Author Topic: Finally learning to braze on new teeth.  (Read 2804 times)
Offline maple flats
  • Life is what you make it!
Re: Finally learning to braze on new teeth.
« Reply #20 on: October 10, 2013, 09:36:38 PM »
I'll get more pics and post them. All of my blades look better than that. I don't think I have any black spots at all.
In the 8 years I've been sawing I only had to get 1 blade re-tensioned, FF member Peachy at Menominee Saw (a FF sponsor) did it, great job. That one had gotten a little hot, but no black spots. Likely letting a blade get so bad it needs to be worked too hard ruins the tension. Keep your teeth sharper and don't force it, you'll need less re-tensioning. Might also be better that my blades have 6 or 8 teeth, rather than just 5. Then each tooth is doing less work. However, I can get a bad chip or even have the end of a tooth break off and I still cut with 5, however I change the blade if I get 2 such chips or tooth tips broken off in a row.
Hammer, I did some more teeth after reading how you do it, and I added no extra braze. They still do look good, however my first sawing with that blade will be tomorrow or Saturday. Going to finish a custom sawing job Saturday. Hit lots of fence staples in the cherry butt log, somehow I set my metal detector to over look iron and steel by mistake, and didn't notice. It usually finds staples before the blade does, but not that time.
Offline maple flats
« Reply #21 on: October 20, 2013, 02:25:32 PM »
I used the 2- 6 tooth blades last weekend. 1 lost a tooth, the other all teeth held good. I now think that my tooth pocket (mating surface) may be the issue. I'm looking to design a guide to get repeatability in a perfect tooth pocket. I think maybe a roller each side of the blade in the 2 planes needed for a perfect 90 degree pocket for the tooth. This will likely need to be mounted on the hub for precise repeatability. Certainly not my forte` but I have 2 machinist friends who could do it. I think I have buggered up some of the pockets.
My last brazed tooth mentioned in the post directly before this one did not fail. The one that failed appeared to have a larger amount of added brazing rod to fill a void. Likely was a no-no.
Maybe I should have named this thread "trying to learn to braze new teeth"instead of what I named it!
Saw teeth
Started by John Woodworth on Sawmills and Milling
Last post June 26, 2013, 09:20:07 PM
by bandmiller2
MD teeth
Started by cleargrain on Sawmills and Milling
Last post January 02, 2009, 02:42:57 PM
by Jeff
All teeth...
Started by Kbeitz on The Outdoor Board
Last post September 06, 2017, 07:50:31 AM
by Chuck White
New teeth
Started by dustyjay on Sawmills and Milling
Last post February 08, 2014, 09:14:28 PM
by bandmiller2
