Author Topic: 24x24 cabin material list  (Read 33046 times)
Offline bigred1951
  • logging and sawmilling
« on: August 11, 2013, 07:58:34 PM »
well hopefully you guys can help me out. Im wanting to start building a 24x24 foot cabin but i need some help on figuring out how much lumber i would need. I know for the floors i want to use either 2x8s or 2x10s depending. Of course 2x4s for the framing and i figured 2x6s for the rafters. I figure everything at 16 inches apart and its gonna be open inside just one big room. But hopefully one of you guys can chime in and give me some advice or would know how much lumber i would need so i wont buy to much or to little.
Offline Planman1954
Re: 24x24 cabin material list
« Reply #1 on: August 11, 2013, 08:16:50 PM »
Have you thought about roof trusses? At a 24' span, you'll need 2x12's...pricey! You might want to go 20'x26' or something to cut down on the size of ceiling joists.
2x8x16" on center would work fine for the floors with a center beam support for the floor. 2x4x16" oc walls, and 2x6x16" oc rafters would be fine. (Down here, we typically space them 2x6x24" oc...but don't have many snow days to worry about.
Norwood Lumbermate 2000 / Solar Dry Kiln /1943 Ford 9n tractor
Offline beenthere
« Reply #2 on: August 11, 2013, 08:29:50 PM »
br
Cathedral ceiling?
On a foundation, over a crawl space?
Inside finish? paneling or drywall?
Insulation?
Roofing?  metal, or shingle
Sheathing?
Offline bigred1951
« Reply #3 on: August 11, 2013, 09:04:57 PM »
Im not sure about the trusses i know that i dont want to go out and buy some premaid I want to do it all my self. I tryed to figure up how many 2x8s i would need for the floor and i got around 38 to do the floor but i figure 40 just to make sure.
Offline bigred1951
« Reply #4 on: August 11, 2013, 09:11:41 PM »
no just a regular plain ceiling haha. In a way im building it like a shed but gonna make it a cabin. I planned to either put post in the ground as a foundation to build on or block the corners up and so on but not a couple block all the way around. As far as the inside im going back and forth between paneling or drywall and ive even thought about both as like a drywall on top of the walls with wood paneling on the bottom. Insulation is a yes and roofing id like metal but would consider shingle just depends on what i can get at a better deal. And as sheating im guessing you mean like house wrap and suck and yes i plan to put up plywood on the outside the wrap it all then either board and batten or lap siding
Offline bigred1951
« Reply #5 on: August 11, 2013, 09:19:41 PM »
now that i think of it a cathedral ceiling would be really nice but it would depend on how much more money and work it would cost to do it
Offline beenthere
« Reply #6 on: August 11, 2013, 09:28:11 PM »
This room is 24 x 30, with cathedral ceiling (added on to our home) 12 yrs ago.
Online Hilltop366
« Reply #7 on: August 11, 2013, 10:48:41 PM »
For 16" oc studs I usually get 1 per foot. You will need to know your window and door size to get the correct header size. ( don't forget to add 2x the stud thickness + rso to the header length)
Offline WmFritz
« Reply #8 on: August 11, 2013, 11:17:25 PM »
That "room"  is the size of a small house! Very nice. I'm guessing about 1000sf of cedar on that ceiling.
~Bill
2012 Homebuilt Bandmill
1959 Detroit built Ferguson TO35
Offline beenthere
« Reply #9 on: August 12, 2013, 12:01:55 AM »
Real close on the sq ft, and it allowed some high grading to remove some defect such as large knots, and edge splits of tongues and/or grooves.
Went up pre-oiled and random length.
We call it the "great room" for more reasons than one. ;)
Offline grweldon
    • Just Stuff! (my personal blog)
« Reply #10 on: August 12, 2013, 08:56:36 AM »
Very pretty room Beenthere!  Did you use scissors trusses or are those 2x rafters?
BTW, what is your first name if you don't mind me asking...
Timberking 1400, Ford 3910 Tractor, John Deere 350B Crawler/Loader
Offline beenthere
« Reply #11 on: August 12, 2013, 10:24:34 AM »
Quote
2x12's on 24" centers
Offline grweldon
« Reply #12 on: August 12, 2013, 11:13:16 AM »
Thanks... great picture, and I guess you DO mind me asking your first name!
Offline WmFritz
« Reply #13 on: August 12, 2013, 11:52:40 AM »
I did my cabin roof similar with the lam beam. Instead of 2x12 lumber, I used TGI floor joist for rafters.
~Bill
Offline beenthere
« Reply #14 on: August 12, 2013, 12:55:12 PM »
gr
Just been or bt will work too.  ;)
Or, you can call me Bob.
Offline grweldon
« Reply #15 on: August 12, 2013, 01:20:24 PM »
BT... gotch...
Fritz... I've built a 16' wide shed-type addition with a vaulted ceiling with 11.25" deep wood I-beams as well.  With the overhang, they ended up being 22' long.  A bunch lighter and cheaper than 2x12x24' lumber (can you get them that long?).  They worked very well on 24" centers.  We only have a few PSF snow load in Alabama.  You could go to 16" or 12" spacing for a northern snow load...
Offline WmFritz
« Reply #16 on: August 12, 2013, 02:36:15 PM »
GR... 2x12x24' can be bought at a regular lumber yard. Not sure about HD or Lowes.  Mine are 24" centers as well. With the 12/12 pitch and metal roof I went with, snow only builds up about 3" and slides off.
~Bill
Offline WmFritz
« Reply #17 on: August 12, 2013, 04:52:01 PM »
Bigred, more details are needed on your building plan. I'm wondering about your foundation. Are you thinking about a crawlspace and using 2x8's for joists? Off the top of my head, I'm thinking you would need at least two beams to span 24'. are you setting your joists on posts like a deck?
~Bill
Offline LaserZX
« Reply #18 on: August 12, 2013, 06:26:29 PM »
I like that truss design    Any chance to see a more up close pic  and or detail info  thanks
Quote
Offline beenthere
« Reply #19 on: August 12, 2013, 08:05:28 PM »
LaserZX
Design in my house?
They are just 2x12 rafters that sit on the ridge beam and the walls, 7:12 pitch.
I can rustle up more detail if that is what you'd like. A plywood gusset on the rafters at the peak and birdsmouth on the wall plate. The ridge beam is 24" deep, of three 1 3/4" lam ply's.
best guess on how long to cut material list
Started by dablack on Sawmills and Milling
Last post September 19, 2013, 06:22:23 PM
by Chuck White
VT solar kiln material list accuracy
Started by Ogopogo on Drying and Processing
Last post August 26, 2018, 07:35:22 AM
by GeneWengert-WoodDoc
clip
24x24 Workshop
Started by Khaameleon on Timber Framing/Log construction
Last post February 26, 2016, 01:23:02 AM
by witterbound
roof design for a 24x24 garage
Started by KyleHilmer on Timber Framing/Log construction
Last post February 08, 2017, 05:30:49 PM
by Brad_bb
