Author Topic: Single arch or dual arch ???  (Read 1460 times)
Offline BargeMonkey
« on: November 24, 2013, 03:11:45 AM »
 Ive been narrowing down the list on a grapple, and wondering what you guys had to say. Im not a huge production logger, have no plans of a chipper, this machine will see 500 hours max a year.  We still pull alot of cable, and I know it sounds funny but I would still like to run it like a 1/2 cable skidder if I had too. Most of the stuff around here is single arch and old or newer and dual arch, everyones opinion varies. What about a 460C V.S a 648G.3 ?  Any good versus bad ?
Offline Firewoodjoe
  • Im getting old
Re: Single arch or dual arch ???
« Reply #1 on: November 24, 2013, 09:40:27 AM »
I like both single and dual. Both have there pros and cons. If u want to use the winch a lot then u need a dual. The grapple is always in the way on the single. The single we run is a 360tj
Offline nhlogga
« Reply #2 on: November 24, 2013, 09:45:45 AM »
I have run both extensively and in my opinion the dual arch is the way to go. You can do much more with the dual arch.
Jonsered 2260
Husky 562xp
Offline nhlogga
« Reply #3 on: November 24, 2013, 09:48:01 AM »
They 460c and 648giii are both good machines. The 648 will be better on fuel if it has the direct drive transmission.
Jonsered 2260
Husky 562xp
Offline loggah
  • Just hangin' around :)
    • Johnson Hollow Sawing and Shingle Making
« Reply #4 on: November 24, 2013, 07:15:24 PM »
Dual arch with a winch only way to go. you can lower your wood down and push yourself out of bad spots with a dual arch,and i welded a tree pusher on the top of my grapple and with the dual arch you could actually push on the tree about 14 feet up using the hydraulic power, pushed over some huge trees leaning the wrong way. Don
Interests: Lombard Log Haulers,Tucker Sno-Cats, Circular Sawmills, Shingle Mills, Maple Syrup Making, Early Construction Equipment, Logging Memorabilia, and Antique Firearms
Offline Kemper
  • Go Big Blue!
« Reply #5 on: November 24, 2013, 09:45:56 PM »
We do the same with our single arch, but not 14 feet high. We also use the top of the cutter, you can really get up there then.
Offline thompsontimber
« Reply #6 on: November 25, 2013, 01:14:20 AM »
Have yet to meet anyone who has made the switch from single arch to dual arch who has regretted it.  A single arch is great so long as you've had no experience with a dual arch.  Once you get accustomed to a dual arch, you will always want a dual arch.
Like logga said, you can really push yourself out of some holes with the dual arch.  Definitely an asset and full of tricks.  As for choosing between the 460 or 648, I agree that they are both great machines.  I second the opinion of fuel efficiency with the 648 and would add that the JDs are quick on the ground as well. Depending upon where and how you are working, that may not be a big issue, but the 648 is a fast machine.
franklin 185 dual arch $25,000
Started by spencerhenry on For Sale
Last post August 19, 2009, 02:32:14 PM
by spencerhenry
-Running a dual arch grapple -
Started by BargeMonkey on Forestry and Logging
Last post April 24, 2014, 07:39:38 AM
by nk14zp
450C dual arch grapple,
Last post February 27, 2014, 07:28:56 AM
by loggah
2000 Timberjack 460 dual arch skidder
Started by ilog4u2 on Forestry and Logging
Last post June 28, 2012, 08:53:22 PM
by snowstorm
