TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: putting set into blades  (Read 3311 times)
Offline diesel pap
« on: October 27, 2013, 10:48:03 PM »
about how many times can you sharpen band saw blades before you have to set the teeth
Offline Peter Drouin
    • A&P Saw mill LLC
Re: putting set into blades
« Reply #1 on: October 27, 2013, 10:50:13 PM »
Maybe one time.
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline diesel pap
« Reply #2 on: October 27, 2013, 11:08:37 PM »
looks like i will have to build myself a setter. i bought a grinder off of ezboardwalk
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
« Reply #3 on: October 28, 2013, 12:17:02 AM »
I was told by my WM dealer, 1 to 3 times between setting.
In practice I've found that a blade that's been cutting true without marking the wood is good for a couple of sharpenings between setting. If it's marking the wood or wandering even a little it needs to be set.
When I sharpen a blade I write on it with a black felt pen, indicating how many times it's been sharpened and how many sharpenings since it was last set.
When I finish sawing with a blade, I duplicate the numbers and also add a note about any issues with the blade.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Offline kelLOGg
« Reply #4 on: October 28, 2013, 05:58:30 AM »
I set every time before I sharpen and I frequently find that the outer teeth have lost more set than the inner teeth. Anybody else seen this?
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline bandmiller2
« Reply #5 on: October 28, 2013, 06:46:36 AM »
New band you can get by with one or two sharpenings between setting.It varies some logs seem to take the set out early.I have a dial indicator gauge and check several teeth,if their good I just sharpen.The bands are springy and if the teeth have enough set they really don't change going through the two side setter only the lowset teeth get a bump.  Frank C.
Offline diesel pap
« Reply #6 on: October 28, 2013, 08:27:00 AM »
so im guessing you set if needed before you sharpen. back in the late nineties i sent my blades to a guy to sharpen. they worked good after the first time but that was about it. he didnt set since he  didnt have a setter.
Offline sawmillhand
« Reply #7 on: October 28, 2013, 08:53:28 AM »
Do you set then sharpen?  or do you sharpen then set?  which would be the correct way.
1990 woodmizer LT40 Hyd  2004 Ford F350 Flatbed. Plenty of tractors.
Offline Kansas
  • In the mountains of Kansas
« Reply #8 on: October 28, 2013, 08:58:22 AM »
Set, then sharpen.
Offline Happycamper
« Reply #9 on: October 28, 2013, 09:00:35 AM »
I set then sharpen the blade like you would a hand saw. I use a "pineywoods" setter and it does a good job.
                                    Jim
Wether you think you can or you can't you're right
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #10 on: October 28, 2013, 09:41:01 AM »
I set the teeth, then sharpen.
I set everytime the blade needs sharpening!
~Chuck~
I LOVE MY SAWMILL
Offline fat olde elf
  • Growing old is not for sissies - Betty Davis
« Reply #11 on: October 28, 2013, 02:59:25 PM »
I always check the set before sharpening. Usually I go at least 2 sharpenings without setting unless I hit something. Years ago TOM told me to set and then sharpen. He was always right, put on your red t-shirt........ Say your prayers  FOE
Cook's MP-32 saw, MF-35, Several Husky Saws, Too Many Woodworking Tools, 4 PU's, Kind Wife.
Online Tom the Sawyer
  • Converting your logs to lumber at my home or yours
    • Tom the Sawyer Portable Sawmill Service
« Reply #12 on: October 29, 2013, 10:16:41 PM »
I understand the importance of removing the burr off of the blade setting the teeth, if you sharpen first.   smiley_thumbsup
For those who set, then sharpen, it is necessary to remove the burr or will it come off as soon as it enters the log?   smiley_headscratch
Thanks for your opinions,
07 Timberking B-20, Custom-made log arch, 20' trailer w/ log loading arch, F350 SD flatbed dump.  Princeton piggy-back forklift.  Bobcat S250, Stihl 025C 16" and a Husqvarna 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says "He's sawin logs", I ain't snorin'.
Offline Brian_Rhoad
« Reply #13 on: October 29, 2013, 10:48:53 PM »
I never remove the burr. By the time the blade needs sharpened the burr is gone. I have tried setting before and after sharpening and before is definitely better.
    • A&P Saw mill LLC
« Reply #14 on: October 29, 2013, 11:02:58 PM »
I always set then sharpen , the top of the tooth has to be square to the blade. And that doesn't happen if you sharpen then set. It just won't cut right.
 Just my 2 cents.
Sawing since 1987
« Reply #15 on: October 30, 2013, 01:09:10 AM »
Peter D. is absolutely correct.  Squareness of the tooth is critical. Custom Sawyer has posted about this. Just check any table saw blade that is made for ripping. Teeth are square to the blade......Any burr left after sharpening is soon gone and not a factor.
Offline Brucer
« Reply #16 on: October 30, 2013, 01:13:13 AM »
I also set, then sharpen. The burrs come off as soon as the blade hits the log.
Further to Peter's comment, new blades (at least WM blades) are set after they are sharpened so they are not square to the blade. This doesn't seem to cause a problem when you use them straight out of the box. However, you must grind them down until the tops of the teeth are square to the blade across their entire width.
If you don't sharpen them this way, the lowest part of the tooth (on the outside) doesn't get sharpened. This means you have sharp teeth in the centre of the cut, but dull teeth on the top and bottom portions of the cut.
Offline customsawyer
    • The Custom Sawyer
« Reply #17 on: October 30, 2013, 03:42:14 AM »
For what it is worth I sharpen and then set. I think it has a lot to do with how you are using your blades and what you are cutting. Just my 2 cents worth.
Two LT70s and to much other support equipment to mention.
www.thecustomsawyer.com
Offline woodmills1
  • the truth shall set you free
« Reply #18 on: October 30, 2013, 05:44:38 PM »
here is a trick I use that will work if you can plan your cutting and you cut both hard and soft species.  I buy wm 7 degree blades set for white pine, and use them twice with one sharpen.  If the universe is in alignment I can then use them twice with two sharpens in hardwood.  then they need serious set, except most of the time I hit metal in the oak.  I don't sell oak log that I think have metal as I won't get paid for them.  If a blade does2 pine jobs with no metal it doesn't owe me anything on the next oak job.
that said I set very little
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #19 on: October 30, 2013, 06:10:30 PM »
I've turned it around and am now setting, then sharpening.  lets me skip the de-burring step.   I'm sure the burr is gone the instant the blade saws into the log.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
Putting this in my IH
Started by treefarmer87 on Forestry and Logging
Last post December 10, 2013, 12:24:10 AM
by Maine logger88
putting red oak up wet
Started by thinman56 on Drying and Processing
Last post February 24, 2010, 12:14:35 PM
by ARKANSAWYER
Putting the WPF together
Started by Qweaver on Sawmills and Milling
Last post January 25, 2012, 07:04:24 PM
by terrifictimbersllc
Putting it all together
Started by Ianab on General Board
Last post December 03, 2004, 08:45:25 AM
by OneWithWood
