Author Topic: Chainsaw mill chains  (Read 1422 times)
Offline farmhand
  • Workin hard and getin nuting dun!!!
« on: April 23, 2004, 06:04:32 AM »
Hey, you guys running chainsaw mills, what have you found to be the best chain?
WITH GOD ALL THINGS ARE POSSIBLE!!!!!!!!
Offline Danny_S
Re: Chainsaw mill chains
« Reply #1 on: April 23, 2004, 09:32:12 AM »
I dont know if it is the best but oregon 73RD works well. That is all that I have used so far. What kind of saw are you using for milling?
Plasma cutting at Craig Manufacturing
Offline Danny_S
« Reply #2 on: April 23, 2004, 07:49:22 PM »
Offline farmhand
« Reply #3 on: April 24, 2004, 05:37:28 AM »
I'm running a Logosol M-7 with a husky 395xp.  The prices from Logosol are killing me.
Offline Kevin
« Reply #4 on: April 24, 2004, 06:49:35 AM »
I like a factory 3/8 pitch full skip ripping chain.
Offline Shamus
  • Another day in paradise...
« Reply #5 on: April 24, 2004, 02:00:14 PM »
Kevin, do you find full skip to be much faster than full comp? Does it make much difference in the roughness of the board surface? I use Oregon 3/8 square full comp, and have been experimenting with filing angles of 0-10, but not sure which is best, so many variables involved. There must be a 'best' filing angle for hardwoods vs softwoods, even each species. Any thoughts here?
D&L Doublecut Synchro sawmill, Procut chainsaw mill, John Deere crawler loader,  F350 4x4 flatdeck, 20 ton logsplitter, running Stihls
Offline Kevin
« Reply #6 on: April 24, 2004, 02:58:16 PM »
When milling wood that your bar is buried in, full skip is better.
As far as angles I stick with a 10o top plate.
Stihl RS is 35o, it cuts well but leaves a rough finish.
Chainsaw mill chains.. your preference?
Started by Danny_S on Sawmills and Milling
Last post November 28, 2003, 05:51:45 PM
by fencerowphil (Phil L.)
Chainsaw chains
Started by Woodhauler on For Sale
Last post November 21, 2011, 08:18:58 PM
by Cut4fun
WoodlandPro Chainsaw Chains
Started by luvmexfood on Chainsaws
Last post October 02, 2016, 09:55:47 PM
by LAZERDAN
chainsaw milling chains
Started by mnbowler on Sawmills and Milling
Last post March 02, 2015, 07:37:22 PM
by richhiway
