TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: Gearmatic 19 winch  (Read 4622 times)
Offline Ed_K
Re: Gearmatic 19 winch
« Reply #20 on: November 16, 2012, 07:51:27 PM »
When mine wore out i checked into new, $ 5,000. is what a gearmatic dis.will ask for a new one. I had mine rebuilt at a machine shop for $300.
Ed K
Offline DDDfarmer
  • did you know 4/3 people don' know their fractions
« Reply #21 on: November 17, 2012, 10:48:44 AM »
easy to do the minor repairs on the machine bands-slave cylinders-springs.  Just remember to cover the holes between the fuel tank and frame BEFORE you start the work. Stuff does get dropped down there and they are not fun to get out.
Treefarmer C5C with cancar 20 (gearmatic 119) winch, Husky 562xp 576xp chainsaws
Offline madmax
« Reply #22 on: November 18, 2012, 10:45:16 AM »
My brake got stuck on, same as other people, if I keep the winch in release position, will this eliminate the band from getting stuck? Sounds practical?
Offline DDDfarmer
« Reply #23 on: November 18, 2012, 12:41:16 PM »
Then you will always have pressure on your hydraulic lines and the springs will be under tension.
Offline captain_crunch
« Reply #24 on: November 23, 2012, 01:46:13 PM »
Only cure I know for keeping brake and clutch bands from sticking is start machine bout once a month and play with winch :) :) Band tolarences are touchy on the gearmatic condensation is worse issue when winch has been working it gets warm and as it cools moisture forms. But when they are working right bout best winch going
gearmatic 19 winch
Started by treefarmer87 on Forestry and Logging
Last post March 08, 2010, 06:54:58 PM
by logger92
gearmatic winch
Started by ehp on Forestry and Logging
Last post April 22, 2015, 07:07:01 PM
by ehp
Gearmatic winch
Started by oldseabee on Forestry and Logging
Last post February 02, 2013, 10:48:10 PM
by oldseabee
gearmatic winch
Started by coxy on Forestry and Logging
Last post November 25, 2013, 08:02:44 PM
by Ed_K
