Author Topic: 4* blades  (Read 5420 times)
Offline ladylake
4* blades
« on: December 23, 2012, 04:05:32 PM »
 For those of you that won't or don't try 4* blades in tough to saw wood you should. Today again I put on a brand new 7* blade that I could watch cut up and down on the first and 2nd cut, took it off and put on a old Simonds sharpened down to less than 1-1/8 inch wide (10 plus sharpenings) that cut way better but was just a bit wavy on a big knot  in wide frozen white oak.  Took that same 7* blade, gave it a little more set and sharpened at 4* then it cut real straight untill it got dull. This is about the 5th time sharpening at less hook resulted in same although the other blades started a 10 *   Steve
Timberking B20 14000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline Shotgun
  • Location: Michigan - Lower Peninsula - East Central Area
Re: 4* blades
« Reply #1 on: December 23, 2012, 04:10:46 PM »
How about 4 blades?  In Windows, do "Alt 0176" on your numbers keypad to get the .
 :christmas:
Joined The Forestry Forum 5 days before 9/11.
Offline ladylake
Re: 4* blades
« Reply #2 on: December 23, 2012, 04:20:29 PM »
 Shotgun, your going to have to live with * here, alt0176 seems to do nothing here and it would be to much bother.   Steve
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: 4* blades
« Reply #3 on: December 23, 2012, 04:55:06 PM »
DanG, I just do it the simple way and click on the button just below the "C" on "Change Color" above.   ;D
Offline ladylake
Re: 4* blades
« Reply #4 on: December 23, 2012, 05:07:44 PM »
 I don't see that button either, I think we all know what* mean on here.  Steve
Offline ladylake
Re: 4* blades
« Reply #5 on: December 23, 2012, 05:08:39 PM »
 I don't see that button either, I think we all know what* mean on here and 4* works better in tough wood.  Steve
Offline taylorsmissbeehaven
Re: 4* blades
« Reply #6 on: December 23, 2012, 05:09:19 PM »
DanG I just bought some 7* blades to cut some old oak for a fella. Maybe I should have gone with 4s. We shall see next week. Always a day late and a dolla short, Oh well! Merry Christmas to all, Brian
Opportunity is missed by most because it shows up wearing bib overalls and looks like work.
Offline ladylake
Re: 4* blades
« Reply #7 on: December 23, 2012, 05:17:32 PM »
 Taylor,  your 38 years old try some 4* before you get much older.  I'd have thought a  7* would have cut better but they didn't.  These 7* blades have a real deep gullet, I've alway said gullet dept doen't mean anything.  Steve
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: 4* blades
« Reply #8 on: December 23, 2012, 05:24:52 PM »
4 is my go to for tough sawing. Tried to cut an old, clear maple last month, the 10 left a cut that looked like a roller coaster, the ReSharp 4 cut it perfectly.
Offline Chuck White
  • Sawing Mobile since 2005
Re: 4* blades
« Reply #9 on: December 23, 2012, 07:20:01 PM »
Steve;  Sometime you'll have to explain how you make adjustments on the Cats Claw to sharpen at different hook angles.
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline bandmiller2
Re: 4* blades
« Reply #10 on: December 23, 2012, 08:15:45 PM »
Chuck,I'am not steve or as smart as he, but my cats claw has a clamp behind the motor and socket head setscrew that fits in different tapped holes for different hook angles.Always good form to have a machinests protractor head and check the teeth.As the leading edge of the grinding wheel wears you will tend to get less hook. Frank C.
Offline Ohio_Bill
  • Wood is Good
Re: 4* blades
« Reply #11 on: December 23, 2012, 11:27:02 PM »
Steve, I agree with you on 4s.  Whenever I have a log that gives me trouble seems like the 4s work.  I just bought a box of 7s and have not tried them yet. I saw a lot of over ripe oak and hickory.
 :christmas:
Bill
USAF Veteran  C141 Loadmaster
LT 40 HDD42-RA   , Allis Chalmers I 500 Forklift , Allis Chalmers 840 Loader , International 4300 , Zetor 6245 Tractor Loader ,Bob Cat 763 , Riehl Steel Edger
Offline ND rancher
  • I'm Learning!
Re: 4* blades
« Reply #12 on: December 23, 2012, 11:37:43 PM »
Cut my first bur oak with a new ultra 10*. It didn't make it through a 9'x 20" log! Need to get some 4* before I try another.Any suggestions? Keith
TimberKing B-20.  Have been bitten by the bug! Loving life !
Offline 5quarter
    • Blue Harbor Refinishing
Re: 4* blades
« Reply #13 on: December 24, 2012, 01:45:14 AM »
ND...Bur Oak bark is very deep furrowed and holds dirt and grit like you wouldn't believe. that might have been more of a problem than the hook angle of your blade. Steve's right about less hook angle running better in frozen hardwood, but dirt will chew up teeth fairly quick regardless of of the degree of hook.
Offline barbender
Re: 4* blades
« Reply #14 on: December 24, 2012, 02:01:53 AM »
Dirt is bad. Frozen dirt is much worse. It doesn't take much to dull a blade.
Offline ladylake
Re: 4* blades
« Reply #15 on: December 24, 2012, 05:05:52 AM »
 For sure get some 4* , also check the downpressure the guide wheels are putting on the blade which is real important to cut straight. It should be 1/4", have the blade tensioned ,loosen the guide wheels so they're above the blade then measure from the blade to the bunk and lower the wheels untill they push it down 1/4". Make sure both sides are even to the bunk.  Also run the movable guide wheel in and out and make sure it stays even with the bunk, there are adjusters on the top of it .    Steve
Offline ladylake
Re: 4* blades
« Reply #16 on: December 24, 2012, 05:11:01 AM »
 The log I was cutting was clean but did have a lot of blown in dust but that 7* blade was up and down if the first 3 feet of the first cut.  When I cut those trees down my saws dulled up fast.   Steve
Offline bandmiller2
Re: 4* blades
« Reply #17 on: December 24, 2012, 07:39:09 AM »
Anyone here tried less than 4 degree hook.[notice how I got around that degree symbol thing] I must try less than four myself, if you sharpen you own no big deal a simple adjustment.Only real downside is will probibly require more power and a little harder to feed. Frank C.
Offline Chuck White
Re: 4* blades
« Reply #18 on: December 24, 2012, 07:49:11 AM »
Thanks for the info Frank!
Don't know why, but that info is not in my manual.
~Chuck~
Re: 4* blades
« Reply #19 on: December 24, 2012, 07:52:12 AM »
Your right Steve, I'll give em a try on my next blade order. You sound pretty happy with them. Brian
question
Bandsaw Blades - Who sends sample blades to try out?
Started by Ozarkian on Sawmills and Milling
Last post April 01, 2012, 06:50:08 PM
by Magicman
Band saw blades vs circle saw blades
Started by Arkyrick on Sawmills and Milling
Last post February 17, 2017, 07:55:52 AM
by longtime lurker
Peterson Blades, vs Lucas Blades
Started by Nate Surveyor on Sawmills and Milling
Last post May 07, 2007, 12:26:56 AM
by Firebass
question
Sharpening blades vs shipping blades
Started by Deese on Sawmills and Milling
Last post April 10, 2015, 07:39:09 AM
by Chuck White
