Arborwear
Author Topic: Keeping glue and finishes from freezing  (Read 723 times)
Offline hackberry jake
« on: February 13, 2013, 01:21:05 PM »
I have lost a few $ worth of products over the years simply because I forgot to bring my finishes inside. I use something in the summertime and put it in a shelf in the shop when I'm done. Winter time comes around and I forget it's there and it freezes and is no good anymore. Do they make the opposite of a refrigerator? Something that will keep the inside temp above 50 or so? I was going to glue up some white oak this morning and it said glue must be above 45 degrees. It was right at 45 so I postponed the glue up til a later date. I could probably make something myself I suppose. Just an insulated cabinet with a thermostat controlled electric heater inside, but would feel better about fire safety if it was a premade unit. Do such things exist?
Offline Lefty1981
Re: Keeping glue and finishes from freezing
« Reply #1 on: February 13, 2013, 02:05:25 PM »
Use an old refrigerator with a light bulb left on inside.
Offline isawlogs
  • A smile is contagious ... Start an epidemic
« Reply #2 on: February 13, 2013, 02:28:44 PM »
Lefty1981 beat me to it,  :D
 Find an old fridge  gut it outof its compressor, redo the insulation and make some shelving that  will hold what you plan on storing in it and put a 40 watt light bulb in there that will stay lit and heat the inside. If the insulation is real good ya might get away with a 25 watt bulb.
   Marcel
« Reply #3 on: February 13, 2013, 03:06:52 PM »
You guys are geniuses! I've heard of that for pump houses. I don't know why I didn't think of that!
Offline LeeB
« Reply #4 on: February 15, 2013, 08:02:42 AM »
works good for welding rods too.
Offline sbishop
« Reply #5 on: February 15, 2013, 09:54:41 AM »
Great idea, i ran into sorta the same kind of issue...but mine involved curing meat. I have a fridge in my garage but the outside temps were in the -25c range a few weeks ago....things were getting too cold so put a 60w bulb in the fridge and left the door opened just a bit...temps were around 3-4c...perfect!
Offline LeeB
« Reply #6 on: February 15, 2013, 11:22:50 AM »
I must assume that Mr. Bishop is talking in degrees celcius.
Offline isawlogs
« Reply #7 on: February 15, 2013, 01:02:08 PM »
-25c range  3-4c...perfect!
Lee, I am sure the little "c" after the numbers is giving that away  ;D  :D
   Marcel
Offline jamesamd
« Reply #8 on: February 16, 2013, 04:36:33 PM »
Put them in an igloo cooler
All that is gold does not glitter,not all those that wander are lost.....
Can you use calking glue to glue logs together?
Started by Rod on Timber Framing/Log construction
Last post February 28, 2005, 10:45:59 AM
by Rod
erc finishes
Started by fishman on General Woodworking
Last post October 23, 2007, 08:59:42 PM
by Haytrader
question
finishes
Started by wheelinguy on General Woodworking
Last post January 23, 2012, 05:09:33 PM
by tcsmpsi
Timber finishes
Started by Matt Trav on Timber Framing/Log construction
Last post July 29, 2009, 09:39:39 PM
by witterbound
