Baltic Abrasives Technologies
Author Topic: Pole Saws  (Read 8702 times)
Offline 555JM
Pole Saws
« on: October 07, 2013, 06:24:47 PM »
Hi,
New here, but not to chainsaws...AS refugee :-\  Started looking at power pole saws recently.  Have a dozen or so nut trees badly in need of pruning, some large evergreens that need work, and some brush thickets that need thinning (heard the pole saws work good for that).  However, I've never used a power pole saw.
Was comparing the Husky 327P5x with the Stihl HT101.  Then happened upon the Echo line and, after looking at the PPT-266, stumbled upon the PAS modular line.
The thing I like about the PAS (thinking PAS-266) is that they'd be lighter for the down-low pruning and that the 3' extension (and its weight) would only be needed for the higher jobs (salesman said that two extensions could be used).  That, plus there are also brush cutter, string trimmer, and hedge trimmer attachments; all of which would be useful when not using the pole saw attachment.
I've done a search and seen some pole saw posts, but anyone here care to comment on any of the models listed?  In particular, has anyone used the Echo PAS (Pro Attachment Series)?  Usually multifunction tools, while useable, aren't particularly good at anything.  Wondering if that applies here.
Offline exSW
  • I'm new!Well here at least
Re: Pole Saws
« Reply #1 on: October 07, 2013, 06:49:21 PM »
Same deal here,I looked at Echos, that big one is HEAVY.I'm most impressed with the Efcos.Adjustable head,and an extendable(ptx2700)that's manageable.
"well I was drunk the day my mom got out of prison"
Offline sharkey
Re: Pole Saws
« Reply #2 on: October 07, 2013, 06:56:08 PM »
We have one of the older Echo and one of the Stihl Telescope jobbies.  Both will reach 12 ft, but the Echo has a 5ft extension for a total of 17ft.  I think you will find the longer the reach the better because you cant stand under what your cutting, you have to stand off to the side.  The echo has been the better of the two for us.
Offline Weesa20
Re: Pole Saws
« Reply #3 on: October 07, 2013, 09:11:04 PM »
AS refugee as well...I Have a stihl ht101 and really like it....pretty good reach, not super heavy, pretty well balanced, can get a full harness for all day use. Hadn't used in 3 months, 3 pulls and was runnin, just have to use the starting procedure specific the stihls. Oh, and I use the synth oil- has a stabilizer in it that helps with the ethanol I think.
Offline Cattoon
Re: Pole Saws
« Reply #4 on: October 08, 2013, 08:35:37 AM »
I have had good experience from the Stihl KM90, I couldn't justify the expense of a dedicated pole saw, I bought the kombi with the extension pole a couple of years ago and thus far have had no issues, but I still haven't bought any other attachments LOL, it cuts quick and is handy for clearing trails. I can cut to about 12-13 ft easily and there are several other attachments available.  Have a great day.
Offline thecfarm
Re: Pole Saws
« Reply #5 on: October 08, 2013, 09:31:00 AM »
I've been looking at that Stihl kombi,polesaw,trimmer,leaf blower would be nice.
Offline nmurph
Re: Pole Saws
« Reply #6 on: October 08, 2013, 09:53:20 AM »
Find a used HT 75. They are lighter than the competition, have enough power for a polesaw, and the motors are used in lots of Stihl products.
Offline scsmith42
    • Whispering Pines Farm
Re: Pole Saws
« Reply #7 on: October 08, 2013, 11:04:35 AM »
I spent a day using an HT101 and a smaller Stihl pole saw a few weeks ago.  The HT101 was a real hoss and cut circles around the smaller saw.  I was impressed.
Tom's 3638D Baker band mill
Offline Weesa20
Re: Pole Saws
« Reply #8 on: October 08, 2013, 03:00:40 PM »
Not sure if everyone knows or not, but you can put just about any attachment on the end of the Stihl straight shaft machines (FS line)...the exceptions are the FS250 and RX100....don't have to have a KM setup to use the attachments but the KMs are a little quicker to change but heavier than the standard FS machines.
Offline JohnG28
Re: Pole Saws
« Reply #9 on: October 08, 2013, 04:17:48 PM »
My uncle has a Stihl 101, sweet little deal. Has a 14" bar on it I believe and he has said it will about cut the length of the bar with no problems. I used it for some smaller branches and had no problems at full extension. Reach was at least 15' while standing.
