Author Topic: Been reading and looking for info on cutting logs into lumber .  (Read 4696 times)
Offline ST Ranch
  • Outside of a horse is good for the inside of man
Re: Been reading and looking for info on cutting logs into lumber .
« Reply #20 on: June 03, 2013, 11:32:52 AM »
RBQ - I mill a lot of spruce [engleman spruce] that grows naturally on my ranch. About 75% of the time the logs and lumber work out fine - the more open grown one [usually lots of limbs and often twist from blowing in the wind] and ones that grow on the edge of a clump or edge of an opening [this is usually a result of uneven growth rings on the branchy side of the tree], cause me trouble.
I usually only cut a 8 - 10 foot butt log to reduce twist issues. From second and third cut logs I can get nice 12 -16 footers and the top log I usually cut into a small cant [4x4 for posts or dun age]
I find it best to mill when freshly logged. Partially dry is tough to mill, sawdust sort of sticky and stringy, and if log is quite dry, knots are hard and can cause blade to dip.
Lumber from the dry logs is usually more stable and less likely to warp.
The other trick for the green saw lumber is lots of stickers [every 2 feet] and an even foundation to stack on [ make sure the bottom foundation stickers are a 2 feet too].
Big issue is to have good sharp blades, I have a debarker and I only get 5 - 600 BF of cutting when logs are dry [10 - 20 inch dia logs], but 1000 BF + with green logs.
Good luck
LT40G28 with mods,  Komatsu D37E crawler,
873 Bobcat with CWS log grapple,
Offline rasorbackQ
« Reply #21 on: June 06, 2013, 07:41:20 PM »
--Photos MUST be in the Forestry Forum gallery!!!!!--.com/user/rasorbackq/media/HPIM3061_zps616021ba.jpg.html[/img]
Thanks for reading, Steven
Offline bandmiller2
« Reply #22 on: June 10, 2013, 07:27:14 AM »
Putter miller is not taking the bait on this one. Frank C.
Offline rasorbackQ
« Reply #23 on: June 14, 2013, 06:29:39 PM »
Offline rasorbackQ
« Reply #24 on: June 14, 2013, 06:34:29 PM »
How does one attach a pic to a post
Offline rasorbackQ
« Reply #25 on: June 14, 2013, 06:52:14 PM »
Offline rasorbackQ
« Reply #26 on: June 14, 2013, 06:54:23 PM »
Cutting big oak logs into quartersawn lumber
Started by flatrock58 on Sawmills and Milling
Last post November 25, 2014, 07:45:35 PM
by drobertson
Some general questions on cutting dimensional lumber and really big logs.
Started by opticsguy on Sawmills and Milling
Last post March 12, 2012, 08:53:10 AM
by Al_Smith
Cutting beams and lumber with a Haddon lumber maker.
Started by richhiway on Sawmills and Milling
Last post April 29, 2014, 05:02:35 PM
by richhiway
I need some info on cutting
Started by KjBarnwood on Sawmills and Milling
Last post July 09, 2008, 08:46:49 AM
by KjBarnwood
