Author Topic: wood filling  (Read 645 times)
Offline rdhdfmn
wood filling
« on: May 29, 2004, 10:21:42 AM »
I recently routed a fish symbol into a 25x48 cedar top. the depth is about 1/4 inch deep. I want to fill that in with a filler so when I finish the top it looks smooth on the top. thanks   RD
Offline shopteacher
  • Hiking Sedona, AZ.
Re: wood filling
« Reply #1 on: May 29, 2004, 11:36:00 AM »
What are you planning to use for filler?
Offline rdhdfmn
Re: wood filling
« Reply #2 on: May 29, 2004, 03:37:29 PM »
I really dont know. I thought about some type of epoxy or maybe something that is made for wood. I also thought about maybe busting up tile and grouting it, But then I worry about the water in the grout leeching into the cedar. I really dont know. thanks
Offline burlman
Re: wood filling
« Reply #3 on: May 29, 2004, 04:19:47 PM »
you could inlay it with an exotic wood or atleast one that would contrast the cedar color. maybe some maple. leave it a little high then sand her flush when the glue dries. I use epoxies as filler when i'm working with spalted wood. JB weld works well and after you sand and finish it it has a blueish gray color to it. Depending on the epoxy after it dries the color it will turn when you apply the finish. tests are required before you decide . Again I try to leave it slightly higher than the piece to be filled, there is some shrinking when it dries so leave enough extra. I use a belt sander with a 120 grit to grind it  flush  with the surface. good luck...burlman...
Offline Ianab
Re: wood filling
« Reply #4 on: May 29, 2004, 05:09:55 PM »
One thing you could try is clear resin and pieces of paua shell, it should work in a fish pattern, very underwater and the colours are neat
Filling cracks and knot holes in wood floor
Started by thechknhwk on General Woodworking
Last post June 05, 2016, 03:15:38 PM
by thechknhwk
filling your OWB
Started by sparky1 on Firewood and Wood Heating
Last post February 13, 2012, 10:45:14 PM
by sawdustandmud
log yard filling up.
Started by weisyboy on Sawmills and Milling
Last post April 04, 2011, 07:13:14 AM
by sigidi
Filling in around a red maple
Started by kelLOGg on Ask The Forester
Last post May 26, 2016, 07:28:58 PM
by sprucebunny
