Author Topic: cold weather starting Caterpillar 51 horse diesel  (Read 7465 times)
Offline GeorgeK
« on: November 24, 2012, 01:28:48 PM »
I have just recently bought a used LT 40 with 51 horse Cat diesel any tricks on getting it to start when cold. Thanks, George
George Kalbfleisch
Woodmizer LT40, twin blade edger, Bobcat A300, Kubota L48 and yes several logrites!
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: cold weather starting Caterpillar 51 horse diesel
« Reply #1 on: November 24, 2012, 03:56:36 PM »
Hi George, my LT40 has a gas engine. But I have always wondered if the diesels have a plug in heater to keep them warm. Probably not.
Glad you got a mill. I hate cold weather!  :)
Offline JustinW_NZ
  • Just Hacking and stacking.
    • Logs2Lumber
« Reply #2 on: November 24, 2012, 04:07:55 PM »
Ive got the lombardini diesel and found it fine in cold/snow the only things i found to watch weremake sure you have antifreeze and you prime the diesel pump and that diesel isnt to much of a "slurry" from freezing.
Im unsure if the cat has a manual diesel primer?
Cheers
Justin
Gear I run;
Woodmizer LT40 Super, Treefarmer C4D, CAT 528 swinging grapple, 10ton wheel loader.
Offline ladylake
« Reply #3 on: November 24, 2012, 05:12:10 PM »
 It's 10 above here this morning, just right..   Little Isuzu popped right off.  You can have that 80+  humid  stuff.   Steve
Timberking B20 14000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #4 on: November 24, 2012, 05:14:34 PM »
My experience with Cat's are from days gone by however, most if not all diesels like
heat, so if you can preheat the block with a heater of some type
and keep your fuel liquid you should be fine,
How cold does it get in your neck of the woods?
Best DGDrls
Offline ladylake
« Reply #5 on: November 24, 2012, 05:50:21 PM »
 Around -30 to -35 on the worst days, I try not to saw below +5 or so.    Steve
Offline jcbrotz
    • Brotzmans Woodworks
« Reply #6 on: November 24, 2012, 06:12:21 PM »
Keep the glows in good order and all your filters. If she's hard starting get the timing checked, my cat skidsteer is the best starting diesel I have ever seen, I dont even hit the glows till below 10 then only give them 10-20 sec. The kubota on the mill is a close second, but I do have to glow plug that on longer I blame that on the mechanical fuel pump though.
2004 woodmizer lt40hd 33hp kubota, Cat 262B skidsteer and way to many tractors to list. www.Brotzmanswoodworks.com and www.Brotzmanscenturyfarm.com
Offline customsawyer
    • The Custom Sawyer
« Reply #7 on: November 24, 2012, 06:29:55 PM »
That 51hp cat is actually a perkins. I turn the key and let the glow plugs warm up a little and then hit the starter. The only problem I have had on these engines starting is they seem to be a little low speed on idle so you may have to turn the idle speed up a little. The other problems with these engines is another matter.
Two LT70s and to much other support equipment to mention.
www.thecustomsawyer.com
Offline ladylake
« Reply #8 on: November 24, 2012, 06:36:17 PM »
 On any diesel if you can hold the throttle open when cranking it will start better.   Steve
Offline wascator
« Reply #9 on: November 24, 2012, 08:05:57 PM »
Warmth always helps: heads, and oil, in that order.
Any way you can warm the coolant and oil will help 'er start. careful with the ether. I would not use it due to the risk of damage.
Offline Don_Papenburg
  • I need money
« Reply #10 on: November 24, 2012, 08:26:57 PM »
Customsawyer , what is the other problem with the little perkapillar?
Offline GeorgeK
« Reply #11 on: November 24, 2012, 10:11:16 PM »
Thanks for all the input today. I will check several things tomorrow and talk to the cat dealer in town onMonday. It was 26 this morning but my Kubota tractor started fine. Many items here to look at and I will look at all plus clean the battery terminals. The battery shows good but will take to be checked Monday also. It started fine yesterday at 40 degrees.
