Author Topic: block heater for a Cat D-318  (Read 1710 times)
Offline hardtailjohn
Re: block heater for a Cat D-318
« Reply #20 on: December 10, 2013, 02:58:03 PM »
I hauled logs for a guy that had hookups on the work pickups, that he'd pull up to the equipment when he got to work, hookup the hoses and it would circulate the warm water from the pickup engine to the equipment engine. Sure seemed to work slick and he could get stuff started easily at -40!
I'm so far behind, I think I'm ahead!
Offline m wood
  • How did I get to be a senior member :)
« Reply #21 on: December 10, 2013, 03:44:55 PM »
hardtailjohn, I'm gonna keep that one in mind.  I have often wondered how to circulate the heat from my work/plow truck to the cat dozer.  Time to do a bit of research on this idea, cuz shes a hard starter below about 30.
I am Mark
80 acre woodlot lots of hard and soft
modified nissan 4x4/welding rig
4x4 dodge plow truck
cat 931b track loader
Norwood mark IV
4' peavy
6' peavy
stihl 034
"her" wildthing limber saw
ALL the rustic furniture  woodworking stuff
check out FB
Offline Gary_C
  • Sunrise on the Prairie
« Reply #22 on: December 10, 2013, 04:10:46 PM »
That's been talked about many times before and it's not a good idea as far as the engine in your pickup. The thermal shock when the cold coolant hits the warm pickup engine will crack blocks, heads, etc. If you have a newer pickup under warranty, if the dealer sees those hot swap hoses on your pickup, he will void your waranty immediately.
Don't know if you can get by with it if you have an older cast iron engine, but the newer alloy heads will not take the thermal stress. Best to find another way to preheat your engine.
« Reply #23 on: December 10, 2013, 10:34:26 PM »
Gary-C I never heard of him having much problems, but that sure makes sense to me. I assumed that there was some sort of restrictor in there to keep it from all hitting at once?  Probably on the new computer controlled stuff, it'd shut down the whole mess!
Good point!
Offline m wood
« Reply #24 on: December 11, 2013, 05:35:39 AM »
interesting, thats probably enuf research for me :D
I am Mark
Norwood mark IV
4' peavy
6' peavy
stihl 034
check out FB
Offline ddcuning
  • Frick 00, 190HP, Cummins HRF-6, Newman 8B Planer
« Reply #25 on: December 14, 2013, 05:22:16 AM »
The side recirculating heaters are made by Kim out of Spokane Wa. Look up KIM Hotstart on Ebay. I have a Kim on both my mill and generator. I just bought a new one for the generator for a hundred bucks. Found someone on Ebay selling kids clothes, shoes, etc. with a New Kim Hotstart in the middle of all that stuff. I figured they didn't know what they had so I offered $60 less than their buy it now price and they took It.
Dave C
We're debt free!!! - Dave C, Nov 2015
Offline bandmiller2
« Reply #26 on: December 14, 2013, 07:00:32 AM »
Dave,is that Kim the one that uses propane or kero and a flame,seems that would be perfect for a no electric power mill. Frank C.
Offline ddcuning
« Reply #27 on: December 14, 2013, 08:20:26 AM »
The one I got was electric, I am not sure about alternate heat sources but you could check their web site. Price goes way up when you stray from 120/240v and get above 2000watts. At least that is what I found when looking for mine. The Cummins on the mill came with a 240v version and my gen set had a 120v model. Both had integrated stat.
Dave C
Offline Mt406
« Reply #28 on: December 15, 2013, 09:10:53 AM »
Hi Mt Horse
I grew up there. I may have some names for you. send me a privet message  with your number. I also live south of you 125 miles.
I should be passing though that way in a couple of weeks. would like to see your set up.
Scott
Block heater or not?
Started by Firewoodjoe on Forestry and Logging
Last post February 03, 2019, 07:56:26 PM
by mike_belben
Detroit 3-53 block heater.
Started by Dave Shepard on Forestry and Logging
Last post February 24, 2014, 10:33:19 PM
by Dave Shepard
Block heater for 353 Detriot
Started by Barkman on Forestry and Logging
Last post February 04, 2005, 09:00:36 PM
by devo
For all the block heater users
Started by yukon cornelius on General Board
Last post December 27, 2015, 11:21:26 AM
by Reddog
