Author Topic: Timber grading  (Read 1031 times)
Offline ljohnsaw
Timber grading
« on: January 17, 2013, 01:43:23 AM »
I need to understand the codes on the beam calculator.  When I look at the list of species to choose from, I see codes after the names: SS, B+S, and P+T.  I think SS is surfaced 2 sides, right?  What do the other two mean?  I understand the #1 and #2 (how many/where knots are located, bark areas, etc).  When you are using your own trees, what do you usually get out of pines, #1 for beams since you are pulling them from the center?
John Sawicky
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
Re: Timber grading
« Reply #1 on: January 17, 2013, 09:25:47 AM »
SS does not mean surfaced two sides that's S2S
SS means structural select.
B+S means Beams and stringers.
P+T means posts and timbers.
The difference between B+S, and P+T is two inches.
What I mean is if a timber is an 8x8 it's in the P+T category. If a timber is 8x10 it's also in the P+T category. But as soon as the second dimension goes to more than 2" then it is assumed that the timber will be used as a beam (example an 8x11). So it's in the B+S category.
Beams mean the timber is horizontal. There is no such thing as a vertical beam.
Stringers as you all know are the pieces of lumber that hold up stair treads. And they must be strong or the stairs will fail. Rafters are also in the "stringer" family.
Timbers that are in the P+T category have lower grade rules due to the fact that most of them could be used as Posts. And wood is strong in compression. Knots in compression don't fail, usually.
But, knots in beam can be a problem if they are big. When we look at pieces of wood to be used as beams we always look for "crown" the sweep in the piece from end to end. And we put the crown up so that gravity, and the load on the beam will push it down, towards being straight. If it was crowned down and then the load is applied the bow would be even more. This would make a very un-even, un-level floor system.
Also, when we are inspecting beams that are fairly straight, no crown, we look at the size and location of the knots. And roll the beam over so that the knots are near the top surface of the beam. Knots are strong in compression. But weak in tension. The lower side of the beam would be in tension. The upper side would be in compression.
Some where in between these two "zones" of the beam is the area known as the "neutral axis" where there is neither compression or tension. It would be best if the joints/mortises could be cut in the neutral axis area. As these would not effect the strength of the piece.
I hope that helps you to understand which values to use when you select your values in the calculators.
Jim Rogers
If not keep asking questions.
Offline WindyAcres
Re: Timber grading
« Reply #2 on: January 18, 2013, 07:29:23 PM »
Quote
Cool, I did not think about that, good point, thx.
Just use common sense, get nice trees for your beams + overbuild, then you dont have to worry about things..  :)
2011 Woodmizer Lt40 Hyd G28, Stihl Chainsaws, Tractor with Farmi Winch, Woodturning Lathe,....
Offline canopy
Re: Timber grading
« Reply #3 on: January 18, 2013, 08:05:05 PM »
No matter how much overbuild I think it is still good practice to be in the habit of carefully inspecting each member individually, optimizing knots, crown, and other attributes to allow each to perform at its absolute best.
Offline Jim_Rogers
  • Board Moderator
    • jrsawmill.com
Re: Timber grading
« Reply #4 on: January 19, 2013, 08:36:40 AM »
Well said.....
Timber grading?
Started by scgargoyle on Timber Framing/Log construction
Last post January 04, 2008, 05:43:03 PM
by Don P
Timber Grading
Started by Scott G on Sawmills and Milling
Last post January 23, 2007, 04:46:14 PM
by Don P
Grading timber in MA
Started by ex-Engineer Wannabe on Timber Framing/Log construction
Last post October 21, 2005, 07:03:36 PM
Timber Grading course by TFG
Started by rjwoelk on Timber Framing/Log construction
Last post August 30, 2019, 06:49:38 PM
by Don P
