Author Topic: Radical lean  (Read 1400 times)
Offline travelr64
  • We ain't even begun to fight yet ! ! !
Radical lean
« on: April 07, 2004, 09:42:42 PM »
I have some large ash trees to drop.  Some of them are multi-trunked, and leaning very radically.  How do you guys cut your notch on a tree like that?  I'm afraid the lean of the trunks might pinch the bar even starting the notch.  Am I wrong?
Or should I just go ahead and make the felling cut and let them fall over without a notch?
As you can tell, I'm new here and a bit green when it comes to cutting timber.
Thanks in advance for the help.  Great Site, and obviously tons of knowledge here ! ! !
Coop
""Now look what you've gotten us into ! ! !
Offline Ianab
Re: Radical lean
« Reply #1 on: April 07, 2004, 10:37:58 PM »
Hi Travelr
Have a look at these threads about plunge cutting, that seems the safest way to fell leaning trees, more control and less chance of barberchair splitting. Think you should allways make a notch, even if you reduce depth of it Very unlikely that it will close as 90% of the trunk is still intact. I have had it happen to me, but that was in a cypress tree that had about a 70 deg lean, should be OK with any sensible looking tree ::)
http://www.forestryforum.com/cgi-bin/board/YaBB.pl?board=Business;action=display;num=1076772988;start=0
http://www.forestryforum.com/cgi-bin/board/YaBB.pl?board=chainsaws;action=display;num=1080350803;start=40
Best to practise on some user friendly small trees before you go tackling the big ugly ones though
ian
Offline oldsaw-addict
Re: Radical lean
« Reply #2 on: April 07, 2004, 10:39:45 PM »
Whats the diameter of the trees? Also how many degrees are the tree trunks growing at?  If they're growing on a 45degree angle I think the best thing to do is simply cut em from the top without a notch.
Let there be saws for all mankind!
Offline redpowerd
Re: Radical lean
« Reply #3 on: April 07, 2004, 10:49:32 PM »
i grab them as low as i can go, if the trunk aint low enough, take stems out individually untill comfy
NO FARMERS -- NO FOOD
northern adirondak yankee farmer
Offline Kevin
Re: Radical lean
« Reply #4 on: April 08, 2004, 05:22:28 AM »
Welcome Coop.
You can't cut those with a normal notch and back cut because the tension wood on the back side is likely to cause the tree to split out and barberchair.
On a guess without seeing it I would think the best way to handle it would be to isolate each stem and remove them separately.
As always, if you aren't sure get someone in that's experienced to help.
Offline Hunter
  • Dolmar/ Efco/Redmax/ Silvey Grinder Sales
Re: Radical lean
« Reply #5 on: April 08, 2004, 06:01:06 AM »
I think Kevin gave some great advise. Make sure you dont get yourself in a dangerous situation.
The leaning trees can be tricky and unpredicatable at times.
Hunter
Jmccomas@insight.rr.com
614-554-2169
Dolmar / Efco / Redmax / Silvey Grinders Sales
Offline travelr64
Re: Radical lean
« Reply #6 on: April 08, 2004, 07:59:08 PM »
Well, I got a couple of the bad leaners down today.  Not much trouble there. Just cut a shallow notch on the bottom side, then made my felling cut and they came down fine.  They do tend to be a little tough to limb though.  I guess I need to get the winch I've had for seven years out of the box and start using it.  It'd be a lot easier to limb and buck these big trees if I winched 'em off of the hinge over on the side that had the least limbs on it.
Thanks for all the tips.  That helped a lot.  I did bore one  tree that I couldn't get behind very well.  Never considered doing it that way until gettin' that idea this morning from one of the replies.
Thanks again
Coop
lean seize
Started by bandmiller2 on Chainsaws
Last post August 15, 2015, 04:36:24 PM
by lumberjack48
353 seems to be running lean
Started by hydro2 on Chainsaws
Last post September 04, 2005, 11:06:48 AM
by hydro2
How to attach lean to
Started by stanwelch on Timber Framing/Log construction
Last post March 02, 2018, 10:14:38 PM
by Don P
MS460 to lean
Started by clyde on Chainsaws
Last post October 03, 2005, 10:01:45 AM
by clyde
