AVAILABLE
Author Topic: Amazing 1500 bf per blade on Goodwill trip  (Read 1982 times)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Amazing 1500 bf per blade on Goodwill trip
« Reply #20 on: December 14, 2013, 05:22:21 PM »
I have completed 12 years of sawing and I am on my second drive belt and second brake pad.  I am sure that WM lets it run during shootouts, etc. but their operator's manual says to disengage and that is the way I learned to saw.
I also might contact the cant/log end or a high knot when returning.  If the blade was running, that would be a blade.
Our individual sawing routine is what each of us is comfortable with.  That is good enough for me.   :)
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #21 on: December 14, 2013, 05:25:58 PM »
Well said Magic.does this mean I can continue doing it MY WAY?  Its always a SHOOT OUT around my mill. :D :D :D
Offline drobertson
« Reply #22 on: December 14, 2013, 05:30:40 PM »
I'm not sure on others practices, but, I have never had an issue with stopping and starting. the brake is still good, and the drive belt as well.  As we know the saw bands, belts and brakes are parts designed for wear, and should be expected.  I will say, I have ran the .042 blades longer than the .045's per change.  This is on my mill and the way I run it.  There are so many factors that come into play that one can only experiment with different blades to find the one that fits the need.  All said, the job done in Texas by MM was a good example of perfect rhythm, clean logs, and timing of all the above which includes good alignment.  More could be said, but I'll leave it at this.   I always hear a lil squeal when engaging,    david
Offline SawyerBrown
  • If you're gonna be stupid, ya gotta be tough!
    • Saw It There
« Reply #23 on: December 14, 2013, 05:45:25 PM »
MM, I'm still trying to learn (and not yet set in my ways   ;D)), and your data is pretty compelling.  I think I'll give it a shot and see if it doesn't slow me down too much.
But I won't hold it against you other fellers to keep doing it like you are!!
Offline Holmes
  • 1840 house
« Reply #24 on: December 14, 2013, 06:16:30 PM »
  Aren't you allowed one brain fart in 4 long days of sawing?
Hopefully yes, because they were long days.  We were sawing at 7:30, a half hour for lunch, and quitting time at 5:30.  That makes it very easy to make a mistake.
 That is a very long day of working.   My preference would be to start late and quit early. 8)
Think like a farmer.
« Reply #25 on: December 14, 2013, 06:36:15 PM »
You need an Off Bearer Holmes?  :)
Offline Delawhere Jack
  • I ought to know better.....
« Reply #26 on: December 14, 2013, 06:36:48 PM »
Even with mostly milling 2x material, 1,500 bf/blade is pretty impressive.
I'm thinking there was a little Divine Intervention going on there.  smiley_angel02_wings
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #27 on: December 14, 2013, 07:17:34 PM »
As another data point as to whether to disengage the saw after each cut, I went back and looked at WM's sales / demo videos (and even the Shootout video).  Very hard to tell on the LT40 video, but on the LT35 video I'm sure I see sawdust flying on the return pass at one point (saw is barely above the cant).
My biggest concern is wear and tear on drive belt and/or brake.  For those that do disengage, has that been a problem?  For those that don't, are you breaking blades due to fatigue?  Might be an argument either way as far as fuel savings, first impression is to idle her down, but re-accelerating those two pulleys burns some fuel too.
I thought it said in my owner/operator manual to disengage upon exiting the far end of the cant or log!
I looked through the setup and operation section and step 4 says to disengage the blade when you exit the log.
Step 5 says "Always disengage the blade before returning the carriage for the next cut"!
I haven't noticed any ill effects by continually starting and stopping through the course of sawing for the day!
Since I've had my mill, I've only replaced the drive belt twice and I've sawn over 350,000 board feet.
~Chuck~
I LOVE MY SAWMILL
« Reply #28 on: December 14, 2013, 07:31:26 PM »
I think a drive band that is slipping under load will wear out much faster than it will from engaging-disengaging the clutch.
David, not sure about that "squeal" thing. I think that's telling you that the belt is about worn out.
Online Jeff
  • Fearless Leader
  • Proverbs 13:20
    • THEE Forestry Forum
« Reply #29 on: December 14, 2013, 07:33:39 PM »
On my LT30, I disengage only when I have to, as on that older mill, it'll flat wear a guy out tipping that motor back and forth.
My mill has always squealed on engagement. Mr. Tom told me it was normal.
« Reply #30 on: December 14, 2013, 07:41:01 PM »
Nah..a little sqauk is just right. If you get the belt to tightthat sucker will squeal like a stuck hog and not long after that you will lose a shaft.  smiley_crying
Offline Chuck White
« Reply #31 on: December 14, 2013, 07:47:49 PM »
The belts on the mills have specific belt tensions that they are to be adjusted to, and if the drive belt/s adjusted properly you should get a definate chirp when engaging the blade!
