TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: chainsaw milling  (Read 913 times)
Offline gginseng4
chainsaw milling
« on: November 07, 2013, 09:39:48 PM »
Would two Stihl 056 (around 81cc) powerheads work on a granberg 56 "chainsaw mill. Does anybody have any experience with running two power heads on one of the mills?
   Glen
Offline qbilder
  • lil helper
Re: chainsaw milling
« Reply #1 on: November 07, 2013, 09:58:54 PM »
I haven't ran a two headed mill, but two 056 heads should easily run a 56" bar.
God bless our troops
Offline Delawhere Jack
  • I ought to know better.....
« Reply #2 on: November 07, 2013, 10:11:54 PM »
Haven't a clue, but if you make it work, we want to see PICTURES!!  ;)
Online terrifictimbersllc
    • Terrific Timbers LLC
« Reply #3 on: November 08, 2013, 03:27:38 AM »
I have a Sperber 52" mill with two Stihl 090AV power heads.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline mad murdock
« Reply #4 on: November 08, 2013, 07:37:03 AM »
How well does it work? 2 090's? Those things are worth a bit of $$ nowadays
To the OP-56" is a long bar, are you planning on slabbing a lot of stuff in the 36-48" range? For a lot of CSM'ing you can do well with a 28-36" Alaskan and a single powerhead. I have not used 2 powerhead a at once, but I am sure it would power through the long cuts better than 1.
JD AMT 626, Turbosawmill M6 Warrior Ultra liteweight, Granberg Alaskan III, lots of saws-gas powered and human powered :D
Offline dboyt
  • Log On!
« Reply #5 on: November 08, 2013, 07:55:03 AM »
I've used the double head bar with various combinations of saws, including a Husqvarna 372 on one end and a Stihl 066 on the other.  Works great, but you have to work with someone who pays attention.  You have to throttle up together, because one saw powering the other can spin the clutch off of it (heard about it, never had it happen).  Goes through a lot of gas, but it gets the job done.  Go for it!
« Reply #6 on: November 08, 2013, 07:58:20 AM »
A lot of noise and vibration which doesn't stop when the saws are turned off, but effective. Two saws to start and keep running.   Easier with two people than one, and not something you want to ask the customer to help with, in my opinion.  The reason I bought an LT40 Super when sawing wood was still a hobby.
Offline Gasawyer
« Reply #7 on: November 08, 2013, 08:28:12 PM »
Unless you're going to use it alot one of those power heads should work,just go slower. I run a 72" bar with a husky 3120  without any problems. Running both power heads will be plenty of power if you can cordanate operation. Just remember to let them run a minute or so after the completion of each cut to cool off, makes power heads last longer.
Woodmizer LT-40hdd super hyd.,Lucas 618,Lucas 823dsm,Alaskian chainsaw mill 6',many chainsaws large and small,NH L555 skidsteer, Int. TD-9,JD500 backhoe, and International grapple truck.
Milling with chainsaw
Started by plantman on Sawmills and Milling
Last post March 12, 2017, 12:41:58 AM
by Brucer
chainsaw milling
Started by WoodSmith on Sawmills and Milling
Last post October 16, 2005, 07:28:33 AM
by DonE911
chainsaw milling
Started by 76gmc on Sawmills and Milling
Last post January 02, 2012, 01:20:45 AM
by Brucer
Chainsaw Milling Help
Started by alabama on Sawmills and Milling
Last post April 25, 2017, 06:50:05 PM
by theonlybull
