Author Topic: Pole Saws  (Read 8826 times)
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
Re: Pole Saws
« Reply #20 on: October 10, 2013, 06:26:40 PM »
well I skimmed thru this thread , but here again is my 2c worth.
I have a husky which runs really well.
Th problem is when cutting to the highest branches it jams.
I would think that the MFRS could design a head that angles to cut 90 degrees to the ground. eliminating the binding.
"old guy"
Pete
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline mesquite buckeye
  • Trees are good- even ones with stickers
Re: Pole Saws
« Reply #21 on: October 10, 2013, 07:08:06 PM »
Good idea, Pete. Maybe a 45. Maybe a dedicated high saw for branches from 14-22 ft.
Offline exSW
  • I'm new!Well here at least
Re: Pole Saws
« Reply #22 on: October 10, 2013, 07:48:41 PM »
"old guy"
Pete
EFCO has
"well I was drunk the day my mom got out of prison"
Re: Pole Saws
« Reply #23 on: October 10, 2013, 11:04:47 PM »
Who dat? Also how high does it go?
Offline exSW
Re: Pole Saws
« Reply #24 on: October 10, 2013, 11:17:15 PM »
Efco,what used to be Olympyc.PT2700(fixed) 7'5" and PTX 2700(eXtendable)12'5"and head pivots 45 degrees and 90 degrees.I keep wanting one but...I'm cheap.I have an Efco 40cc brushcutter and I've been very pleased and it gets used hard.
Re: Pole Saws
« Reply #25 on: October 10, 2013, 11:44:51 PM »
Might be worth a look. How much?
Sure would be nice to get one that reaches 21. Handling would be the issue.
Offline Ed
Re: Pole Saws
« Reply #26 on: October 11, 2013, 09:39:20 AM »
Stihl makes an angle adapter for their pole saws and Cannon males an angled bar.
http://cannonbar.com/chainsawbars/specialtybars.html
I bought one of the Stihl angle adapters for my HT75, doesn't really work well, the HT75 is down on power compared to the current offerings and the added gearbox doesn't help matters much.
Ed
Offline 555JM
Re: Pole Saws
« Reply #27 on: October 11, 2013, 10:00:26 AM »
There are a couple of Efco shops within driving range.  I may give them a call to see if they have one I can look at.  I  think the fixed length Efco would be too short for much of my work.
Those extendable jobs, at least the Stihl and the Echo I looked at are heavy.  Can see that there'd be a handling problem with the saw dropping ahead of the cut-off limb and then the limb landing on the pole and bending it.
Leaning more towards the Echo PAS system.  They're lighter, the pole extensions would be cheap to replace, and, if this whole pole saw idea doesn't work, there are other tools the power head can be used with.  My Echo dealer said he had an Echo extendable pole saw for his own use and switched to the PAS pruner for easier handling and cheaper repairs.
Offline exSW
Re: Pole Saws
« Reply #28 on: October 11, 2013, 12:00:30 PM »
I think the PTX2700 retails for around 650 the PT2700 500ish.There are some left over PT2500's floating aound that can be had for around 4 bills.As far as reach,no matter what you get it's always going to be 6" to short.Even at 6'5" and a pTX 2700 I still see myself standing on the flatbed dump trying to get just a little higher.
Re: Pole Saws
« Reply #29 on: October 12, 2013, 10:35:14 PM »
Too true, but in thinned, fast growing forest my branches start getting pretty fat around 20 feet, so too big to take away without making a rot point. If I could just get to 21, I would be content. ;D
Offline terry f
Re: Pole Saws
« Reply #30 on: October 12, 2013, 10:39:49 PM »
    I have a stihl 130 Kombi that I think is great, more power than it needs to run a 12 inch bar, and a quick change to whatever attachment you want. For what I do, I use it as a chainsaw more than my chainsaw, and it's easier  on the back.
Offline Cut4fun
Re: Pole Saws
« Reply #31 on: October 13, 2013, 12:46:27 PM »
I like my echo 260 extendable 2 stroke pole saw. I wouldnt trade it for any 4mix type crap.   8)
Offline deerslayer
  • old cars, saws, trucks, tractors
Re: Pole Saws
« Reply #32 on: October 20, 2013, 02:55:14 PM »
I've been happy with my Stihl HT101. It's a bear to use fully extended but does jobs that would be difficult otherwise. I really like it for clearing roof lines (from the roof) or trimming brush away from homes from the ground. I even occasionally will use it in a tree to cut something off I don't dare to climb out to. It is an important component of my saw line up. I haven't had any issues with the shaft twisting but did turn a bar into a pretzel when I couldn't get the saw clear when topping a pine tree. Can't really blame that on the tool I guess, eh?
Too many chainsaws, not enough wood.
Stihl, Husky, Craftsman, Mac, Homelite, Poulan. Some live here, some just passing through.
Offline aldo
Re: Pole Saws
« Reply #33 on: October 21, 2013, 06:44:39 PM »
I have an extendable Echo PPT265 version and I find it great. I chose it over the Stihl a few years back due to marginally longer reach and one thing I thought to be a valuable addition was a well protected rear end. The tank area will always cop a knock and the Stihl model back when I purchased was not as well protected. The Echo units bar/chain adjustment is not super sturdy I reckon but I'm pretty fussy with maintenance so I'm not rough. My dad has the multi tool type system and they just don't have the reach for what I need.
 I found a handy companion for my Echo is a manual Silky Hayate. I bought the petrol unit first, had I done it the other way I may have not purchased the Echo.
In terms of engine reliability I have most brands and I find they are all excellent when maintained well. About the only standout in terms of first pull starting is Tanaka. It's almost ridiculous.
Offline annia
  • Gender: Female
Re: Pole Saws
« Reply #34 on: January 07, 2018, 05:04:31 AM »
The pruner extension works great and cuts through branches up to 3 inches. You need to know how to prune, though. A bit more instruction for the beginner in the manual would not be so bad. The attachment is easy to "assemble" and attach. Can be swapped out to any other attachment easily. Due to the length of the pruner, the whole Echo machine gets a bit out of balance (top heavy) and if you work the trees you get a nice upper body and arm work out on top. Not for everyone probably.
Annia Palmer
Offline Logger RK
Re: Pole Saws
« Reply #35 on: January 07, 2018, 06:03:27 AM »
I bought a black & decker 20 volt battery powered pole saw this summer. I'm impressed with it. I don't use it to much,mostly for logging roads so semi's don't hit low hanging branches. It does come apart into 3 pieces & fits on a 4 wheeler rack nicely.  It'll be handy for clearing shooting lanes for hunting. And it has the same battery as my weedwacker. I do have a old gas one that's not very dependable. When I'm looking for a good work out I use that one.
How does the HT 131 Stihl Pole Saw compare to other Pole Saws?
Started by JOE.G on Chainsaws
Last post May 29, 2012, 01:36:36 AM
by Dixie Feller
Pole saws
Started by Riwaka on Chainsaws
Last post August 22, 2017, 02:10:01 PM
by DaveP
pole saws
Started by snowman on Chainsaws
Last post March 20, 2009, 09:57:27 PM
by rebocardo
Pole saws
Started by MrMoo on Chainsaws
Last post June 15, 2015, 05:10:52 PM
by CTYank
