Author Topic: Insulation ?  (Read 4082 times)
Offline J_T
  • Some of anything beats all of nothing Even in Dukedom Tn
Re: Insulation ?
« Reply #20 on: March 22, 2004, 03:44:59 PM »
 I think one reason is the sound of it . You know hey Joe just had ten inches sawdust blowed in my attic  Another reason WORK . A circle saw makes bigger pieces you could screen it for size or put it over plastic.That celulose is dustey ever blow any on a hot day ? :) :)
Jim Holloway
Offline J_T
Re: Insulation ?
« Reply #21 on: March 22, 2004, 03:49:14 PM »
 Sorry my brain is naping again  :D Thanks Mur and welcome I needed that . 8)
Jim Holloway
Offline etat
  • Member*
Re: Insulation ?
« Reply #22 on: March 22, 2004, 03:57:25 PM »
I'm a thinking it would be a magnet for soaking up moisture, even out of the air.
That said most of the new houses around here are being decked with sawdust as we speak!   They mix it with glue and call it OSB!!!!! ;D ;D ;D
Old Age and Treachery will outperform Youth and Inexperence. The thing is, getting older is starting to be painful.
Offline Don_Lewis
  • dry kilns, heat pumps
    • nyle
Re: Insulation ?
« Reply #23 on: March 23, 2004, 02:15:26 PM »
It will get pretty wet and wet sawdust doesn't have a very high R factor.
Offline J_T
Re: Insulation ?
« Reply #24 on: March 23, 2004, 03:46:06 PM »
Why don't them ground up newspapers get wet ?
Jim Holloway
Offline Buzz-sawyer
  • To see it is to saw it....
Re: Insulation ?
« Reply #25 on: March 23, 2004, 03:54:12 PM »
Paper has better insu power cause of the air trapped in all the little pockets,
so the fluffy-er the sawdust the better...in using it in walls an uniterupted vapor barrier would prevent moisture from the inside....could easily treat the dust with insecticide as well
Spread
Spray
Dry install
reason it isnt being used...newer better materials exist
It has been used in the past extensively...including homes
    HEAR THAT BLADE SING!
Offline mur
Re: Insulation ?
« Reply #26 on: March 23, 2004, 10:34:43 PM »
The main problem with sawdust is that it settles with time.  Compacts down at the bottom - not much insulating value there and then almost no insulating value in the void at the top of the wall.  The old sawmill cabins around here used it back in the Fifties and the walls were half empty of sawdust 20 years later.  It had settled.
Don't dream it, be it.
Offline Don_Lewis
    • nyle
Re: Insulation ?
« Reply #27 on: March 25, 2004, 04:22:06 AM »
Actually none of the open cell type insulations, sawdust, cellulose (ground newsprint), fiberglass, mineral wool, expanded polystrene etc. are good to use in a wood frame kiln. As long as the dewpoint falls in the insulation and it is open cell, it will get wet. You can slow it down with an effective vapor barrier but there are few perfect vapor barriers.
Offline FeltzE
  • Fayetteville NC, Stop by and visit some time!
    • Feltz's Sawmill
Re: Insulation ?
« Reply #28 on: March 31, 2004, 05:33:07 AM »
Sawdust
Pros:
Cheap
Plentiful
Cons:
Needs to be dried for best R value
Needs to be protected from moisture Bagged or Wraped
Fire hazards
Settling
cold weather insulation vs hot weather insulation
Started by jueston on Timber Framing/Log construction
Last post January 31, 2014, 08:07:24 PM
by RavensWood
insulation
Started by Raider Bill on General Board
Last post March 24, 2008, 03:11:26 PM
by scsmith42
garage insulation
Started by redpowerd on General Board
Last post October 31, 2004, 02:51:39 PM
by SwampDonkey
Insulation for New Kiln
Started by pine on Drying and Processing
Last post January 19, 2017, 10:34:52 PM
by Darrel
