Author Topic: Another home built log arch  (Read 1853 times)
Offline OH Boy
  • Maybe I'm too old to start doing this!
« on: December 28, 2013, 09:05:42 PM »
I had an old trailer in the back that still had air in the tires, so cut it up, welded it back together along with a tow hitch receiver, which maybe I can use with a bar to help hold up the log end, and a come along. gave it the first test today and works great, at least didn't break. still need to have better cables to hold with but looks like it will work.
Offline thecfarm
Re: Another home built log arch
« Reply #1 on: December 28, 2013, 09:12:44 PM »
It passed the test,it did not break.  ;D
Offline KyLogger
  • Loggin' for a livin'
« Reply #2 on: December 28, 2013, 09:36:40 PM »
Is that log totally suspended?
I only work old iron because I secretly have a love affair with my service truck!
Offline mad murdock
« Reply #3 on: December 28, 2013, 09:38:01 PM »
Nice job on the arch!!
Offline OH Boy
« Reply #4 on: December 28, 2013, 09:43:20 PM »
Yes, it is suspended, which is nice because the easiest path to the top of my hill is on the neighbor, so it won't tear up his path dragging logs. I'm thinking a 10 footer may be all I can do, but if I can find a 2 in stock bar to stick out the hitch receiver, maybe that will extend my reach by holding up the end. definitely still a work in progress.
Offline KyLogger
« Reply #5 on: December 28, 2013, 10:05:19 PM »
Looks like a job well done! You may have to reinforce the 2" tubing maybe a piece of angle welded on top and bottom?
Offline Bandmill Bandit
« Reply #6 on: December 28, 2013, 10:15:58 PM »
looks real good. Might want to consider a couple of short gusset braces on the inside corner above the axles. It looks like a good design.  I may have to build one my self. get about a dozen calls or so a year to pick up a single yard tree in town. That rig would do a good job of handling those jobs.
If you ain't livin on the edge you are takin up way to much room. Of course at my age if I get too close to that edge any more theres a good chance I may fall off.
2001 Dodge 1500 4x4. 2018 F150
2007 Woodmizer LT40HDG28 almost Super
2 Logrite 36 inch cant hooks and a bunch of stuff I built myself
Offline 36 coupe
« Reply #7 on: January 05, 2014, 08:09:09 AM »
I splayed the legs out on my log hauler.No need for bracing and makes the rig better when it comes to rolling sideways.One hauler featured on here was too tall.Use wood patterns to get the angle cuts right.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #8 on: January 06, 2014, 10:03:05 PM »
Looks good.  It will be a very useful tool.
Offline Sixacresand
  • John and Nancy
« Reply #9 on: January 07, 2014, 06:56:41 AM »
Good Job.   I know you will get a lot of use out of it.
Offline Sixacresand
  • John and Nancy
« Reply #10 on: January 11, 2014, 09:00:59 PM »
I broke my home made arch the other day.  I was moving  28 inch x 12' pine log and the center beam on the hitch/tongue end broke.  All the weight of the log is balanced over the wheels, so it was stress from pulling the load.  The break point was not a weld.  I wonder if the original stock steel tubing had a crack in it.   I use my arch to move logs and as well as stacks of lumber. It is my main support equipment and milling is down until I "fix" it.  LOL
Anyone built a logging arch
Started by WV_hillbilly on General Board
Last post October 11, 2002, 11:29:22 AM
by WV_hillbilly
My log Arch, log ramps, and log winch I built
Started by mainiac1 on Sawmills and Milling
Last post June 23, 2019, 05:06:10 PM
by mainiac1
Built a arch trailer for oak logs
Started by LoneDuck on Sawmills and Milling
Last post June 25, 2019, 09:34:29 PM
by John Bartley
sawmill home built
Started by thedeeredude on Sawmills and Milling
Last post February 23, 2006, 11:38:04 PM
by jpgreen
