Author Topic: Wanted a glass wood stove door  (Read 3895 times)
Offline muddstopper
« on: February 10, 2013, 01:51:29 PM »
I have a buddy that heats his shop with a barrel stove. Its several years old and he is wanting to build a new one. The doors on those volgezand stove kits are really to small if you have large splits to put in. He is wanting to find a glass stove door to use for his new stove. I have searched for stove doors, but all the barrel kits seem to be solid doors. Does anybody know where I can get a glass door that might fit on the end of a barrel stove.
Offline Local4Fitter
Re: Wanted a glass wood stove door
« Reply #1 on: February 10, 2013, 05:57:27 PM »
Never owned a barrel stove, but seems that the doors that they come with are mounted on a frame already. If your friend finds a glass door he will probably have to make a frame to mount it to so it will seal properly. Also he would have to customize the draft control because I think that is in the door too.
1974 John Deere 510, Wood fired pizza oven,2005 Dodge/Cummins,Firearms for all occasions.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #2 on: February 10, 2013, 08:13:02 PM »
After replacing glass in a couple different stove doors I had a piece of steel cut the size of the glass and didn't worry about it anymore  ;D :)
Offline Corley5
    • Whittaker Farms
« Reply #3 on: February 10, 2013, 08:15:12 PM »
Combustion air should flow over the glass from the top to keep it clean.  If the draft is below it the glass will always be black anyway :)
Offline muddstopper
« Reply #4 on: February 10, 2013, 08:43:35 PM »
My friend is a retired boilermaker, He's 68yo now, but I am sure he can still fab up a frame to fit a door if we can find one.
Offline Corley5
    • Whittaker Farms
« Reply #5 on: February 10, 2013, 08:45:28 PM »
If he can fab the frame he might as well fab the door too  :)
Offline muddstopper
« Reply #6 on: February 10, 2013, 09:37:09 PM »
Where do you get the glass that goes in the door?
Offline Mooseherder
« Reply #7 on: February 10, 2013, 10:16:26 PM »
It's been a few years but I had replaced a Stove door glass from a company that was online.
Just sent in my measurements and they cut it to fit.  Installation into the frame wasn't hard.
I don't remember the name of the company but there are probably many to choose from.  Google Wood Stove glass.
There has to be a company that sells the frame also.
The draft on our stove is at the bottom of the glass and it gets black after cleaning on the first burn.
You'd think that the stove designer might have known about that. ::)
Lane Circle Mill
Homemade Bandmill
Offline Corley5
    • Whittaker Farms
« Reply #8 on: February 11, 2013, 09:44:15 AM »
I got mine from a local glass supply place.
Online Hilltop366
« Reply #9 on: February 11, 2013, 09:57:30 AM »
Anyone know if the inner glass on a electric or gas kitchen stove (range) and a wood stove are the same? If they were the same it would be a cheap source if someone was throwing one out.
I do know they are both expensive.
Offline Yoopersaw
« Reply #10 on: February 11, 2013, 10:51:32 AM »
X2 on this.  It can be done with some fabricating; but, probably not worth the effort.
Offline Handymark
« Reply #11 on: February 13, 2013, 07:41:50 PM »
I saw a sign at a local glass shop recently stating they do replacement glass for fireplaces and wood stoves. That would be my first phone call.
Offline muddstopper
« Reply #12 on: February 14, 2013, 11:43:32 AM »
Lots of good suggestions. Thanks you all. I think my buddy has gone off on a different tangent for now, doesnt know what hes going to do. I guess when he finally makes up his mine, at least I will know where to start looking.
Offline 36 coupe
« Reply #13 on: March 06, 2013, 06:30:19 AM »
A Pyrex pie plate or baking dish would work.Open flames in a wooden box make me nervous.Cant understand why people want glass doors in a stove.Most get broken by a bit of ice brought in from outdoor wood piles.
wood burning stove glass
Started by tstex on General Board
Last post January 10, 2010, 09:53:24 PM
by tstex
out door wood stove
Started by beav39 on General Board
Last post March 04, 2008, 08:08:40 PM
by head block
King Wood Stove. Need Door.
Started by Striker911 on Firewood and Wood Heating
Last post September 23, 2011, 09:31:16 AM
by doghunter
skid steer glass door
Started by sully on Forestry and Logging
Last post January 29, 2015, 08:59:21 AM
by Offthebeatenpath
