Author Topic: What do you charge for surfacing lumber?  (Read 1078 times)
Offline WoodenHead
« on: December 04, 2012, 06:14:41 PM »
I sell lumber and most of the time customers want rough material.  However, I have had demand for 1 x 4 and 1 x 6 finished 4 sides or 1 x 10 board and batten planed one side.  I was wondering what people charge for surfacing lumber one side, two sides, three sides and four sides.  Do you charge by the linear foot?  Or by the hour?  I'm thinking mainly softwood, but I'd be interested in comments on hardwood as well.
Offline red oaks lumber
Re: What do you charge for surfacing lumber?
« Reply #1 on: December 04, 2012, 06:36:45 PM »
i charge by the board foot, it dosent matter if its 1 side or 4 side  the price is the same, its still only one pass thru the planer.
 softwoods is .16 cents per b.f.
 hardwoods is .25 cents per b.f.
Offline woodmills1
  • the truth shall set you free
« Reply #2 on: December 04, 2012, 06:58:13 PM »
I get 60 or 70 an hour for custom work
planing or joint, rip and or mold
60 for what I think will be repeat customers and 70 for one timers
nails are extra
Offline learner
  • Learning and passing on what I know.
« Reply #3 on: December 08, 2012, 11:17:42 PM »
Specialty work is better charged by the hour I believe.  Unless you factor in the time to move the boards(loading/un-loading etc.), it's far easier by the hour than having to calculate the board footage.
The Only time I would ever consider charging by the board foot is if drying services are requested.  In that case an hourly rate isn't acceptable.
WoodMizer LT40 Super Hydraulic, MF-300 FEL, Nissan Enduro 60 forklift, 2 Monkey Wards Power Kraft Radial arm saws, Rockwell series 22-200 planer, Prentiss 210 loader
Offline scsmith42
    • Whispering Pines Farm
« Reply #4 on: December 19, 2012, 12:56:07 AM »
I typically charge by the manhour ($65.00), but my standard prices for low volume (less than 100 bd ft) are:
Joint/planing (1 pass both sides) .40 bd ft
Wide boards (2 passes both sides) .50 bd ft.
SLR - first edge:  .15
SLR both edges:  .40
Anything non-standard (such as a slab) is based upon the actual time spent and has a $20.00 minimum.
I use an Oliver Strait-o-plane that joints and planes in one pass.  Firing up the Jointer/planer or Mattison SLR requires me to run the generator and large dust collection system, and it adds about 4 minutes to the overall process.
I don't feel that my labor rate is too high; if anything it is too low, as I am covering not only labor but generator fuel and all equipment maintenance out of the hourly charge.  A typical mechanics garage charges $80.00 - $95.00 around here, and I have at least as much invested in my operation as a garage does.
Tom's 3638D Baker band mill
What do you Buy/Charge for lumber??
Started by adam on Sawmills and Milling
Last post May 31, 2009, 08:56:01 AM
by DR_Buck
What do you charge for rough cut cypress lumber?
Started by Bogue Chitto on Sawmills and Milling
Last post February 19, 2012, 11:16:03 AM
by Okrafarmer
Surfacing 6 x 6 x 20'
Started by JRC on Sawmills and Milling
Last post February 22, 2010, 08:08:26 PM
by laffs
The Best Surfacing Machine You'll Ever Buy!
Started by B@kerLuke on Baker Products
Last post November 20, 2018, 10:25:55 AM
by B@kerLuke
