Author Topic: Replacing B57's  (Read 992 times)
Offline AdamT
Replacing B57's
« on: August 21, 2013, 10:53:47 AM »
How many hours are you averaging between replacing your B57's, or if you use a different belt on your mill?
What are some signs of them needing replacing?
Thanks!
2017 Wood-Mizer LT40HDD35-RA
2011 Wood-Mizer LT40 HD
It's better to have it and not need it then it is to need it and not have it
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: Replacing B57's
« Reply #1 on: August 21, 2013, 11:31:17 AM »
Adam, I have a little over 800 hours on my LT40. I just put new belts on mine.
However I did have to put new bels on at 203 hours due to a blade breaking and chewing the belts up.
Personally I think its an inspection thing. Keep them clean and watch for the rubber peeling on the edges or other wear.  They should give you long service.
If you travel, keep an extra belt or 2 for emergencies.
I saved my old belts just in case I need them to get by one day. You never know.
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: Replacing B57's
« Reply #2 on: August 21, 2013, 12:14:50 PM »
Signs? Cuts and bands almost touching metal wheels.  Keeping them clean and rotating them should keep them evenly worn and pretty flat.
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide, 2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker),  Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline Bibbyman
    • Warden Sawmill
Re: Replacing B57's
« Reply #3 on: August 21, 2013, 01:22:17 PM »
Worn out.  Blade running on wheel.
New belt installed.
I've tested a number of belts for Wood-Mizer and none lived longer or worked better than the Goodyear belts special made for Wood-Mizer.
Sawing since '94
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Replacing B57's
« Reply #4 on: August 21, 2013, 01:40:29 PM »
I have never had a belt to wear out or flatten because they are cut by blades breaking long before that.  I guess that I get a couple of years out of them.
Offline pineywoods
Re: Replacing B57's
« Reply #5 on: August 21, 2013, 04:02:24 PM »
I see no need to change them until the blade's about to touch the steel wheel. I'm with Bibby, the goodyears made for woodmizer will outlast anything I have found. Cheap belts are no bargain...
Offline AdamT
Re: Replacing B57's
« Reply #6 on: August 21, 2013, 05:56:43 PM »
Thanks guys!  I guess my belts are still good. They're the originals with just over 500 hours on them. My blades do not touch the wheels.
Is that the only indicator of when its time to replace belts, or are there other reasons to replace them?  That and a broken blade chewing up a belt I can understand too.
Offline Chuck White
  • Sawing Mobile since 2005
Re: Replacing B57's
« Reply #7 on: August 21, 2013, 08:41:28 PM »
I remove the sawdust from my belts everytime I change the blade!
Wood-Mizer recommends rotating (switching sides) the belts every 50 hours!
The band should always be at least 1/8 of an inch away from the steel wheels!
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Replacing 288
Started by backwoods sawyer on Chainsaws
Last post April 22, 2014, 12:07:22 PM
by mad murdock
Replacing my 045
Started by TessiersFarm on Chainsaws
Last post January 05, 2010, 08:40:03 PM
by madhatte
Replacing 026
Started by JW IN VA on Chainsaws
Last post September 30, 2016, 06:36:41 AM
by Ada Shaker
Replacing A 625
Started by NITRO313jh on Chainsaws
Last post July 22, 2014, 02:05:09 AM
by NITRO313jh
