Author Topic: Suffolk dual tooth setter  (Read 1490 times)
Offline barbender
« on: May 24, 2013, 11:04:45 AM »
Does anyone have experience with the suffolk dual tooth setter? I was looking at some used ones for reasonable money, but I know nothing about them.
Offline vt k-9
Re: Suffolk dual tooth setter
« Reply #1 on: May 24, 2013, 01:04:01 PM »
 I own one and I recommend it.  I have used it for 11 yrs  with no problems at all. It's easy to use and it is very accurate.
will
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
« Reply #2 on: May 24, 2013, 01:51:03 PM »
 What blades are you using it on ? Some blades are pretty stiff to set the teeth ?
Offline barbender
« Reply #3 on: May 24, 2013, 02:04:22 PM »
WM doublehards and silvertips, .045 and soon .055. I thought I read they were finicky to set up or adjust. I'll have to do a search. Vt-k9, what blades are you using yours on?
Offline 1938farmall
  • Uff-da
« Reply #4 on: May 24, 2013, 04:20:24 PM »
i have this setter & it works well.  suffolk suggests leaving .160" of tooth above the anvil to get a consistent set.  i set after i grind, fwiw.  ag
aka oldnorskie
Offline slider
  • sawyer,trucker,tree service
« Reply #5 on: May 25, 2013, 07:23:47 AM »
I have had one for years and it"s been a great tool .If yours does not come with dial indicators I would suggest picking up a hand held one.Cooks has them.
al glenn
Offline barbender
« Reply #6 on: May 25, 2013, 12:26:15 PM »
A couple more questions- Would these set .055 blades ok, and would $500 be a decent price for a used one in good shape? I couldn't find the price of the new ones on Suffolk's web site.
Suffolk Setter(Dual tooth semi auto)
Started by Percy on Sawmills and Milling
Last post September 29, 2003, 12:33:37 AM
by Percy
recycled
Suffolk Dual Tooth Setter no longer for sale
Started by xphys1 on For Sale
Last post April 03, 2014, 11:07:03 PM
by sawmillhand
Still looking for a used dual tooth setter
Started by flatrock58 on Wanted
Last post April 05, 2019, 11:21:29 AM
by Woodpecker52
Dual tooth band setter
Started by pasbuild on Norwood Sawmills USA Inc.
Last post February 16, 2018, 03:46:35 PM
by Mike@Norwood
