question for the john deere guys
Started by cutter88, September 24, 2013, 08:08:23 PM
cutter88
was coming out with my last hitch tonight with my 1988 640d and all of the sudden the heat gauge spiked and she started puking anti freeze out the over flow line by the rad cap??? ran the machine all summer in hot tempetures and pullen heavy and she never heated up once so what could make it spike like that on a cool day when it want even working hard????
any tips would be appreciated
Romans 10 vs 9
650G lgp Deere , 640D deere, 644B deere loader, 247B cat, 4290 spit fire , home made fire wood processor, 2008 dodge diesel  and a bunch of huskys and jonsereds (IN MEMORY OF BARRY ROGERSON)
PaYoungBuck
Maybe the thermostat or water pump failed? Something blocking a line? Feel the hoses and see if and where they are hard for pressure/ temp
chevytaHOE5674
Water pump working? Fan belt present and tight? Thermostat working? Hose collapsed? Any one of this things can cause it to overheat.
TheDirt
do you have a quick connect on a coolant line so you can hook the system up to a warm pickup or whatever on cold mornings? I had just the tiniest amount of sediment clog one of my lines at the disconnect and spent days watching my temp go crazy and blow the cap, then drop right down to cold, finally figured it out after being certain I'd blown a hole in the new cummins.
PaYoungBuck
ga jones
My buddies timberjack did that last winter. The radiator hoses were breaking down internally. Pieces of rubber from the hose blocked the thermostat.
380c timberjack c4 treefarmer international trucks jonsered saws. Sugi hara bars d31 komatsu 350 tj grapple
Nemologger
Sure acts like the thermostat to me. My 548 did the same thing a couple years ago and a pair of thermostats fixed it...Good luck!
Clean and Sober
treeslayer2003
you still got yer clark? I have 2 clarks 1 international and a 540b deere. had to rebuild the deere last year because it ate a pinhole in one liner. mine leaked into the base but I heard of cummins pressurizing the radiator from liner pinholes. just a thought, good luck.
justincase
I Have a 440d that did same thing. New thermostats and make sure they have a small hole in rim or drill a hole. I took mine apart 4 times before I realized it was air locked just below thermostat and needed just a little flow of coolant to open. I lost a lot of hair on that one.
Icehouse
I run my skidder during the summer with my fan in the pusher setting, sure helps keeping the radiator not so dirty from all the dust. But your problem sounds thermostat to me.
Favorite Stihl ms361 ms064 Favorite Husky 242xp 262xp
