Author Topic: Insulation ?  (Read 4081 times)
Offline J_T
  • Some of anything beats all of nothing Even in Dukedom Tn
Insulation ?
« on: March 21, 2004, 09:28:58 AM »
I took apart a large frezer one time it was 16x20 or larger .It was used to make ice when they use to ice down rail cars .The walls were 8'' wide and filled with sawdust .Why couddn't you use it in a wall for a kiln ??? I know it would need to be dry and you could line the walls with a water proof liner. I know I am tighter than Dan G. ;D Also Boss says no more money sawdust I got .
Jim Holloway
Offline Buzz-sawyer
  • To see it is to saw it....
Re: Insulation ?
« Reply #1 on: March 21, 2004, 10:19:13 AM »
JT
Why not add borax to the sawdust....bug -fungus proofing it;
and fire profing it to boot?
Old timers used it for years to keep ice over the summer.....
    HEAR THAT BLADE SING!
Offline Kevin_H.
  • my two boys
Re: Insulation ?
« Reply #2 on: March 21, 2004, 10:50:51 AM »
hey buzz, is that your truck?
sorry cant help on the sawdust insulation :(
Got my WM lt40g24, Setworks and debarker in oct. '97, been sawing part time ever since, Moving logs with a bobcat.
Offline J_T
Re: Insulation ?
« Reply #3 on: March 21, 2004, 12:24:02 PM »
Thanks Buzz didn't know about it were you get it ? Was fishing wonder what the R value is ?
Jim Holloway
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
Re: Insulation ?
« Reply #4 on: March 21, 2004, 12:56:03 PM »
  I know a guy that made a sawdust filled wall-Kiln. Right now, it's looking pretty bad, sawdust spillin outta the holes that the TERMITES ate through. :o :o  He said it worked REAL well, till the bugs got to it. ;D
Offline J_T
Re: Insulation ?
« Reply #5 on: March 21, 2004, 05:14:55 PM »
FD we gona pison them bugs Soon as Buzz tells me how.How long did it take before he had trouble? I do things on a shorter cycle as I have no warrenty on how long I may be here. : ;D
Jim Holloway
Re: Insulation ?
« Reply #6 on: March 21, 2004, 05:26:47 PM »
  From lookin at all the other projects he has layin around, I'd say, about, 10 years??? :D :D :D
Offline J_T
Re: Insulation ?
« Reply #7 on: March 21, 2004, 05:35:13 PM »
You talking about him or me ??? If him sounds like I got a brother I didn't know I had. ;D
Jim Holloway
Offline Buzz-sawyer
Re: Insulation ?
« Reply #8 on: March 21, 2004, 06:39:44 PM »
 ;) :DHey Harold....
comming from you (about projects on the burner)
I believe Ill be done with my solar, high efficiency, biodiesel, steam powered egg beater 10 years before you clean your plate :D :D
you gotta head start onme too :P :o :o ;D :D
Offline J_T
Re: Insulation ?
« Reply #9 on: March 21, 2004, 06:53:15 PM »
Hay Buzz what about that Borax ??? Anyone know R value?Don't mean to be persentant the only Borax I ever heard of was washing powders. Help am I missing something  :-[
Jim Holloway
Offline etat
  • Member*
Re: Insulation ?
« Reply #10 on: March 21, 2004, 07:08:32 PM »
J_T, them borax washing powders, and boric acid (like roach powder) is what it be.  Mix em up with ye ole sawdust and it'll make it fire resistant, mold resistant, and insect resistant.  Couple a recipes online fer making it up so's you can spray it on wood, one with antifreeze, and one with just plane ole water. Probably could just mix it in with sawdust.  Borates makes a good wood preservative, only thing is the borates leach out over time from the rain and such.  Closed up in them walls doubt it'd go anywhere.
Another thing you could mix with it would be copper sulfate, like you get at the feed store, but I don't think you could mix it up in a spray.
Sawdust, huh.  I wondered what made them danged old freezers so heavy!!!!!
