Author Topic: "Embossing" a product.  (Read 1029 times)
Online Dave Shepard
  • Geometrically proportional
    • My homepage
« on: January 26, 2013, 08:14:02 PM »
For lack of a better term. I've put down hardwood flooring that had the manufacturers name stamped on the bottom. It wasn't in ink, but actually cut into the wood. I was wondering if anybody knew anything about the process. Thanks.
Offline GeneWengert-WoodDoc
Re: "Embossing" a product.
« Reply #1 on: January 27, 2013, 12:11:47 AM »
It is done with a metal stamp on a wheel.  With heat, it works better.
Offline Cypressstump
  • I'm not so new now!
« Reply #2 on: January 29, 2013, 02:59:02 PM »
I have seen custom made ones that use your design, they build a 'stamp' with handle. Can get them heated or not, the electrically heated ones burn into the wood very nicely.
Stump
Timberking 1220 25hp w/extensions -hard mounted
Case 586E 6k forklift
2001 F350 4X4,Arctic Cat 500 4 wheeler wagon hauler
Makita 6401 34",4800 Echo 20"er, and a professional 18" Poulan PRO , gotta be a 'pro' cuz it says so rite there on tha' saw..
« Reply #3 on: January 29, 2013, 04:38:24 PM »
If you do not get the stamp (also called a die) too hot (maybe 250 F max.), then the wood will not burn, but may get a little brownish in color.
Online Dave Shepard
    • My homepage
« Reply #4 on: January 29, 2013, 05:35:37 PM »
What I'm thinking of is more like what WoodDoc is talking about, a stamp on some sort of roller. I was just wondering if it was a stand alone thing, or mounted somewhere inside a moulder.
« Reply #5 on: January 29, 2013, 05:38:52 PM »
Mounted near the molding machine outlet.
Online Dave Shepard
    • My homepage
« Reply #6 on: January 29, 2013, 05:45:33 PM »
Any idea who makes them? I have a product I'd like to put a name or web address on. Thanks.
Offline pep
  • Lucas Owner
« Reply #7 on: January 31, 2013, 07:28:31 AM »
Dave
  Check out Lee Valley Tools.  You can have a custom stamp made for around 200.00
Cheers
Pep
Lucas 827 w/slabbing bar
JD 410B
Wood Wiz Surfacing Attachment