George Kalbfleisch
Offline valley
« Reply #12 on: November 24, 2012, 10:17:41 PM »
It doesn't get that cold here but I have several diesel engines and anything below freezing will make some of theme hard to start I simply use a dipstick heater in the ones that don't have a built in block heater :::: problem solved on mine anyway
Have a great day unless you have other plans !!!
Offline Okrafarmer
  • Location: upcountry SC-- Sweetgum capital of the world!
  • Exiled from Sawdust Land--plotting a return
« Reply #13 on: November 24, 2012, 10:25:38 PM »
Clean the battery terminals, yes, and be sure that all your wiring involving the battery, ground, and starter is fully functional. Sometimes wires will break part way through, or develop a short, or whatever, and not be as efficient, but still marginally work.
Draining your fuel at the end of the day and bringing it warm fuel to start with may help-- even better, but more trouble, is draining the oil when you're done, and heating it up before putting it in before starting. Ditto coolant. Or any other way you can warm the engine up from the outside before trying to start it. My dad used to take a bucket of hot coles and put it under the bulldozer engine, with a tarp over it to help keep the heat in. That would warm things up enough to get its blood pumping.
These are all "old army tricks," or "old Russian tricks," or as we would say in Maine, "old indian tricks," though I'm not sure if the old indians had diesel engines. . . .  just sayin'
No matter how conventional wisdom may fly in the face of radical thought, it's still the most popular type.
Reduced to Uber Driver and a broken MS290 Stihl
Genesis Hardwood Lumber
Offline Okrafarmer
« Reply #14 on: November 24, 2012, 10:27:12 PM »
Valley, I'd actually never heard of a dipstick heater-- you learn something new every day. That sounds like a real spankin' good idea-- imagine if the old indians had just come up with that idea, way back when!
Offline Brad_S.
« Reply #15 on: November 24, 2012, 11:10:35 PM »
I have used a kerosene topedo style heater pointed at the engine for a while to get it going after my glow plugs bit the dust.
  • I need money
« Reply #16 on: November 24, 2012, 11:51:47 PM »
I used to carry a propane stove burner  and fire it up and slide it under the oilpan on my ol GMC . Then whenI got it running I would take it to the back and warm the air valve so the brakes would work
Offline Okrafarmer
« Reply #17 on: November 24, 2012, 11:59:13 PM »
And then stick it on your dash board to act as a defroster?
Offline Satamax
« Reply #18 on: November 25, 2012, 02:50:55 AM »
Well, many good replies. I didn't know about the dipstick heater either.
I work for a chairlift company in the winter, and we have had generators to start when realy cold. Biguns, 400KVA or more.
Two tricks i've found, boil a big saucepan of water, and bring it up puting the fuel filter butt in it. Even better atach the saucepan with two bungees while you start it.  And put some boiling water on the intake manifold, slowly pouring, to raise the intake air temp. Well, there's always the MEK solution.
French CD4 sawmill. Latil TL 73. Self moving hydraulic crane. Iveco daily 4x4 lwb.
Offline red
  • we will never forget
« Reply #19 on: November 25, 2012, 06:55:32 AM »
Hot Air . . think hot air balloon
We have a lot of good boys and girls in harms way
lets all support them and their familys.
Cold weather starting
Started by concretecutter on Forestry and Logging
Last post January 23, 2016, 01:53:40 PM
by gspren
cold weather skidder starting
Started by a old timberjack on Forestry and Logging
Last post March 26, 2008, 07:17:01 AM
by a old timberjack
Detroit cold weather starting
Started by madmari on Forestry and Logging
Last post February 01, 2011, 07:56:11 PM
by Ed_K
Cold weather Diesel Additives.
Started by POSTON WIDEHEAD on General Board
Last post December 27, 2015, 05:54:25 PM
by Polly