Re: Insulation ?
« Reply #11 on: March 21, 2004, 07:12:37 PM »
  Like ta keep projects lined up. Keeps me from getting bored ;D ;D  I'm anxiously waiting to have them cloned thingys legalized. I'm gonna order me a dozen ;) :)
Offline J_T
Re: Insulation ?
« Reply #12 on: March 21, 2004, 07:16:52 PM »
Thanks CK I wrecked that old ice house at Obion Tn That is where I saw it . Had to been thare a long time . 8)
Jim Holloway
Offline Buzz-sawyer
Re: Insulation ?
« Reply #13 on: March 21, 2004, 07:26:19 PM »
Jt
Yea what ck said....
I am not sure on r value...but I paid a fortune for tore up newspapers soaked in borax at the hardware store.... commonly called cellulose insulation....8 inches was bout r-27 or 30
Offline J_T
Re: Insulation ?
« Reply #14 on: March 21, 2004, 07:32:53 PM »
 Thanks Buzz recon we could toat sum up in the attic? I got  plenty :D :D
Jim Holloway
Offline Buzz-sawyer
Re: Insulation ?
« Reply #15 on: March 21, 2004, 07:38:51 PM »
friend of mine cut ice from the lake and used a backhoe to dig a "ICE HOUSE" then covered with layers of sawdust....just to see if it would work....it did
Offline mur
Re: Insulation ?
« Reply #16 on: March 21, 2004, 08:56:40 PM »
Insulation value is R 2.44 per inch of sawdust.
Source: Pocket Ref by Thomas J. Glover.
Don't dream it, be it.
Re: Insulation ?
« Reply #17 on: March 22, 2004, 04:03:20 AM »
  ALRIGHT, another member with stats ability. 8) 8)
 Welcome to the Forum, mur.
 Reckon, before long, there won't be a single problem this bunch can't solve.  ;D ;D ;D ;D
Offline Norwiscutter
  • Have a nice day!
Re: Insulation ?
« Reply #18 on: March 22, 2004, 03:23:53 PM »
so a feller could get a jag of sawdust, mix in some borax, and presto...bob's yer uncle...you got free attic insulation instead of paying for cellulose?   ??? There has got to be some major disadvantages else people would be doing this already wouldn't they? The weight issue doesn't seam to be a concern that couldn't be planned for.  I supose the major down side would be the dust wouldn't it? Got me thinking now.
Si vis pacem, para bellum.
Online beenthere
Re: Insulation ?
« Reply #19 on: March 22, 2004, 03:38:57 PM »
Sounds like a reasonable idea to use the sawdust in the walls for a kiln, as it would be cheap(er), and likely available (although not dry), but a bit heavier than cellulose (wouldn't put it in my house walls, and for sure not the ceiling). Borax (twenty mule team) probably could be mixed with the sawdust too, and at least the mold would be reduced. If used where no termites, then they should not be a problem.
Because it is cheap, probably having to replace the kiln walls in a few years wouldn't be a big deal either. Getting the sawdust dry and keeping it dry might be a trick, but not impossible, and maybe not that necessary.  If it rots, replace it with new.
There is no question sawdust keeps ice from melting, well into the hot summer. But it remained pretty wet, and likely would be replaced each winter ice was brought in.
Interesting ideas.  But if it really worked for insulating house walls and ceilings, it would already be used - I would bet.
;D
cold weather insulation vs hot weather insulation
Started by jueston on Timber Framing/Log construction
Last post January 31, 2014, 08:07:24 PM
by RavensWood
insulation
Started by Raider Bill on General Board
Last post March 24, 2008, 03:11:26 PM
by scsmith42
Kiln insulation
Started by Bnewman712 on Drying and Processing
Last post May 29, 2018, 07:41:08 PM
by Bruno of NH
Shed Insulation
Started by Steve_M on General Board
Last post December 28, 2005, 12:59:48 PM
by Larry
