Author Topic: Flame Tempering of wood  (Read 11925 times)
Offline Spruce_Goose
  • wood is good
« on: August 08, 2013, 08:58:15 PM »
Hi all.
Is anyone here familiar with the term or process of 'flame tempering' wood. This would be used in such applications as archery bows, tool handles, bats, etc. It is supposed to make it stronger, but I'm not sure exactly why or how it is best done (torch, open flame, coals, etc.)
I am familiar with the concept of kiln drying strengthening wood through the extreme dryness it causes (dry wood = stronger wood). And I am also familiar with the concept of wood becoming more supple through high heat (often applied through steam). I am guessing flame tempering is working off one or both of those concepts. (supple wood being beneficial for certain items because it will bend further before breaking). I also have read that flame tempering may affect the cell structure, causing it to be tighter...
Online beenthere
Re: Flame Tempering of wood
« Reply #1 on: August 08, 2013, 09:32:20 PM »
A flame would darken the color of the wood, and may give the "perception" that the wood is stronger.
Often, "perception" sells and is a good marketing gimick.
Just my opinion on it.
Offline longtime lurker
« Reply #2 on: August 12, 2013, 03:12:10 AM »
The process is called fire hardening.
There is no "perception" about it, it's a process that humans have used for thousands of years... as in since the stone age... to case harden things like spear and arrow points. Basicly it achieves hardening by two means... one is that the wood dries which obviously makes it stronger. The other is that the mix of oleoresins released from the wood mixed with charcoal that forms on the surface can be polished to a sharper edge then straight timber alone.
Offline Ianab
« Reply #3 on: August 12, 2013, 03:34:54 AM »
Like Longtime says....
From Wikipedia
Quote
Fire hardening, also known as "fire-polishing", is the process of removing moisture from wood, changing its structure and material properties, by slowly and lightly charring it over a fire. This makes a point, like that of a spear, or an edge, like that of a knife, more durable.
Pre-historic weaponmakers would rub the end of a selected wood pole against a smooth rock surface until a point was achieved. Then the point was heated in a fire, making sure to thrust the point into the coals. This put a light coating of carbon on the surface, which was then polished with a special stone, which ground fine particles of stone into the pitch which had been brought to the surface of the wood by the fire. Subsequent firings and polishings of the wooden tip of the spear would eventually form a hardened glaze consisting of pitch, wood particles and carbon on the tip which could eventually be even harder than a copper tip. This kind of primitive technology was available to primitive humans for at least 400,000 years, long before flint or stone points were used.
It was done by native cultures like the Australian Aborigines, Polynesians etc that might not have had access to flint or metals to make spears. I bet Bear Gryls has done an episode on it at some point, and eaten whatever he was able to spear  :D
Offline 5quarter
    • Blue Harbor Refinishing
« Reply #4 on: August 18, 2013, 12:31:43 AM »
there was a type of Shillelagh made by the Irish peasantry that was made from the root and trunk of a blackthorn tree. they would sharpen the ends of the root projections and then harden them in fire. It was rumoured that a well made Shillelagh could pierce plate armour. seems unlikely, but I wouldn't want to test it... ;)
Offline GeneWengert-WoodDoc
« Reply #5 on: August 18, 2013, 01:24:16 PM »
When the western US was being surveyed--early to mid 1850s--, to mark the survey corners, they used an eastern hardwood species (a species that was not found in the West) stake that was buried and that had been well toasted in a fire.  This toasting insured that the wood would not decay.  I can recall even in 1960 that some of these stakes were found and, due to their legal importance, we were asked to I.D. them for species.
Offline LeeB
« Reply #6 on: August 18, 2013, 10:23:26 PM »
Well?
Offline Jemclimber
« Reply #7 on: August 29, 2013, 09:42:01 AM »
Yes Doc, we want to know the species? Please?
lt15
Offline hackberry jake
« Reply #8 on: September 06, 2013, 10:18:40 PM »
Locust?
Offline redprospector
« Reply #9 on: September 07, 2013, 02:51:14 AM »
Fire hardening is no joke!
I've got a job that I have to get back on that was burnt in the Scott Able fire in 2000. The land owner wants all the burnt snags, and blow downs mulched. I looked the job over pretty good, but being human I guess I was a little lazy and only sounded the down trees toward the bottom of the canyon. After 13 years they seemed to all be pretty rotten. Well, surprise, surprise. As I worked my way up the hill the logs, and snags got more & more solid, at least the SW White Pine. Some of this stuff is close to being petrified. I've changed my strategy on this project, and am going to skid the hard stuff and haul it to my place (for firewood I guess). I'll mulch everything that is soft enough.
Andy
« Reply #10 on: September 07, 2013, 01:13:04 PM »
The surveyor could select the species.  Some of them included cherry, hickory, walnut and locust...it depended on what species were native to the area they were surveying.
At times they also used living trees as reference points, giving the species, but after 100 more years, these trees often were gone, but an old stump might have still been there and so we did some ID work on these stumps too.
Hi flame Shetland wood stove
Started by Jerryok1971 on Firewood and Wood Heating
Last post December 15, 2017, 09:44:23 AM
by Weekend_Sawyer
odd flame
Started by r.man on Firewood and Wood Heating
Last post December 28, 2013, 10:19:07 AM
by jhellwig
flame coming from exhaust
Started by levi on Chainsaws
Last post November 24, 2010, 02:11:08 PM
by sharkey
Solved: Flame Azalea
Started by Don P on Tree, Plant and Wood I.D.
Last post June 06, 2002, 09:11:27 PM
by Don P
