Author Topic: Cleats for end splits  (Read 1984 times)
Offline Seaman
  • Still learning as hard as I can go.
    • Uniquewoodcuts.com
« on: April 05, 2013, 07:35:01 AM »
I really do appreciate all the help and advice here.
I know I have seen a couple different cleats to keep boards from end splitting further. I have seen an S like you see in RR Ties, and a staple on steroids.. I just cannot find them for sale.
Lots of the Logs I slab have been down a long time and have some pretty good checks already. I am thinking the cleats would help a lot while drying the slabs.
Thanks, Frank
Lucas dedicated slabber
Woodmizer LT40HD
John Deere 5310 W/ FEL
Semper Fi
Offline thecfarm
Re: Cleats for end splits
« Reply #1 on: April 05, 2013, 07:39:26 AM »
Also have plastic one. I think I've seen them in the Timberline magazine. I don't have one at this time.
Offline Jay C. White Cloud
  • semper fidelis
    • Online business card
« Reply #2 on: April 05, 2013, 08:25:41 AM »
Hi Frank,
If you are unsuccessful, I will track a source down for you, but we stopped buying them a decade ago.  Now we just end seal and if it is slab stock use a good wire nail and cleat with a length of board.  You can even tack on some of the stickers to aid in this process, especially near the pith slabs.
Regards,
jay
Offline PC-Urban-Sawyer
  • Been wasting time for sixty-eight years...
« Reply #3 on: April 07, 2013, 11:08:05 PM »
Offline GeneWengert-WoodDoc
« Reply #4 on: April 08, 2013, 12:20:32 AM »
End splits caused by the ends drying faster than the rest of the lumber can be best controlled by using an end coating.
Splits caused by stress in the tree (growth stress) can be somewhat controlled by mechanical restraints, but not coatings.  Mechanical restraints loosen as the wood dries.  uC Coatings does sell plastic restraints that work well, but the stress is still in the wood, so after drying, warp can be expected if pieces are sawn, planed, etc.
  • semper fidelis
« Reply #5 on: April 08, 2013, 12:31:51 AM »
Hi Frank,
Gene's advice is a great breakdown of how to think about it.  If I am working with big slabs I want the following.
Slow down dry as much as possible to release stress evenly and slowly.
What stresses can't (won't) be release must be controlled (arrested.)
The cleating method I described earlier has done the best for me over the years, unless I want the checking for an esthetic effect.  Often it is better to let certain woods, (I have some very big and naughty elm slabs at the moment) do what they want to do, and then butter fly the boards and make the checks part of the design.  They can be left open or filled with epoxies, and/or wood, stone, bone, or other infill methods.  Did one that was filled with turquoise and abalone chips for a client in new mexico that came out rather nice.
Regards,
jay
Offline Seaman
« Reply #6 on: April 08, 2013, 07:33:42 AM »
Thank you Jay and Gene, I always learn a lot from your post.
Yes , most of the checks I have are from stress, as in when the center slab just trys to seperate on you, some can't be helped.
 I have had a couple pop in two as soon as they are ripped, kinda cool to listen to a big piece of locust pull itself apart!
Woodmizer LT40HD
Semper Fi
  • semper fidelis
« Reply #7 on: April 08, 2013, 09:40:30 AM »
Quote
Keep them together, they can still be made into one slab.  In some cases, you can't even tell they came apart. Just remember to put some kind of identifying marks on them so you don't loose track of their orientation.
Offline Seaman
« Reply #8 on: April 09, 2013, 06:56:59 AM »
Rodger that!
Woodmizer LT40HD
Semper Fi
« Reply #9 on: April 10, 2013, 10:53:51 AM »
Here is a bit more--probably more than you need or want to know, but...
Growth stress is common in most tress, but at a low level.  Plantation Southern pine and red pine has a lot along with yellow-poplar at times and sweet gum in the U.S.
Years ago, before many of the readers here were born, many hardwood sawmills would have a "busting saw."  This saw would rip wide lumber down the center, thereby relieving some of the stress.  However, the growth stress in a tree, log of resulting lumber is distributed throughout the stem of hardwoods,  So, a piece of lumber with stress in the green, even if ripped, will still have quite a bit of stress when dry and remanufactured into a smaller product.  Such stress can causing manufacturing issues, like warp or open glue joints.
There is some research literature about steaming stressed lumber PRIOR to drying to relieve the stresses, but the results were not very effective.
The tie plates used on the end of RR ties (looks like a big gang nail plate) are quite effective for controlling end splits, especially splits that might develop after treating.  There is a patent for putting a piece of plywood on the end of tie to control growth stress splits too.  As ties are not remanufactured, the residual stress does not cause an issue if the pith is centered (also called heart centered).  This centering keeps the stresses balanced and minimizes warp.
When you see large end splits in a log, you know you have growth stresses and so if you do not keep the rings centered within the lumber, side bend is likely.
Offline Seaman
« Reply #10 on: April 14, 2013, 07:55:06 AM »
Slabbed a nice Ambrosia (sp?) maple this week, the two center slab (3in) split as soon as the saw came out.
 I'm thinking of tacking  a strip onto the end grain of the slab before cutting thru, and leaving it on thru the drying process, put in butter-flys, then plane, then take off strip.
Sound logical? or is there a reason this won't work.?
Thanks, Frank
Woodmizer LT40HD
Semper Fi
Offline giant splinter
  • Pacific Northwest
« Reply #11 on: April 14, 2013, 10:45:05 AM »
Frank,
The staple on steroids you spoke of is called a 'gang nail" you can buy them at Home Depot or Lowes in the framing hardware section. Gang nails are common on truss fabrication and a slightly heavier version is found on railroad ties as well.
Although these fasteners work very well, the advice by The Wood Doc and JC is sound and will work going in, the heavy gang nails used on R/R ties are added after the milling and treating of the ties and do help a great deal with controlling the stability.
roll with it
« Reply #12 on: April 15, 2013, 12:40:26 AM »
For hardwood RR ties, the green tie comes into the treating yard with extra length on it.  The tie is then cut to length, giving fresh ends, and the gang nail plate, called a tie end plate and probably other names too, is put onto the end of the tie before treating.  The typical tie end plate will have 250 "nails" and covers the tie end nearly 100%.  I have seen at least 50% of the ties with such plates.  The wood then air dries and some small cracks develop as the wood shrinks.  It is hoped that when the tie is then treated, that the treatment chemical will get into the splits and a bit further.  Also, it is hoped that the tie end will not split anymore...if it did split further, then untreated wood could be exposed (although the treatment does go pretty deep into the tie).
Such a treatment process works well, as most ties are replaced due to mechanical wear or damage, and not because of decay.
Boot cleats
Started by Jim_Rogers on Health and Safety
Last post February 15, 2019, 05:33:59 PM
by sprucebunny
Clamping Cleats on the Sawbunks
Started by Rougespear on Sawmills and Milling
Last post May 30, 2016, 04:48:57 PM
by Magicman
End Splits on HIckory
Started by Kirk_Allen on Drying and Processing
Last post March 02, 2005, 01:51:28 PM
by Tom
Price per Unit splits - Western NC
Started by westernnc on Ask The Forester
Last post August 14, 2011, 08:46:14 PM
by Ron Scott
