Making a Saw Handle
Started by Dodgy Loner, April 10, 2013, 09:47:03 AM
Dodgy Loner
I have a few saw plates that need handles, and I decided to get started on one last weekend. I figured I would snap a few pictures as I went along in case anyone else out there has orphaned saw plates in need of a cozy handle.
The saw in question started out life as a Disston No. 7 (1896-1917) 8 PPI crosscut that I found in my shop about a year after moving in. It was a well-loved saw and had been filed down to a knife point. The handle was completely busted and only a few tattered remnants were left. I decided to turn it into a panel saw (any saw less than 26" is considered a panel small) with rip filing. I started by cleaning up and straightening the plate, and I cut 4" off the end to get the toe to a reasonable width.
I started off with a rough billet of split beech. It has been drying for about 2 years. Maybe not dry enough for a plane, but plenty dry for a saw handle.
I sawed it to length, then hewed one side flat so I could process it safely on the bandsaw-
I took off a quartersawn slice a little thicker than I wanted-
And then planed it to thickness. I'm not sure what the thickness is, I just set my calipers to the thickness of my most comfortable saw handle and used that dimension as my target.
To ensure that the saw had the right look and dimensions, I used a template that I printed from a
friend's website. I will be modifying the template to suit my preferences, but I know that this one will fit my hand comfortably and will be in proper proportion to this smaller saw plate.
For me, the trickiest part of making a saw handle has been getting the curves inside the handle to look and feel right, so that's where I started. I bored the holes on a drill press-
And cut out the rest with a coping saw-
Leaving the extra length on either end for this part really helped with the work holding – I was able to clamp the blank any way I needed to into all the tricky angles. I used a variety of files and rasps, but one nice discovery was finding out that my chip-carving knife absolutely excelled at reaching some spots that no rasp could touch.
Once I was satisfied with the inside shape, I went ahead and bored all of the outside holes. You can see where I've changed a few details from the original pattern. I drew a straight line at the bottom of the handle to make it a London-pattern handle. This is an older type of handle that dates to the 18th century.  I also changed the front of the handle where it meets the saw plate give it more of an 18th century look.
Then I cut the rear shape of handle on the bandsaw. Once again, leaving the extra length at the front of the blank really helped me shape the back side. The front is a very quick and simple job compared to shaping the part where your hand actually grasps the saw, so I saved that for last.
And when I was satisfied with the shaping of the back of the handle, I cut the profile on the front.
Then it was time to cut the slot for the blade. When I was trying to determine how deep the cut should be, I realized that the heel of the saw plate would be at the wrong angle for this handle. So I scribed a more appropriate angle onto the plate and cut it off with a cheapo tile saw (a tile saw makes quick work of spring steel).
Then filed off the bur-
I marked out the cut with a marking gauge, and cut it with a tenon saw (The tenon saw in the picture is the recipient of my first attempt at handle-making, from about 3 years ago. I'm not happy with the result, but it's not bad enough to replace...)
The saw plate fits just right.
After cutting the slot for the blade, I gave the front of the saw handle some contour and refined the lamb's tongue detail at the bottom of the cheeks. And now it's ready for saw nuts. I will probably do a little more shaping to the saw plate to give the heel a little more curve, but that will have to wait until I'm finished with the handle.
I made the saw nuts out of some random brass stock that I found in the plumbing department at a local hardware store. I didn't take many pictures of that process, but it would really deserve a thread unto itself. Hopefully if you are making a saw handle, you will have the original nuts that came with the saw. That makes things a lot easier. Here is the plate with the nuts installed. They still need to be filed flush with the wood, but the end is in sight.
Tim Lea
That is nice.. Got one I need to do thanks for shareing..
JohnM
 smiley_clapping
Very nice!
Lucas 830 w/ slabber; Kubota L3710; Wallenstein logging winch; Split-fire splitter; Stihl 036; Jonsered 2150
clww
That was a great tutorial!  :)
Many Stihl Saws-16"-60"
18-Wheeler Driver
Jay C. White Cloud
 smiley_clapping
I second that motion, thanks for sharing that processes with everyone!  Awesome work, very nice detailing.
These saws have really taken a life of thier own with you. Enjoy yourself. You are bringing those old saws back to life.
LeeB
Really beautiful handle. You do such nice work. I've never worked with beech and know nothing about it. Would it be better to use an interlocked grain wood like hickory or elm to avoid breakage at the weak spots?
purple otter
      Great job again,Dodgy . You have given me some inspiration for some saw plates I have that are in need of handles. Your friends website is cool too! Thanks for sharing.
Hudson Oscar 228 on homebuilt trailer, Kubota B2320 with homebuilt forks,Stihl 028 Super & 029 Super, Solar Kiln .
Holmes
Think like a farmer.
Dodgy Loner
Quote from: LeeB on April 10, 2013, 06:07:37 PM
Thanks, Lee! I think elm and hickory would make beautiful handles, though I don't know that they would be more durable than beech. Beech has a long history of use for saw handles (as well as for many other tools, such as mallets and plane bodies). For over 200 years, it was the most common wood used for saw handles, and since the handle I made is a traditional form, I wanted to use the traditional wood. Beech actually has grain that is pretty well interlocked, and it was quite a chore to split the log that I used! A lot of modern sawmakers use all kinds of non-traditional woods for their saws, like curly maple, black walnut, cherry, and all sorts of exotics. Apple also has a long history of use for saw handles, but it didn't become popular until after "London pattern" saw handles had fallen out of popularity.
LeeB
As I said, I don't know anything about beech, but if it has an interlocked grain, I see why it would be used.
I split ALOT of beech growing up with a sledgehammer and iron wedges. That beech is not the type to open up easy with just a splitting maul. I would not want to leave the saw outside too many rainy nights,gets dozzy real quick,like white birch.
