Arborwear
Author Topic: husqvarna 562xp  (Read 7656 times)
Offline NovaSS
husqvarna 562xp
« on: November 11, 2013, 11:26:34 PM »
Hi, I bought a acre of land that needed cleared off so I thought might as well do I my self. I have been searching and reading forums for a couple of weeks on saws. First I wanted the ms290 farmboss, then looked at the ms291 and ms392. But after talking with some friends and my grandfather they have always had better luck with the husqvarna. So i ordered the 562xp 20" bar extra chain and the 3 things of premixed gas/oil and forester full warp chaps for $725. I owned a couple of small echos and small homeowner stihls. I hope the husqvarna impresses me. lol I wasnt going to get chaps at first but after reading a few people saved there legs i changed my mind.
I was wondering how these saws are holding up today? I know they been out for a few years now. The computer contol carb kinda scares me.
Offline thecfarm
Re: husqvarna 562xp
« Reply #1 on: November 12, 2013, 09:36:05 AM »
NovaSS,welcome to the forum. A acre that needs clearing. Where's all the wood going? Building a house on the clearing?
Offline Yatt
Re: husqvarna 562xp
« Reply #2 on: November 12, 2013, 10:43:18 AM »
It's a great saw.
On the first start up.  Find a large log you can bury the tip and run the saw WOT for at least 5 min. making bucking cuts constantly.  The computer does the set up at this time.  This is not the time to putz around and idle the saw and cut twigs.
288 XP Lite
372XPG
562XP
357XP
550XPG
346XP
Dolmar 7900
028 Super totally rebuilt and ported
Speeco 28ton splitter
Silvey 510, Oregon 511AX & Tecomec grinder
Offline DDDfarmer
  • did you know 4/3 people don' know their fractions
Re: husqvarna 562xp
« Reply #3 on: November 12, 2013, 11:33:01 AM »
Great saw.  Earlier models had problems with rewind case breaking ( under warranty). Should be solved by now.  +2 on the WOT, follow the book on that.
Just wait till you have a few tanks of gas used, it gets better.. ;D
Treefarmer C5C with cancar 20 (gearmatic 119) winch, Husky 562xp 576xp chainsaws
Offline NovaSS
Re: husqvarna 562xp
« Reply #4 on: November 12, 2013, 01:24:38 PM »
I just read the online manual on the saw and it says to not run at wot for the first 10 hours of use.
Offline tlandrum
Re: husqvarna 562xp
« Reply #5 on: November 12, 2013, 01:59:32 PM »
just run the saw as you normally would run it. you don't have to do the tuning cuts with it. it learns every time you run the saw so the tuning cuts just tune it for the cuts your making not future cuts. you can run it at wot without  any problems as long as its ubder a load you good to go.
www.wickedworksaw.com
wickedworksaw@gmail.com
Husqvarna and jonsered dealer
chainsaw porting for high production work saws
4233465399
Offline SawTroll
Re: husqvarna 562xp
« Reply #6 on: November 12, 2013, 04:18:50 PM »
I assume that is about WOT out of wood, and not about WOT in general - and is normal advice.  ;)
Information collector.
Offline Lanternguy
  • Cottage, Home and rental properties
Re: husqvarna 562xp
« Reply #7 on: November 12, 2013, 04:39:58 PM »
i'm sure allot of Husy XP fans on this site and i love the older models as i used lots of them over the years but i am a little weary of the XP saws, now mind you i only experienced one and this one did not like to re-start when hot but man was that sucker fast when it did run  :o
Echo CS3000, Stihl MS180, Echo 450P, Stihl MS361, Stihl HS46C-E, Stihl Magnum BR600, Echo SRM225, Stihl FS 56, Echo TC-210 Tiller, Stihl BG56 C-E,  Black and Decker Alligator, Poulin Pro Blower
Offline NovaSS
Re: husqvarna 562xp
« Reply #8 on: November 12, 2013, 05:32:34 PM »
I read on another tread theres alittle trick you had to do on the first models after it was hot. Maybe they fixed it on the newer models
Offline ChopperDan
Re: husqvarna 562xp
« Reply #9 on: November 12, 2013, 10:46:28 PM »
I haven't had any problems with mine. I run 2 autotune saws and never had any issues hot or cold.
