Author Topic: Buyers Gang exclusive ...  (Read 6443 times)
Offline psychotic1
  • Earth First   We'll log the other planets later
Re: Buyers Gang exclusive ...
« Reply #20 on: January 21, 2002, 07:48:45 PM »
 :P So... I want and outside top plate of 10o.  And you put a 10o inside top plate on your RA with your grinder, but I have to pretty much stick with 45o because I am as of yet hand filing..  Yes?
If... I say IF I've got it right. what advantage does the 10o inside top plate give you over 45?  Would it be worth my while to buy a grinder -depending on how much sharpening I'll actually be doing.
My handy-dandy file guide also lets me tilt the file horizontally so I'm filing at a somewhat up or down angle.  I don't see a description of this angle in my tutorial.  Should I forget that angle even exists?
Thank you so much for explaining this stuff.  I can't get anything out of the dealer here in town.  I don't think he knows anything.  He keeps going back to his computer and asking what I'm going to be using my saw for. ::)
Patience, hell.  I'm gonna kill something
Offline Kevin
« Reply #21 on: January 22, 2002, 04:08:32 AM »
Bruce, you can forget the 45o angle because it`s on the inside of the top plate, you`ll get that angle automatically with the file.
Your top plate should have somewhere between 10-15o and you tilt the file on chisel chain to give you a 10o side plate hook.
1  raker height.
2  tilt file for 10o side plate hook on round ground chisel chain or tilt the vise on a grinder.
3 10-15o top plate angle.
4  your file will give you this angle, on a grinder you need to tilt the head.
Marathon gang sash gang saws
Started by Ron baker on Sawmills and Milling
Last post August 14, 2013, 08:44:35 PM
by Ron baker
TIE BUYERS
Started by dail_h on Sawmills and Milling
Last post June 08, 2005, 07:56:27 PM
by smwwoody
Log Buyers
Started by Rob on Ask The Forester
Last post February 05, 2003, 02:38:37 PM
by Rob
tie buyers in ky
Started by bigred1951 on Sawmills and Milling
Last post June 06, 2014, 05:55:42 PM
by bigred1951
