Author Topic: Clean up and new fuel line, doesn't seem to pull fuel?  (Read 463 times)
Offline fairlaniac
« on: October 18, 2013, 10:21:19 PM »
I replaced the fuel line on my Mcollough Eager Beaver. After having issues getting it to run I put a few drops of fuel straight into the carb, through the throttle plate. I pull it and it runs until that few runs runs out. Once running it doesn't seem to pull fuel. The carb is clean, the diaphragm seems to be working. I put a piece of tubing on the impulse line and sucked it to actuate it and also on the fuel line. I just can figure how to keep it running. Any thoughts? Prior to disassembling the saw to replace the fuel line it ran fine. A section of fuel line had rotted off in the tank leaving an open end of fuel line to feed the carb. I thought I fix it and clean it up. So why does it act like this now? Any help?
Thanks,
Doug
Offline chainsaw dog
Re: Clean up and new fuel line, doesn't seem to pull fuel?
« Reply #1 on: October 18, 2013, 11:15:12 PM »
THEY ARE COLD BLOODED.DID YOU REAJUST CARB? YA GOTTA PLAY THAT CHOKE LEVER TILL IT WARMS UP. SET THE HI LOW 1AN HALF TURN OUT THEN TURN THEM BACK IN SLOW
New saws don't have personalities until they're old
« Reply #2 on: October 18, 2013, 11:31:08 PM »
ALSO DID U CHECK FUEL FILTER  STUFF IN THE TANK?
Offline Al_Smith
« Reply #3 on: October 19, 2013, 06:51:51 AM »
What you have is a classic case of a carb with stiff diaphragms and check valves .I have often commented that to just "clean " a carb more times than not is an exercise in futulity if you don't install a new rebuild kit which is relatively inexpensive .
029 fuel line and fuel filter
Started by tstex on Chainsaws
Last post December 13, 2010, 09:33:18 AM
by tstex
question
I need help please with my fuel line
Started by brucec on Chainsaws
Last post October 03, 2015, 03:23:08 PM
by Kingmt
it was the fuel line
Started by ten_mile on Chainsaws
Last post January 01, 2016, 04:24:10 PM
by Gearbox
fuel line
Started by 4430jd on Chainsaws
Last post December 22, 2012, 11:36:14 PM
by scully
