Baltic Abrasives Technologies
Author Topic: sawing 3to 4in diameter cedar  (Read 645 times)
Offline fivedogs
« on: April 12, 2013, 08:21:35 PM »
I had a guy  call me the other  day wanting to know if i could saw cedar poles in half  they are about 3 to 4 inches in diameter  the only way i can think of  is to sandwhich them between two  4x4's  to get a grip
i worry about twist out
any one else have any ideas ?
  thanks fivedogs
Offline mesquite buckeye
  • Trees are good- even ones with stickers
Re: sawing 3to 4in diameter cedar
« Reply #1 on: April 12, 2013, 08:26:12 PM »
And maybe put a tapered board underneath to compensate for log taper.
Offline Cedarman
    • Cedarusa
« Reply #2 on: April 12, 2013, 09:26:03 PM »
Take a 2x6 with the 2" part being the width of the rail.  Cut a V notch in the 2x and bolt a couple small boards to the base so the 2x6 will sit on the cross rail and not fall off.  Make 2 of these.  Now you can place the pole in the V notches.  If you need height adjustment at one end or the other, place shims under the appropriate 2x6.
Have a helper push down on the far end of the log holding it in the V.  As you saw down the log, place your hand on the log with down pressure and have the helper get out of the way.  You can quickly saw logs in half this way.  We have done many hundreds without incident.
Offline fivedogs
« Reply #3 on: April 12, 2013, 11:12:33 PM »
Thanks for the advice  i will try both ideas  this coming weekend
 thanks  fivedogs
Log diameter for quarter sawing, species
Started by climber2 on Sawmills and Milling
Last post February 13, 2018, 01:34:06 PM
by Ianab
moved
MOVED: timber framing peg diameter vs peg hole diameter
Started by chet on Forestry and Logging
Last post February 08, 2018, 09:17:07 AM
by chet
Started by metroplexchl on Timber Framing/Log construction
Last post February 09, 2018, 11:38:41 AM
by Heartwood
Sawing pattern for 14" to 20" diameter hardwood logs
Started by WoodenHead on Sawmills and Milling
Last post May 21, 2014, 05:45:46 AM
by WoodenHead
