Author Topic: sweet gum ???  (Read 3449 times)
Offline Po-Jo
  • "Life is hard: its harder if you're stupid" John W
sweet gum ???
« on: June 30, 2013, 02:05:20 PM »
i want to ask you guys with the experience, Is a sweet gum worth cutting < B-I-L is clear cutting some property and the excavator is in there digging stumps and knocking down trees the timber company did not want and there is a sweet gum tree laid down right now and not in a burn pile YET, B-I-L said take it if i want it, but i need to get it PDQ before it finds its  way in a pile, Its about 30" diameter straight as an arrow and about 60' of good cutting , what would you guys do cut or take a pass on it? thanks for any info
Offline xlogger
Re: sweet gum ???
« Reply #1 on: June 30, 2013, 02:26:28 PM »
I have no use for sweetgum, I know a few here have saw some up before.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: sweet gum ???
« Reply #2 on: June 30, 2013, 02:50:17 PM »
Sweet Gum makes some of the best Barn Siding I've experienced.
When dried....its as hard as a rock. When I use it, I saw it green and get it up.
I built a shed using SG for siding. I was prepared in the way as I sawed 20 boards, I would stop and install the boards to the shed.
I used rink shank nails to keep the boards from drawing away from the shed as the boards dried. Screws can be used also.
I also use my shed as a sales point that SG came be used.
Google Sweet Furniture. Its beautiful. getting it to dry without a twist is the trick. I've never built furniture from it but they say it takes a green SG board 1 1/2" thick just to get a dried 3/4" board out of it because of the twisting.
Offline ladylake
Re: sweet gum ???
« Reply #3 on: June 30, 2013, 02:59:45 PM »
 No sweetgum around here but sure sounds a lot like cottonwood or Elm , both like to twist.  Siding  sounds like a good use for it put up green. I use Elm and cottonwood for outrigger board on semi trailers as it doesn't spilt , with enough weight most dry fairly straight.   Steve
Timberking B20 14000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline pineywoods
Re: sweet gum ???
« Reply #4 on: June 30, 2013, 03:26:47 PM »
po jo, grab that sweet gum log and quarter saw it. Stack and sticker with weights on top. It's slow to dry, but once dry, it's quite stable. Makes nice furniture. Sweetgum has spiral grain, and flat sawn, it WILL twist and warp. Fresh cut, it mills nicely..
Offline drobertson
Re: sweet gum ???
« Reply #5 on: June 30, 2013, 05:09:37 PM »
+1
Offline fat olde elf
  • Growing old is not for sissies - Betty Davis
Re: sweet gum ???
« Reply #6 on: June 30, 2013, 05:40:45 PM »
Where is Magic Man ?
Cook's MP-32 saw, MF-35, Several Husky Saws, Too Many Woodworking Tools, 4 PU's, Kind Wife.
Offline beenthere
Re: sweet gum ???
« Reply #7 on: June 30, 2013, 06:05:49 PM »
Quote
He said it was cabin time, for a week. ;)
Offline clww
  • Oh yeah? Watch this!
Re: sweet gum ???
« Reply #8 on: June 30, 2013, 06:22:24 PM »
Quote
Jeff banned him when he reached "15,000 Posts"! ban_smiley :D
Many Stihl Saws-16"-60"
18-Wheeler Driver for Knight
Offline Po-Jo
Re: sweet gum ???
« Reply #9 on: June 30, 2013, 07:16:22 PM »
so what would be the best thickness to saw it? quarter sawn and or used for siding? thanks again for the insight
Online customsawyer
    • The Custom Sawyer
Re: sweet gum ???
« Reply #10 on: June 30, 2013, 07:21:39 PM »
I have used it for flooring on lowboy trailers. When it is dry it don't get as brittle as oak. It won't last as long but it seems to have a little give to it when the back-hoe is between the cross members. Put it down green.
Two LT70s and to much other support equipment to mention.
www.thecustomsawyer.com
Offline drobertson
Re: sweet gum ???