Engaging and disengaging the blade all day will definately take it's toll on ones shoulder.
I've found that when I engage the blade on my mill, that I will straighten my arm, then just lean back a little, it's easier on the shoulder!
This is exactly why the autoclutch was invented.
~Chuck~
I LOVE MY SAWMILL
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #32 on: December 14, 2013, 07:52:08 PM »
In the beginning, I was told that starting and stopping the band caused a lot of stress to the whole works, including the band, so I would keep it running for multiple cuts. Then I was told to stop the band as soon as I exited the cut to save on flex life. This was all from WM. Now, if I can make a few cuts in thinner boards, I leave it running. I have AutoClutch, so it's not a shoulder issue, although I can certainly see where that would really be a concern without AutoClutch.
Yup, a chirp is correct. I was told, again by WM, that it was better to chirp the belt than to slip it.
Offline thecfarm
« Reply #33 on: December 14, 2013, 09:13:22 PM »
I have a centrifugal clutch on my mill. My shoulder could not take the off and on part. That is my big issue.
« Reply #34 on: December 14, 2013, 09:17:46 PM »
This is my point y'all..if a shoulder can't take it.it's just a matter of time before machine parts start breaking down. This is why I keep mine running.
Offline ladylake
« Reply #35 on: December 15, 2013, 05:49:26 AM »
 Mine runs a lot also but I idle the engine down when needed. I'm with Poston with this one, I think it's hard on everything clutching it in and out.  Even just speeding up the 27hp Kohler sounded tough on it , a little faster idle helps.  My little diesel doesn't mind speedind up-down.   Steve
Offline stavebuyer
« Reply #36 on: December 15, 2013, 06:14:27 AM »
The WM manual for the LT70 section 4.11 "Optimal Cutting Procedure" states "In order to achieve maximum production rates, it may be desirable to leave the blade engaged when returning the carriage"
We gained at least 10% in production when we started leaving the blade engaged. We are getting more bd/ft sawn per blade than we were when stopping the blade exiting the cut. The only negative change we have noticed is that we burn an additional gallon or more in diesel than we did before but with the added production our fuel per bd/ft sawn has remained about the same.
We do have the out-feed conveyor and DCS operator controls in a saw cab so nobody is ever close to the running blade. Occasionally we ruin a blade knocking it off with a splinter or something on the drag-back that wouldn't have been damaged if the blade were stopped.
I made the change after watching a video of the mill running. If you haven't seen a video of yourself sawing its a real eye-opener. Take one and put a stopwatch on the time your loosing engaging and disengaging the blade, positioning the head or punching buttons on the set-works. We gained quite a bit of production by doing whatever we could to prepare for the next cut while the saw-head is moving. This included advancing the next log on the deck, changing modes or sets on the set-works, and leaving the blade running. We try to keep the head in motion as much as we possibly can.
Offline ladylake
« Reply #37 on: December 15, 2013, 06:43:17 AM »
 On shorter logs there sure isn't time to disengage the blade or slow down the engine.   Steve
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #38 on: December 15, 2013, 06:55:52 AM »
I do the same thing, to keep the blade going on 8' 10' logs . I call it the Wood Mizer rock. Back and forth never stopping . When I come out of the log I'm going up till I think I'll miss the cant then back I go hit the down lever before I clear the cant, go forward and hit the cant with the blade just in the nick of time to when the blade is set, sometimes I go in the cant and the blade has to go down an 1/8 to set. :D :D :D but I don't do that too much ;D
And that is a lot of BF for a blade. Good job in prepping the logs
Offline barbender
« Reply #39 on: December 15, 2013, 10:49:46 PM »
MM can call that the "Loaves and fishes blade" ;) The manual for my LT40 super says to leave the blade engaged if so desired. I often do, especially once I get to a cant and start slinging boards. I have also ruined more than a few blades when my dragback misses a slab and I hit it with the blade- ka-pow!
Finishing latest project before Goodwill trip
Started by Andy White on General Woodworking
Last post December 20, 2013, 08:26:15 AM
by justallan1
05 ram 1500
Started by coxy on General Board
Last post August 08, 2015, 08:11:54 PM
by coxy
Hard to mill this for 1500
Started by Brandon1986 on Sawmills and Milling
Last post December 30, 2015, 08:07:33 PM
by WLC
Standard Sawmill for Sale $1500
Started by FeltzE on For Sale
Last post January 31, 2017, 07:10:14 PM
by FeltzE
