Arborwear
Author Topic: Stihl 362 air filter system  (Read 5868 times)
Offline CCC4
« on: January 11, 2013, 07:21:05 PM »
Anybody having trouble with the double air filter on the Stihl 362? I'm kind of upset with this system, Twice now I have cleaned the airfilter and found splinters had penetrated the outer filter...so many that it was ridiculous! They get stuck half way through the filter, looks like a porcupine. When the 2nd filter comes off there is tale tell sign that there is a problem with sealing and dust has gone into the intake. I clean this filter routinely, and always check how everything seals. I really don't understand why they had to make the switch to this filter. Why not put the K&N style filters like a 44 I had several years ago? Surely I am not the only person who is having this problem. Our Stihl dealer in town just sells the saws...not really any experts, plus I usually work past closing so I can't  call them. Thanks in advance for any insight to my problem. Heck, who knows...maybe I got a factory defective air filter???
Offline CCC4
Re: 362 air filter system
« Reply #1 on: January 12, 2013, 06:05:59 AM »
Well I'm glad it's just me...must be a totally isolated event.  ::)
Offline Timbercruiser
Re: Stihl 362 air filter system
« Reply #2 on: January 12, 2013, 07:08:13 PM »
I will check mine and let you know . Good question anyway
Offline snowstorm
« Reply #3 on: January 12, 2013, 07:24:00 PM »
havent had any trouble with mine. i just bought a 261 i like that what a screamer
Offline lumberjack48
  • 36 yrs ago, cutting Ash saw logs
« Reply #4 on: January 12, 2013, 07:26:59 PM »
If i had dust in the intake i would be very concerned, which you are. I know i couldn't run it knowing dirt was getting into the engine though the filter until i found the problem.
« Reply #5 on: January 13, 2013, 05:45:00 PM »
hey I checked my very new 362 stihl And your right it getting dust through the filter. Im not impressed one bit thats supposed to be a pro platform saw and with dust and dirt getting past is not good. I havent even wore one chain out and can see fine dust in the carb. Im going to get ahold of stihl ASAP
Offline Slab Slicer
  • Hungry to learn
« Reply #6 on: January 13, 2013, 06:09:28 PM »
I just got a 362 a few weeks ago. Haven't actually put it to a log just yet, but I'll be watching for this issue. Hopefully not. I'll keep checking back to see if theirs any more info.
2016 LT35HDG25, Kubota BX1500 w/FEL and custom skidding rig, Stihl MS362-25", Stihl MS250-20", Stihl MS192-18", Stihl MS180c-18". 2011 Toyota Tacoma, Ringo 12' trailer w/ folding rear gate, Iron & Oak 22 ton splitter.
Chuck
Offline CCC4
« Reply #7 on: January 13, 2013, 07:12:11 PM »
Thank you fellas for your replies! I will take a few pics 2moro and post them. I wish someone from Stihl would respond to this thread. The pics are going to show a failed air filter system and I wouldn't doubt somesort of a re-call is in need to fix the problem. The hood on the 362 is going to make it nearly impossible to just swap out the 361 air filter...I don't know really what can be done. Thanks again for your replies...be sure to check your intakes.
Online beenthere
« Reply #8 on: January 13, 2013, 07:26:09 PM »
Your Stihl dealer is your best bet for some attention from Stihl. He/she has a regional rep.
Doubt any Stihl reps are poking around the internet on Forums looking for problems to solve. ;)
I don't get to my Stihl dealer often but this is a good excuse to stop by for a visit. I'll see what he says.
Offline CCC4
« Reply #9 on: January 13, 2013, 07:56:50 PM »
Thanks beenthere!
Offline snowstorm
« Reply #10 on: January 14, 2013, 06:17:10 PM »
mine has 2 air filters inner and an outer. the inner is clean along with inside of the carb
Offline Slab Slicer
  • Hungry to learn
« Reply #11 on: February 03, 2017, 06:29:41 PM »
Digging this old one up. Was hoping there was an answer here. I'm in need of a new filter, and if there is something to replace this, and function better, it would be good to know.
Chuck
Offline kcward
« Reply #12 on: August 10, 2017, 01:40:04 AM »
Did you find a solution?  I just bought a used MS362 non m-tronic and it has the old style filter.  The new ones come with the HD filter (round one).  I looked in to changing over to that and it is possible.  Just need a few more parts...the back plate etc.  The dealer said it would be about $60 to change it over.
Offline Slab Slicer
  • Hungry to learn
« Reply #13 on: August 10, 2017, 04:58:17 AM »
I have not. Was waiting to hear something here.
Chuck
Offline Woodcutter_Mo
« Reply #14 on: August 10, 2017, 08:28:06 AM »
 We have an early 362 that does them same. The filter gets porcupined with splinters and I have seen alot of dust and debris get past the filter on this saw as well. To be honest, I'm not sure how it's lasted this long with this filter setup.
- WoodMizer LT25, Kohler, all manual, old "drag" style WoodMizer sharpener, cat claw single  setter
- Husqvarna 372XP X-Torque/24" bar, 455 Rancher X-Torque/20" bar, 550XP/20" bar, Stihl 024AV/18" Oregon speedcut
- Kioti DK45, '92 Dodge Cummins with Cannonball  bed, '07 Honda Rancher
Offline snowstorm
« Reply #15 on: August 10, 2017, 11:17:06 AM »
And you need the top covet
Offline joe_indi
  • The older I get the more I learn
« Reply #16 on: August 11, 2017, 12:11:04 AM »
CCC4
I would like to see the photo you mentioned
« Reply #17 on: August 12, 2017, 12:11:10 AM »
 Since the warranty is over with this saw I plan to make a few slight adjustments on this ms362 and I may get the HD filter setup to start with. Glad I seen this thread as I always wondered if the newer filter could be adapted to the early ms362's.  :)
Here's what I mean about this saw getting dust past the filter.
Offline Slab Slicer
  • Hungry to learn
« Reply #18 on: August 12, 2017, 07:24:45 AM »
Would like to see how this update/mod is done, and what you need.
Chuck
Offline joe_indi
« Reply #19 on: August 12, 2017, 11:46:46 AM »
Woodcutter_Mo
I'd like to see a picture of your filter
Stihl 064 Air filter cover and filter part numbers
Started by cottonwood1 on Chainsaws
Last post February 16, 2015, 03:21:51 AM
by ladnerlogging
question
Stihl ms 361pro air filter mod
Started by rightone1974 on Chainsaws
Last post January 25, 2016, 01:49:54 PM
by Magicman
Stihl air filter cover
Started by timberfaller390 on Chainsaws
Last post February 08, 2009, 01:28:10 PM
by Rockfarmer
Stihl 200t air filter
Started by brettl on Chainsaws
Last post December 06, 2013, 08:52:55 PM
by lone wolf
