Author Topic: Pole barn doors  (Read 1845 times)
Offline John_Haylow
  • "If you are going through hell, keep going." W.C.
Pole barn doors
« on: August 21, 2013, 04:10:00 PM »
I would like to build some sliding doors for a pole barn with a 24’wide opening and 12’ in height. I was thinking of using a double track so I could have better access using 3 - 8’ doors. Anyone have any thoughts on this, I have heard that the cannonball style track system is better.
Thanks,
John
2004 Wood-Mizer LT40HDG28
Offline red oaks lumber
Re: Pole barn doors
« Reply #1 on: August 21, 2013, 07:25:54 PM »
make 2 12' doors with a single overhead track. my old kiln doors i made 16' wide x12' high with no real issues.
Offline gspren
Re: Pole barn doors
« Reply #2 on: August 21, 2013, 07:33:28 PM »
  It is going to depend some on how wide that end of the building is or if the terrain allows you to take the track off the building to a support pole.
Re: Pole barn doors
« Reply #3 on: August 21, 2013, 09:41:42 PM »
i don't think the building is  sitting on a peak, if there was any excavating done there will be plenty of ground clearance to run the track of the ends of the building. :)
Offline gspren
Re: Pole barn doors
« Reply #4 on: August 21, 2013, 09:48:30 PM »
  On my previous post I should have added how much of the 24 ft you need open at once.
Offline Bibbyman
    • Warden Sawmill
Re: Pole barn doors
« Reply #5 on: August 21, 2013, 10:09:53 PM »
I think about every set of doors roll one way or another depending on need.   The doors on the north gable end will bypass each other.  They can both go out some 4 feet past the end wall each way so we can make about a 16' opening on either side.
The ones on the front will bypass but only go to the left because of the wall that comes out on the right.
The doors over the deck are on single track and only move to left or right because they are cut out to fit over the deck.
Sawing since '94
Offline John_Haylow
Re: Pole barn doors
« Reply #6 on: August 22, 2013, 11:35:25 AM »
I think something like you have on your gable end would work for me Bibby. I take it you have a double track there, do you have the square track or the round track. Also how many support hangers do you have on each door?
Thanks,
John
Offline shinnlinger
Re: Pole barn doors
« Reply #7 on: August 28, 2013, 09:09:44 PM »
I've always built my sliding barn doors with sheets of plywood or t-111 as the core and ran 2x or 1x material around the perimeter. Sometimes I will put bats on the plywood to cover seams and make it look board and batten but without the work or the weight.
Shinnlinger
old barn/new doors
Started by giant splinter on General Board
Last post June 12, 2012, 09:42:41 PM
by shelbycharger400
Insulated Barn Doors
Started by Brian_Weekley on Timber Framing/Log construction
Last post May 07, 2014, 04:09:14 PM
by D L Bahler
Need help re: barn doors (mill shed)
Started by roger 4400 on Timber Framing/Log construction
Last post March 04, 2014, 07:51:58 PM
by Tom King
Center keeper sliding barn doors
Started by schreiber on General Board
Last post November 09, 2008, 08:30:07 PM
by thecfarm
