Author Topic: Kiln liner  (Read 1937 times)
Offline pasbuild
Kiln liner
« on: March 19, 2004, 04:14:33 AM »
Can rubber roofing be used as a kiln liner?
If it can't be nailed or glued then screw it
Offline HORSELOGGER
  • The Lord is my Shepherd, I have everything I need!
    • Heritage Horselogging & Lumber Co.
Re: Kiln liner
« Reply #1 on: March 19, 2004, 05:04:15 AM »
When I built my kiln chamber, I paid these 2 guys to come out and spray expanding urethane foam, 4 inches thick ( r 28 ) when looking at all costs, including my labor, it was much more cost effective to have this done than buy all the insul board and caulk and plywood and kiln paint, etc....
It has held up well , been in since last summer.
"Surgical removal of standing timber, Leaving a Heritage of timber for tommorow. "
Offline Don_Lewis
  • dry kilns, heat pumps
    • nyle
Re: Kiln liner
« Reply #2 on: March 19, 2004, 05:42:48 AM »
Foam is a great way to go but to answer your question, yes, roofing rubber stands up very well in a kiln environment
Offline ElectricAl
  • 1993 LT40HDE15 2012 LT50HDE25
Re: Kiln liner
« Reply #3 on: March 20, 2004, 04:15:19 PM »
HorseLogger,
What was your installed price per sq foot?
We talked to an installer that quoted $1 per sq ft. for a soybean based expanding foam. Another installer that uses a petroleum based product quoted $2.25 per sq ft.
Pretty happy to find an environmentally friendly product is cheaper. ;)
Linda and I custom saw NHLA Grade Lumber, do retail sales, and provide Kiln Services full time.
Offline HORSELOGGER
Re: Kiln liner
« Reply #4 on: March 20, 2004, 05:14:50 PM »
Al... 50 cents per sq ft per inch of thickness. I went with 4 inches of thickness, so my cost was 2 bucks a foot. I framed the building, sheeted the outside walls with metal and that was the extent of my involvement. They had it done in 3 hours.....Hey ... wait a minute... thats about 700 beans an hour :o Maybe I need to find the FoamestryForum and change professions :D... Nah, them chemicals make a guy goofy after a while
Offline Ga_Boy
  • Been rode hard and hung up wet; more than once.
Re: Kiln liner
« Reply #5 on: March 21, 2004, 02:00:48 PM »
Horselogger,
What did you do for the inside of the kiln?
Did you leave the foam exposed or cover the foam with some type of sheeting?
I like the idea of using foam, like you said no caulking to seal the air leaks.
Offline Den Socling
  • just wondering
Re: Kiln liner
« Reply #6 on: March 21, 2004, 02:39:40 PM »
I've seen DH kilns built with wood and sprayed with foam. That's it. It's done. After a couple years, they kinda look like a cavern.  ;D
Offline HORSELOGGER
Re: Kiln liner
« Reply #7 on: March 21, 2004, 05:46:42 PM »
Yep, just installed my fans and loaded it up. We have bumped it a bit, as would be expected, but no ill effects. I found it really easy to maintain my desired temp this winter, but it is really easy to overheat in summer.
Offline UNCLEBUCK
  • Life out on the prairie !
Re: Kiln liner
« Reply #8 on: March 25, 2004, 06:40:51 PM »
I have seen this spray on foam on the web and it can be shipped in kits that look like 5 gallon gas cans along with nozzles and instructions ,its some kind of pre-charged can ready to go for the do -it yourselfer ! I found it on askjeeves somewhere . Looked like a popular place .
Offline Don_Lewis
    • nyle
Re: Kiln liner
« Reply #9 on: March 27, 2004, 05:37:56 AM »
The do-it-yourself kits usually are expensive and/or make too light foam for a kiln. You need at least 2.2 pcf density for the long haul in a kiln chamber. Also, be sure that it is installed in multiple layers with no pass being over 1.5" thick. If you do these steps you will have something that will last many years. I have seen kilns 20 years old that were done right and standing up very well and I have seen kilns where the foamer decided he knew better and in 3-4 months, there were serious problems. Most of the guys that blow this stuff seem to have inhaled a bit too much of it and will argue the points. But this recommendation came from the two leading foam manufacturers and has been proven over the last 20 years many, many times.
Chimney liner
Started by Cguignard on Firewood and Wood Heating
Last post October 18, 2016, 06:47:07 PM
by Al_Smith
possible tree seedling container liner
Started by Lanier_Lurker on Ask The Forester
Last post January 26, 2009, 11:15:15 AM
by SwampDonkey
Liquid truck bed liner for a cement mixer?
Started by scgargoyle on General Board
Last post April 07, 2014, 02:00:41 PM
by mometal77
Pre-build solar kiln questions(Photos of kiln building progress)
Started by caveman on Drying and Processing
Last post April 17, 2016, 06:35:35 PM
by caveman
