Author Topic: Home made slabber  (Read 3896 times)
Online Sixacresand
  • John and Nancy
Home made slabber
« on: August 15, 2013, 05:47:06 PM »
Has anyone on the Forum ever built a slabber using a long bar and a small engine other than a chainsaw engine?  I bought a new 3 ft bar at a sale a few years ago and have a couple 5 and 6 hp engines.  I was thinking I could have a jack shaft machined to fit the clutch/sprocket and put all this together to make a slabber.
Offline AdkStihl
    • J.Miller Photography
Re: Home made slabber
« Reply #1 on: August 16, 2013, 02:20:32 PM »
I'll bet its been done before.
No reason why it cant be done again.
Should be fairly straight forward.
Clutch mechanism?
Offline Cut4fun
« Reply #2 on: August 16, 2013, 02:32:33 PM »
I showed a video of a homemade one on my chainsaw repair site awhile back. I dont know what was powering it but had to be bigger.
Offline Ianab
« Reply #3 on: August 16, 2013, 02:45:51 PM »
No reason you can't make it work.
Have a look at the Peterson and Lucas dedicated slabbers. They generally have a larger bar and motor (5ft cut and 16-20+ hp) but a 3ft bar would need proportionally less to drive it.  As you say, run a jack shaft and size your pulleys to get the chain speed the same with the lower revving 4 stroke. Rig up an oil bottle, gravity feed seems to work. A centrifugal clutch for safety and ease of starting, and you should have a practical mill.
Online ladylake
« Reply #4 on: August 16, 2013, 06:12:41 PM »
 Good idea but I'd run more than 6 hp, find a used 20-25 hp  vertical shaft lawn mower motor, should be cheap.   Steve
Timberking B20 14000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Online Sixacresand
  • John and Nancy
« Reply #5 on: August 17, 2013, 09:41:17 AM »
Thanks for the replies.  I see it can be done.  I will keep the forum posted on my progress.
Offline lowpolyjoe
  • Hey
    • JeRM Software Page... Hobby projects
« Reply #6 on: August 19, 2013, 11:35:33 AM »
I would love to see some details if you go forward.
Good luck
Offline Hilltop366
« Reply #7 on: August 19, 2013, 12:09:05 PM »
A jack shaft with a harvester sprocket and a belt clutch would do the trick, The sprockets are available with different round bore sizes with a keyway. The chainsaw mill I had made used a 16 hp, less would work with proper gearing. Of course if I was making another things would be different.
Offline maple flats
  • Life is what you make it!
« Reply #8 on: August 31, 2013, 08:01:12 AM »
6HP would be pitifully under powered on a 3' bar. A chainsaw in 6HP is  running far more feet/minute (FPM) than you could run ever gear a 6 HP 4 cycle motor to pull a chain. You should really have 15 HP minimum, and over 20 is suggested. I think  6hp would just stall as soon as the chain hit the log.
You could build a slabber but a chain should not be geared too slow to cut. A small engine would need to be geared pitifully slow.
logging small time for years but just learning how,  2012 36 HP Mahindra tractor, 3point log arch, 8000# class excavator, lifts 2500# and sets logs on mill precisely where needed,  Peterson ATS upgraded to WPF mill, maple syrup a hobby that consumes my time. looking to learn blacksmithing.
Offline fuzzybear
« Reply #9 on: August 31, 2013, 08:27:12 AM »
11 hp Honda motor with direct drive to the chain will cut through a 26" dry spruce with little effort. I've never run the engine down or stalled it with everything I've put it through.
   When I built mine I had no budget, so it started as a direct drive. When I found that it worked fine I left it.  It would be nice to have the chain spinning faster, but I have smoother boards than a friend that runs the same style head frame but with a 2100 husky.
   If you are running it as a manual feed it will be slow and hard work, no where near as hard as an Alaskan Mill, but harder than a band mill. You are removing 1/4" of material with every pass so your recovery will be far less.
   The nice thing is you are only limited to the track you have.  I used v-groove wheels on the head and run these on old bed frame rails.  I have enough that I could cut up to 48' at the current time.
FB
I never met a tree I didn't like!!
Home built slabber
Started by flip on Sawmills and Milling
Last post October 12, 2018, 09:52:54 PM
by Kssawguy
issues with the electric clutch on the home built slabber
Started by shelbycharger400 on Sawmills and Milling
Last post March 31, 2012, 12:00:13 AM
by shelbycharger400
Made it home
Started by WV Sawmiller on General Board
Last post September 21, 2018, 10:41:47 PM
by Don P
made it home
Started by Wife on Sawmills and Milling
Last post October 29, 2004, 01:28:20 AM
by TN_man
