Author Topic: Planning on building a twin saw dimension mill, asking for advice  (Read 789 times)
Offline Dan K
  • Location: In the Wet Tropics near Cairns, Queensland , Australia
A bit of an introduction, I have been lurking for a while now, soaking up info hell west and crooked.I have been working away at a very remote minesite for more than a decade, and will be moving back to our home in the Wet Tropics, just south of Cairns, Queensland , Australia. One our home block  has quite a few mature Caribean pines ( Pinus caribaea) to remove from a paddock before I can clean it up. The reminder of the block is hilly rainforest, with a few accessible feature grade hardwoods and a fair quantity of secondary semi hardwoods. I plan on milling for immediate family only.
I'm looking to build a mill, and cut my teeth on the pine, before I am game enough to hoe into some of the more valuable stuff. I have recently acquired a 51hp Perkins and a right angle gearbox, and I'm looking to build a mill with a 12" verticle cut and a 6 - 12" horizontal cut ( yet to be decided ).
My question from the more experienced millers out there is : should I go the traditional dimension saw method of using pulleys, belts and jackshafts to drive the saws,  or should I go straight hydraulic, with a pump bolted onto the perkins, and hydraulic motors for the blades, travel and carriage up/down?
Starting from scratch, either way holds its own promise, but the good folk on here might be able to share their experiences.
PS, I've searched pretty extensively, but couldn't find any info on a twin saw home build,
Regards
dan
Offline beenthere
Re: Planning on building a twin saw dimension mill, asking for advice
« Reply #1 on: December 17, 2012, 12:28:39 AM »
Welcome to the Forestry Forum.
Do you have a design sketch?
 Am sure that doing it yourself has its just rewards too, but it will be awhile coming.
Offline reride82
« Reply #2 on: December 17, 2012, 12:48:39 AM »
http://www.forestryforum.com/board/index.php/topic,41080.0.html
I don't know if he ever finished it, but this was a design I was following for a while before rebuilding my circle saw.
Levi
'Do it once, do it right'
'First we shape our buildings, then our buildings shape us'
Living life on the Continental Divide in Montana
Offline Dan K
« Reply #3 on: December 17, 2012, 01:02:54 AM »
Thanks for the link. I had something similar in mind, just on a larger scale. This home made contraption is what helped me decide to go down the twin saw road. .
I'm yet to have drawings done, I will after I decide on the blade drive method
Regards
dan
Offline Satamax
« Reply #4 on: December 17, 2012, 01:25:18 AM »
Dan, hydraulics, with the kind of power needed for a sawmill, are realy eficient, but need lots of flow and lots of cooling. I doubt you could do much with 51hp. Prety sure you have enough to drive the two saw with gearboxes and puleys tho. Being at the very limit with 12" and 12" imho.  If you want to check a bandmill which is all hydraulic, look at the loglogic autotrek. It gave me few ideas. Remember, i haven't built any mill yet.
HTH
Max.
French CD4 sawmill. Latil TL 73. Self moving hydraulic crane. Iveco daily 4x4 lwb.
Offline Dan K
« Reply #5 on: December 17, 2012, 03:28:59 PM »
Thanks for the reply Max. Whether the Perkins will drive a big enough pump is a pertinent question. 51hp will be more than adequate to drive both saws, going by the rule of thumb of 2-3 hp per tooth. Looks like I may have access to a 12v hydraulic unit, spools and hoses of a moblie lighting tower at the right price  ;D, so the jackshaft/gearbox style might be the go. Very much open to suggestions, but.
Regards
dan
New to FF Planning on building my own mill
Started by GAmillworker on Sawmills and Milling
Last post February 08, 2011, 03:04:56 AM
by customsawyer
Need help planning new mill building/yard
Started by Gabby on General Board
Last post December 14, 2005, 01:22:06 PM
by ksu_chainsaw
advice on building bandsaw mill ??
Started by buildthisfixthat on Sawmills and Milling
Last post July 27, 2011, 11:41:05 PM
by buildthisfixthat
Need advice on building a router sled for the mill
Started by kelLOGg on General Woodworking
Last post June 12, 2019, 04:06:52 PM
by Crusarius