550xpg
562xp
Makita 6421 converted to 7900 X2
Hd SuperSpitter
Offline NovaSS
Re: husqvarna 562xp
« Reply #10 on: November 12, 2013, 11:14:58 PM »
Hi Dan, how do you compare the 550xp to the 562xp? I was thinking about the 550 but I only had to pay a extra $60 to get the 562
Offline SawTroll
Re: husqvarna 562xp
« Reply #11 on: November 12, 2013, 11:24:46 PM »
There is a big differense in cc and power, and of course in weight as well. They aren't really comparable, it depends on what you need or want.  :)
Offline John Mc
Re: husqvarna 562xp
« Reply #12 on: November 13, 2013, 10:05:04 AM »
Both the 550 and the 562 are great saws.  The 562 is just a lot more saw - great to have the extra power, if you don't mind the extra weight that comes with it.
Offline ChopperDan
Re: husqvarna 562xp
« Reply #13 on: November 13, 2013, 10:30:26 PM »
Like SawTroll said they don't really compare.
The 562 is my go to firewood saw. For me it feels right. It pulls with authority.
The 550 is smaller and lighter and the heated handles make it the everything else saw.
The 562 runs a 18" bar with full chisel chain and the 550 runs a 16" bar with full chisel chain. They can run larger bars but I don't like to spend my time sharpening extra chain and I have larger saws with larger bars.
Oh and the heated handles are really nice!!! To the point I'm thinking of selling the 562 to get a 562xpg.
Hope that helps
550xpg
562xp
Hd SuperSpitter
Offline NovaSS
Re: husqvarna 562xp
« Reply #14 on: November 14, 2013, 12:54:35 AM »
im sure the heated handles are nice up north. would be nice some days, but dont think I really need them in florida.
Offline DDDfarmer
Re: husqvarna 562xp
« Reply #15 on: November 14, 2013, 10:32:11 AM »
I never even thought of the heated handles.  Never liked them.  Riding snow machines with heated handles then you climb of and work in the snow with those warm gloves. Then back to the heated handles to warm up again.  In no time at all your gloves are soaking wet.  I already use up 5-6 pairs of gloves a day doing firewood.
Offline HolmenTree
Re: husqvarna 562xp
« Reply #16 on: November 14, 2013, 10:46:05 AM »
I'm with DDDfarmer about snow and heated handles, but they are real nice on the hands when cold and not working in snow, even on a wet damp day.
Here's my 562XP with 16" b/c. The short bar makes the saws powerband even more crazy hyper, Also the best handling b/c for felling, limbing and topping small to medium timber. I saved the spruce trees at the customers request. :D
Offline DDDfarmer
Re: husqvarna 562xp
« Reply #17 on: November 14, 2013, 10:52:57 AM »
Not bad, dropped all those trees and missed the crapper. 8)
Gotta watch out for the important things ;D
Offline HolmenTree
Re: husqvarna 562xp
« Reply #18 on: November 14, 2013, 11:01:36 AM »
Quote from: DDDfarmer link= topic=70377.msg1057192#msg1057192 date=1384444377
Yeah that crapper was a prime target alright :D but those poor little spruce had their days numbered .  :D
Offline SawTroll
Re: husqvarna 562xp
« Reply #19 on: November 14, 2013, 04:03:01 PM »
Most of my saws have heated handles, and it didn't happen by accident!  :)
Husqvarna 562xp question
Started by motohed on Chainsaws
Last post April 14, 2012, 07:29:17 PM
by rocket75
Husqvarna 562XP Upgrades 2015.
Started by HolmenTree on Chainsaws
Last post February 04, 2018, 09:01:03 AM
by thecfarm
Husqvarna 562xp engine burn up
Started by Beres on Chainsaws
Last post February 19, 2015, 07:02:43 PM
by Andyshine77
Husqvarna 285CD & Husqvarna 375K concrete saw
Started by Coach on For Sale
Last post June 25, 2014, 12:30:04 AM
by hacknchop
