Author Topic: Thinking of buying a Peterson ATS  (Read 444 times)
Offline yarnammurt
  • He who dies with the most wins
« on: December 15, 2013, 10:39:49 AM »
I have found a Peterson ATS with 27hp engine and the 21" blade. It comes with 27' rails, slabber bar, extra blade. It has 150hr on the mill. They seam to be good mills. any thoughts.
ATS 10" Peterson, 09 New Holland 4x4 TL90 with loader, 125hp White,2 2009 Kawasaki 610 mules,
Offline firefighter
Re: Thinking of buying a Peterson ATS
« Reply #1 on: December 15, 2013, 11:07:11 AM »
I have a WPF model very good saw mill .
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #2 on: December 15, 2013, 11:58:33 AM »
I own a Lucas Swingmill.
The Petersons are dandy units also, Just be certain you understand its capabilities and strength's
It's not like a band mill.
Good luck
DGDrls
Offline Ianab
« Reply #3 on: December 15, 2013, 05:24:03 PM »
The mills are great, but like DGDrls says, they do work differently to other mill designs. Sometimes this is a plus, sometimes a limitation. But with a slabber option, there isn't much that you wont be able to do.
What's "best" often depends on someone's particular circumstances. Have you seen one of these run in person? They are pretty easy to operate, but there are a lot tricks that you can pick up over time that make life easier.
Offline yarnammurt
« Reply #4 on: December 15, 2013, 05:40:09 PM »
I have not seen one in person. I have watched a lot of video. I think it will work great for me.
question
Thinking about a Peterson....
Started by Engineer on Sawmills and Milling
Last post January 27, 2007, 06:56:20 PM
by logman
Im thinking of buying?
Started by nathan87 on Forestry and Logging
Last post July 25, 2011, 04:07:47 PM
by nathan87
Buying a Peterson and need help!!!
Started by hatchoil on Peterson Portable Sawmills
Last post May 04, 2016, 03:43:11 AM
by hatchoil
Thinking about buying a sawmill, would like some help.
Started by levisthered on Sawmills and Milling
Last post November 24, 2014, 03:44:53 PM
by gimpy
