Author Topic: Wood use question  (Read 895 times)
Offline xlogger
Wood use question
« on: November 18, 2012, 05:42:25 AM »
I'm starting my first winter year use on my Central Boiler CL5036. I got it up and going at the end of last winter and just be using it for hot water and I have an outdoor hot tub heated with it. Now that it getting cooler and really not real cold here I'm having to supply it twice a day. I'm using mostly poplar slabs now from the mill that are not real dry about 1-3 months old and some older pine. My home is about 2000 sq ft.  I know oak and hickory last longer but does it make a big differents? Just wondering how others with about the same useage do?  Ricky
Offline doctorb
  • Unofficial Team Physician
Re: Wood use question
« Reply #1 on: November 18, 2012, 06:04:26 AM »
I think the answer is in three parts.
1.  Seasoned wood is much more efficient than wood with a high water content.  Because you will spend more energy boiling off the water in green wood, less energy is available to heat the water in your stove.  The amount of usable heat is definitely greater with seasoned fuel.
2.  Since your heat demands are not great at the moment, the length of time between OWB cycles can be pretty long.  Green wood has a much tougher time "refiring" after it sits in the idle mode.  So for heating in the non-winter months for hot water and hot tubs, your fire will go out much less often with seasoned wood.
3.  Sure, oak, locust, and other hardwoods are better than poplar and pine.  Look up a chart on BTU's per cord of wood and check out the difference between different species.  With that said, many people here on the FF burn nothing but spruce and pine.  Burn what you have available....but  season it if you can for maximum heat and efficiency.
Offline thecfarm
« Reply #2 on: November 18, 2012, 06:39:46 AM »
I have a Heatmor and I did a few experiments with green wood and not so dry wood,both hardwood and pine. The wood needs to be dry to get a good burn time. I found out it makes a big difference. I also noticed a big difference on how much smoke-steam it put out too. Have to get the moisture out of the wood to burn it,be it by burning or by drying.Start on next years wood now.
Offline xlogger
« Reply #3 on: November 18, 2012, 07:07:45 AM »
I do have some dry oak probably about 2 cords that I'm saving for colder days. Also stacking up cedar and oak slabs for next year. I'm trying to burn wood that will not last outside now like pine and poplar from the sawmill. I was just hoping only to fill the heater once a day. I go to work real early and get home late, sometimes when I get home now the temp is around 160 and I usually keep it between 175-180.
Offline wheelinguy
  • it makes sense inside my tiny little brain!
« Reply #4 on: November 18, 2012, 07:45:42 AM »
How big are the slabs and how many are you putting in?  I have a cl 6048 and live in a cooler climate than you, I burn the pine slabs off my brothers mill and in the dead of winter I have to Put wood in twice a day.  When I burn the slabs they are usually 2-4 feet long and fresh off the mill.  The rest of the time we burn 2 foot stuff, I do the same as you and save the good dry stuff for the really cold days (-20 F).   But i think that you will find checking the boiler twice a day is the way to go.  I am heating about 5,000 square feet with mine, 2 story house plus full basement, and my workshop, all radiant heat.
Offline xlogger
« Reply #5 on: November 18, 2012, 08:30:42 AM »
The slabs range from small to having a hard time getting them in. I have a friend that has a 6048 and he gets by with once a day. His home is probably around 3000 and no hot tub. When he goes out of town I go by and fill it up for him. Probably holds near twice the wood my 5036 holds.
Wood Owl bit question.....
Started by Jim_Rogers on Timber Framing/Log construction
Last post May 26, 2010, 09:02:58 AM
by shad
Willow wood question
Started by levans on Sawmills and Milling
Last post July 30, 2012, 10:00:31 PM
by woodmills1
pulp wood question
Started by Quebecnewf on Sawmills and Milling
Last post May 30, 2005, 09:45:15 AM
by Gary_C
Wood stack question
Started by Arctiva on Firewood and Wood Heating
Last post September 16, 2019, 09:09:55 PM
by jmur1
