Author Topic: Belsaw?  (Read 810 times)
Offline nk14zp
Belsaw?
« on: June 22, 2013, 07:22:16 PM »
I may be getting a Belsaw and the owner said it has good wood just needs to be bolted together.  My question is should I paint or coat the wood with something or not?
Belsaw 36/18 duplex mill.
Belsaw 802 edger.
http://belsawsawmills.freeforums.org/
Offline bandmiller2
Re: Belsaw?
« Reply #1 on: June 22, 2013, 09:05:46 PM »
Depends what color you want your mill. Myself I used oil base stain with creasote where the wood overlaps.Probibly deck coating they sell to preserve decks would be as good as any. Frank C.
Offline nk14zp
Re: Belsaw?
« Reply #2 on: June 23, 2013, 11:12:51 AM »
I don't care about looks.  Just wondering about rot prevention between the overlaps.
Belsaw 802 edger.
Offline beenthere
Re: Belsaw?
« Reply #3 on: June 23, 2013, 01:03:16 PM »
If the water can get in between the overlaps, then you can expect the wood to decay. So whatever you can do to prevent it (cover, roof, or ?? ) will help the longevity of the wood.
If not possible to cover, then some annual or bi-annual flushing of the joints and wood with a preservative will help.
Belsaw m14
Started by Mark K on Sawmills and Milling
Last post June 11, 2012, 03:45:43 PM
by Mark K
New Belsaw
Started by loggah on Sawmills and Milling
Last post May 26, 2014, 08:08:12 PM
by sawdust joe
Old Belsaw
Started by Corley5 on Sawmills and Milling
Last post January 07, 2007, 08:44:00 AM
by snowman
Need some help with Belsaw
Started by Farmer_17 on Sawmills and Milling
Last post April 01, 2012, 06:01:48 PM
by apm
