Author Topic: Sawing my first 21 foot beams.  (Read 4209 times)
Offline Quebecnewf
Re: Sawing my first 21 foot beams.
« Reply #40 on: August 10, 2018, 05:47:57 AM »
I did 2 beams of 25 ft X 8x8 on my mill . Mill is only designed for 16' . . I did my four cuts to get my 8x8 square. Cutting of the slabs with chain saw each time. I then moved the log back wards on the mill to get to tha last 9 ft round section . I placed 2" blocking on the bunks . This lifted the squared section up 2" and made sure the round uncut section was not touching the bunks. I then tapped a small wedge under the uncut end to take out any droop . Then made the last four cuts . Good to go . In theory  I could cut any length using this method . I have hatches on each end of my mill shed that let me pull long logs in through one end and out through the other .
Quebecnewf
Offline Andries
  • Making buildings out of big curvy logs
« Reply #41 on: August 12, 2018, 11:18:10 PM »
Where there's a will - there's a way.
I surprised though, Quebecnewf - you found logs that were 12" at the small end of a 25 footer, in your part of Canada ?
Those trees must've been hiding from the logger for many decades!
8)
LT30G24
Ford 545 Series loaders
Stihl chainsaws
Sawing Prices over 12 foot.
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post April 30, 2016, 07:28:43 AM
by warren46
sawing 25 foot logs
Started by gdingee on Sawmills and Milling
Last post July 02, 2009, 01:40:12 AM
by Brucer
sawing by the foot prices
Started by beav39 on Sawmills and Milling
Last post June 15, 2008, 12:23:54 AM
by Ironwood
$1.14 Per-Board-Foot Sawing Charge
Started by DR_Buck on Sawmills and Milling
Last post May 16, 2011, 08:41:07 AM
by paul case
