Author Topic: WM hydro trailer question  (Read 608 times)
Offline JustinW_NZ
  • Just Hacking and stacking.
    • Logs2Lumber
« on: December 18, 2013, 01:54:26 AM »
Hi all
I have a '97 LT40 that has a Triton? front hitch and has hydraulic brakes hooked up from that.
I don't think it had been hooked up for many years and I put brake fluid in it and it seemed to make it not as jumpy behind the car.
it has a lever on the top that has a wire and little hook which I would think is a tearaway brake for if the mill unhitches, it seems to be stuck in a not quite 90deg angle currently.
It appears like it used to sit flat, at I guess I'm thinking it needs to sit down to make the brake work?
It seems locked upwards currently and I cant make it budge.
If anyones got some clues on how this works that would be great, so at least then if I have to pull it apart I know how it *should* operate :)
Thank you in advance :)
Cheers
Justin
Gear I run;
Woodmizer LT40 Super, Treefarmer C4D, CAT 528 swinging grapple, 10ton wheel loader.
Offline schmism
Re: WM hydro trailer question
« Reply #1 on: December 18, 2013, 02:27:01 AM »
that bar has to do with the tearaway feature.
try this kit  http://www.etrailer.com/Accessories-and-Parts/Titan/T4045400.html
or if you want to deal with that,  it should be a bolt on tongue hitch,  you could replace the whole ball of wax
http://www.etrailer.com/product.aspx?pc=T4332900&pg=Trailer-Coupler&manuf=Titan#prod-acc-onlyquestions
039 Stihl 010AV  NH TC33D FEL, with toys
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #2 on: December 18, 2013, 06:01:27 AM »
Offline JustinW_NZ
    • Logs2Lumber
« Reply #3 on: December 18, 2013, 02:02:27 PM »
Yes thats the one thanks!
Cheers
Justin
Gear I run;
Hydro Axe 221 Question
Started by Wes Lyon on Forestry and Logging
Last post October 13, 2012, 10:44:27 AM
by treefarmer87
Hydro Ax shear question about mulching attachment
Started by H.Watts on Forestry and Logging
Last post August 09, 2014, 01:22:51 AM
by MesquiteSawyer
question
Secondary loop on closed loop hydro heating question
Started by DR_Buck on Firewood and Wood Heating
Last post October 22, 2010, 06:16:01 PM
by Holmes
Trailer Question
Started by Arbor-Mill on Urban and Community Forestry
Last post March 01, 2014, 06:55:41 AM
by David-L
