Author Topic: Stihl Rapid Micro X ripping chain?  (Read 2825 times)
Offline Stanisas
« on: March 25, 2004, 02:32:24 PM »
I've seen Stihl Rapid Micro X ripping chain mentioned on Stihl boxes and in their German catalog, but have never actually seen what it looks like.  Has anyone seen or used Stihls ripping chain?  If so how would you rate it compared to the Granberg type or the Oregon type?
I'm also wondering why Stihl didn't use their Rapid Super as a base for their ripping chain instead of the Rapid Micro?
Same question for the Picco Micro X ripping chain.
Offline Carl_B
Re: Stihl Rapid Micro X ripping chain?
« Reply #1 on: March 25, 2004, 05:51:35 PM »
When we had the procut mill we were using sthil full skip rapid super 3/8 ripping chain . You may have to ask your dealer to order it for you cost is a little less than reglar chain . We also tried semi skip rapid super that work well.Either chain will cut faster than reglar chain.
Offline Kevin
« Reply #2 on: March 25, 2004, 05:53:41 PM »
The only problem I had with RS was the top plate angle which leaves a rougher finish but it cuts well.
Offline Carl_B
« Reply #3 on: March 26, 2004, 04:29:02 AM »
I refile all of my ripping chains to a 5 degree angle the cut is a little rougher but I think it cuts faster than 0 degree. This chain comes out of the box with a 15 degree angle.
Stihl ripping chain
Started by Mike_Barcaskey on Sawmills and Milling
Last post January 14, 2006, 12:50:20 AM
by chainsaw_louie
Stihl 63PMX Oilomatic Chainsaw Chain Ripping
Started by Beefie on Sawmills and Milling
Last post December 24, 2013, 11:45:42 AM
by Grandedog
Sharpening a Micro-chain...
Started by mrcaptainbob on Chainsaws
Last post April 10, 2013, 10:38:36 PM
by mrcaptainbob
runnzell ab micro max chain grinder
Started by 732hess on Chainsaws
Last post January 22, 2010, 09:55:28 AM
by 732hess