« Reply #11 on: June 30, 2013, 08:15:56 PM »
another+1 on trailor decking. david
Online WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: sweet gum ???
« Reply #12 on: June 30, 2013, 08:29:58 PM »
I would definitely NOT flat saw it.  Like Piney says, quartersaw it.  It does not like to behave in wide glued panels or tabletops.  However, it would make very nice wainscott or paneling where each board is free to move as in V-goove or tongue in groove.
Offline sealark37
Re: sweet gum ???
« Reply #13 on: July 01, 2013, 12:02:59 PM »
Heavy equipment mechanics and haulers prefer sweetgum for blocking.
Offline Po-Jo
Re: sweet gum ???
« Reply #14 on: July 01, 2013, 10:09:34 PM »
well after the 3.5" of rain yesterday afternoon, I caught the guy in the excavator early this morning and had him move that tree closer to the road and out of that swamp mud hole from the ran, it was so muddy even that excavator had to work some to get it moved to the road,
Had a buddy with 30 yrs in the logging business back when they were cutting big stuff out of the swamps with chainsaws here to help/ school me on some proper bucking, this thing had that massive root ball on it and that kept the  base a good 5' off the ground due to the root ball, i looked at it and said to myself man i need to get some help on this and not kill myself trying to buck it, my buddy came over and made look easy, tho i know he had the experience from years of cutting , he took the top out first then did 3  10' section , weird they were partial cuts not fully thru and he said watch this, when he cut the final cut near the root ball , all the cuts open up and set that thing down nice and easy, i could not or have ever thought of cutting that way but he has the experience, glad i called him,
Then we dragged that thing out of the mud and got them moved to house and 2 of them loaded up on the log deck, then it began to rain again, will have to go out in the morning and put the anchor seal on the end, I didnt think the anchor seal would stay on in the pouring rain being its water clean up,  so after all was said and done i got 3 10' long logs running in the 32" diameter range,,, for me these things are huge and gonna be a lot of work to cut, and test myself and machine, hopefully i can get to start cutting on my next weekend,
Online WDH
Re: sweet gum ???
« Reply #15 on: July 01, 2013, 10:24:10 PM »
I am looking forward to this adventure.
Offline grweldon
    • Just Stuff! (my personal blog)
Re: sweet gum ???
« Reply #16 on: July 02, 2013, 07:51:39 AM »
Pictures please!
Timberking 1400, Ford 3910 Tractor, John Deere 350B Crawler/Loader
Online WDH
Re: sweet gum ???
« Reply #17 on: July 02, 2013, 07:56:42 AM »
If the heartwood is figured, like it sometimes is, there will be some spectacular color.  It will have a striped effect on the quartersawn face.
Offline dboyt
  • Log On!
Re: sweet gum ???
« Reply #18 on: July 02, 2013, 08:57:32 AM »
I don't care what it is, if someone offers me a 60' log in the 32" dia class, I'm not turning it down.  Sweetgum can be some really pretty wood, if you can keep it straight.  If you are milling for trailer decking, find out what thickness they want before you start cutting.  Glad you're going for it, looking forward to photos.
Offline Po-Jo
Re: sweet gum ???
« Reply #19 on: July 02, 2013, 09:48:15 AM »
This is 2 of the SG logs on the deck they make that red oak that i have on the mill look small, gonna be be interesting trying to cut these things, gonna have to wash these down when it comes time to.especially after.dragging them thru the mud and sand, i am already wishing i had your guys nicer rigs especially those with hydraulics on them,  :)
Sweet Gum
Started by Randy on Sawmills and Milling
Last post January 29, 2005, 09:28:07 PM
by doublecutusa
Does anyone saw sweet gum?
Started by LaneC on Sawmills and Milling
Last post November 18, 2014, 04:02:07 PM
by Okrafarmer
sweet gum /Red gum
Started by Joey Grimes on Sawmills and Milling
Last post October 11, 2016, 07:27:16 AM
by WDH
smiley
How Sweet It Is !!!!
Started by DR_Buck on General Woodworking
Last post June 22, 2010, 11:48:14 AM
by OneWithWood