Offline bill m
Re: Pole Saws
« Reply #10 on: October 08, 2013, 07:43:50 PM »
I own both the Stihl ht75 and the Echo ppt266. The biggest problem with the Stihl is the splined shaft inside. When you pinch the chain while under power ( and yes - it will happen no matter how careful you are ) the splined shaft will twist. When this happens you will not be able to extend or retract the telescoping section. This has happened to every Stihl I have owned. As for the Echo power pruners I have never had a single problem with any of the ones I have owned.
Offline thecfarm
Re: Pole Saws
« Reply #11 on: October 08, 2013, 07:47:44 PM »
Does Echo have just the power head? Than you buy what you want?
Offline mesquite buckeye
  • Trees are good- even ones with stickers
Re: Pole Saws
« Reply #12 on: October 08, 2013, 08:02:03 PM »
I have an older Stihl HT75, about 8 ft long, extends another 5ft. Standing and really stretching I can cut to 17', but not really safely. Above about 14-15 I won't cut anything over a couple inches thick, so not a big deal if it hits me in the head wearing full gear. Probably really safe to around 13-14ft. Really nice for pruning up pole stands and reaching inside monster multiflora roses to cut out the center stems without having to wade into them and get ripped up. This is an exhausting saw to run for any length of time at height without the shoulder sling. Wish I had a way to get to 21ft so I could get one clear 20 or 2 clear 10's. ;D Of course I wish I was 20 years younger and could kick butt like that again. Oh well. ;D ;D ;D ;D
Offline beenthere
Re: Pole Saws
« Reply #13 on: October 08, 2013, 08:09:25 PM »
bill m
Hasn't happened to my Stihl yet. And has been stuck a few times too.
Offline bill m
Re: Pole Saws
« Reply #14 on: October 08, 2013, 08:49:41 PM »
beenthere,
 It happened to both of mine and also to one belonging to a friend. I'll stick to my Echo's.
Re: Pole Saws
« Reply #15 on: October 08, 2013, 09:07:54 PM »
I have had mine stuck more times than I can remember. Part of that is technique and learning curve. Never got any damage from it other than a popped off chain. I do try to be careful and not abuse tools. Makes a difference. ;D :o :snowball:
Offline beenthere
Re: Pole Saws
« Reply #16 on: October 08, 2013, 09:11:22 PM »
Quote
bill
That be fine by me.   8)
Offline 555JM
Re: Pole Saws
« Reply #17 on: October 08, 2013, 10:19:55 PM »
The Echo PAS series is set up like that.  Buy a powerhead for around $200-$300 and then attachments that include a pruner (10" pole saw), a couple of hedge trimmers, four string trimmers, a sweeper, a cultivator, a brush cutter and even a leaf blower. No one has posted about them, so either they're too new or too light duty to be considered.
I'm afraid the pole saw might not be tough enough for my needs, but I may give it a try anyway.  The other attachments would still make it worth owning.  Hard to go wrong with a 5 yr. warranty and local support.
With a few extra attachments, the power head would see frequent use instead of sitting around waiting for the next pruning job.
Offline nmurph
Re: Pole Saws
« Reply #18 on: October 09, 2013, 05:26:10 AM »
bill m
Me either, and I've owned mine for 5+years. The trick to cutting anything over 1" or so is to make an undercut. Otherwise, the limb will barber chair and pinch the bar. As mentioned elsewhere, a polesaw gets heavy if you use it any length of time. The lighter it is, the longer you will be able to control it and use it comfortably.
Offline Ed
Re: Pole Saws
« Reply #19 on: October 10, 2013, 01:53:59 PM »
I've had to replace the extension shaft twice on my HT75...1st time after a falling branch caught it, couldn't get the pruner out from under it before it hit the ground, 2nd time the saw was bouncing in the cut on a large Hickory branch, it was enough to twist the splined shaft enough so that it wouldn't slide.
While the pole saws do serve a purpose, after a number of trimmings you can't reach the branches. That's where I'm at now on our property, we'll be bringing in a telehandler with a basket this winter and do some serious trimming.  ;D
Ed
How does the HT 131 Stihl Pole Saw compare to other Pole Saws?
Started by JOE.G on Chainsaws
Last post May 29, 2012, 01:36:36 AM
by Dixie Feller
Pole saws
Started by MrMoo on Chainsaws
Last post June 15, 2015, 05:10:52 PM
by CTYank
Pole saws
Started by Riwaka on Chainsaws
Last post August 22, 2017, 02:10:01 PM
by DaveP
pole saws
Started by snowman on Chainsaws
Last post March 20, 2009, 09:57:27 PM
by rebocardo
