than have to find a buyer. Than it has to be looked over,50 boards or 2x4 later they pick out 10 and leave you to restack for the next person that wants 10.
Offline Sawdust Lover
Re: Need input
« Reply #3 on: October 18, 2012, 08:44:39 PM »
To bad you couldn't build some type of log outbuilding with them. Take lots of pics while building your dream home! Your about to enter some of the best moments of your life.
Re: Need input
« Reply #4 on: October 18, 2012, 08:47:44 PM »
Ya know......you are sooo right. Good reply SL    smiley_thumbsup
Offline NWP
    • Nicholson Wood Products LLC
Re: Need input
« Reply #5 on: October 18, 2012, 08:53:10 PM »
Firewood and market it to BBQ's and people with smokers.
1999 Blockbuster 2222, 1994 Duratech HD8, 1997 Duratech HD10, 2011 Case SV250, 2000 Case 1845C, 1990 Peterbilt 378 w/ Hood 7000 loader, 2001 Chevrolet, 2005 Chevrolet, several trailers, and Stihl saws.
Offline hackberry jake
Re: Need input
« Reply #6 on: October 18, 2012, 08:57:09 PM »
that's what I was thinking as well, being that small and pecan, I wouldn't cut boards out of gem unless you are going into the wooden pretzel business.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Need input
« Reply #7 on: October 18, 2012, 10:53:58 PM »
With logs that size, most every board will be influenced by the pith, which will cause cracks and checks in any lumber that you produce.  Even if you "box the heart" where the pith is contained in a thick timber, the timber will split and check real bad.  Pecan is also not an easy wood to dry straight.  You end up with a lot of crooks and waves in the lumber that you cannot do anything about except cut them out, significantly reducing yield.
I agree with the option to harvest the trees and mill the wood into a product that would appeal to people for cooking or BBQ restaurants that would use pecan wood as smoking wood.  You will have to do some research, but there is a lot of BBQ produced in that area of the world, and pecan is one of the best, if not the best, wood for BBQ.
Offline paul case
  • Original wearer of the PCM.
Re: Need input
« Reply #8 on: October 18, 2012, 11:01:41 PM »
If you cant find a good market and ya got a whole bunch of it, cut em and build your wife's dream house. It will make 2x4 and 2x6 put them up green and you will get by ok. PC
pc
Offline WDH
Re: Need input
« Reply #9 on: October 18, 2012, 11:03:14 PM »
Remember:
Pecan =  smiley_devil  :).  That is a well documented fact here.
Offline Okrafarmer
  • Location: upcountry SC-- Sweetgum capital of the world!
  • Exiled from Sawdust Land--plotting a return
Re: Need input
« Reply #10 on: October 19, 2012, 12:05:38 AM »
I guess it's either that or pulpwood. Seriously, if you can find the market for the smoker wood, that's what to do.
No matter how conventional wisdom may fly in the face of radical thought, it's still the most popular type.
Reduced to Uber Driver and a broken MS290 Stihl
Genesis Hardwood Lumber
Re: Need input
« Reply #11 on: October 19, 2012, 01:18:14 AM »
You might see if there is a pallet lumber cutting sawmill nearby. There is one about 3 miles from my house and hey take smaller diameter trees at tree length, they don't pay much but it would be Better than nothing.
Offline Meadows Miller
  • Location: Find a Job You Love & You Will Never Work Another Day In Your Life
  • The Walkabout Sawyer
Re: Need input
« Reply #12 on: October 19, 2012, 03:05:56 AM »
Gday
Welcome to The Forum Mate as Sawdust Lover said your just about to enter some of the best moments of your life Mate  ;) ;D ;D 8) 8)
As  others have said firewood from the tops and slab wood and you could either do crane mat timbers or dunnage out of the larger logs just to get them out of the road  so you can get the walnut ;) ;D ;D 8)
Dont be a stranger and keep us posted Mate  ;) ;D
Regards Chris
4TH Generation Timbergetter
Offline 1woodguy
Re: Need input
« Reply #13 on: October 19, 2012, 07:15:45 AM »
Another okie
Just so happens I live in Muskogee county also
In the corner where it sequoyah and Cherokee counties meet
Experience is a rough teacher first you get the test later comes the lesson!
Offline Ron Wenrich
Re: Need input
« Reply #14 on: October 19, 2012, 07:54:21 AM »
Logs that size will not produce much wood for the amount of time it will take to saw it.  Sawing costs would be very high.  Firewood or smoking wood are the best options.
Offline Leigh Family Farm
  • Live life the way you want. You only get one.
    • Isagenix
Re: Need input
« Reply #15 on: October 19, 2012, 10:49:49 AM »
Welcome to the Forum! Don't know if this is a viable option but since you are building your dream home, you ever thought about split rail fencing with the pecans? I don't know how long they would last outdoors but at least you could use them on your property. Then once you get the house built, take the fencing down and chop it up for firewood. Good luck and keep us posted! Take a picture or two...cause we like pictures!
There are no problems; only solutions we haven't found yet.
Offline WDH
Re: Need input
« Reply #16 on: October 19, 2012, 08:40:03 PM »
Pecan does poorly outside exposed to the elements.  Very poorly, in fact.
Offline Merles Okie
Re: Need input
« Reply #17 on: October 19, 2012, 09:32:19 PM »
Hey guys , appreciate very much your comments and input.To 1woodguy , I'm on the south end of the county- off I-40 and
Ross Road. Fin and Feather brings back fond memories, good food and remember the skating rink? Anyway back to the topic,
I have to clear these pecans to gain access also to allow my next generation of black walnuts to flourish, just looking for the
best way to utilize this resource. I was already seriously looking into marketing this pecan wood for bbq'rs I just didnt want
to miss a way to use it for lumber maybe around the farm i.e. sheds or outbuildings.Again thanks for all your input.
Offline Okrafarmer
Re: Need input
« Reply #18 on: October 19, 2012, 11:36:17 PM »
Pecan does have its uses. You might wish to mill up a little bit to keep for odds and ends projects where you want some good hard wood for some reason. Like tool handles, for instance. But the bulk of it is probably best utilized for firewood, smoking wood, or pulp.
WHD is right, Pecan and other hickories rot and get eaten up by bugs more quickly than many other types of wood when left around outside, or in any damp environment.
Offline 5quarter
    • Blue Harbor Refinishing
Re: Need input
« Reply #19 on: October 19, 2012, 11:47:24 PM »
   Maybe cut them in 10' lengths and make split rail fencing. possibly cut poles for stockade fencing. I've got  split hickory rail along one side of my garden. other that weathering they still look nice.  leave some to mature...there is a market for Pecan veneer. like Okrafarmer says, cut some of the largest trees for lumber. it's nice to have on hand.
I would like a little input
Started by peter nap on Forestry and Logging
Last post February 27, 2009, 08:24:07 AM
by Chico
looking for input
Started by little-guy on Sawmills and Milling
Last post January 06, 2006, 01:35:12 AM
by little-guy
looking for input
Started by KDEC19 on Sawmills and Milling
Last post January 06, 2012, 09:56:04 PM
by Dan_Shade
question
Need Your Input
Started by jwhuntman on Forestry and Logging
Last post November 16, 2011, 10:27:56 PM
by jwhuntman
