Arborwear
Author Topic: When I want to smell spring  (Read 665 times)
Online Peter Drouin
    • A&P Saw mill LLC
« on: December 30, 2013, 06:48:16 PM »
I go in the greenhouse.
Cold frames.
some green and 50  :D :D
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: When I want to smell spring
« Reply #1 on: December 30, 2013, 06:52:30 PM »
Not bad Peter..if you can just stay in the Greenhouse.  :D
Where's the Spoon?
Offline thecfarm
« Reply #2 on: December 30, 2013, 06:55:10 PM »
I miss ours. We use to start about Feb. Use to be great to walk in there when the sun was out. But try that when it's dark out.   :o  Even with 2 layers of plastic it did good with the sun.But when the sun went down,the oil would kick in. Would see a 250 gallon tank drop down a of a tank on them cold nights.
I used all hemlock to build ours.
Online Peter Drouin
    • A&P Saw mill LLC
« Reply #3 on: December 30, 2013, 07:03:50 PM »
We will get the seeds ready the  2# week in Feb. Nothing freezes in there Ray
Some days I like to. But for now I fix things in there and it is nice ;D
Sawing since 1987
Offline thecfarm
« Reply #4 on: December 30, 2013, 07:14:44 PM »
Must have glass if it don't freeze in there? Those raised beds help out too. I just had 2 layers of plastic. At night,with no heat,what ever the temp was outside,it was the same temp inside.
Offline JohnM
  • Sometimes its best to punt and play field position
« Reply #5 on: December 30, 2013, 08:19:03 PM »
Peter, that's great!  Been daydreaming about a greenhouse for a while, now that I've got a mill no more excuses, right! ;) ;D  What are the raised beds made out of, pine, hemlock, cedar, other?  And how are they filled?  It's not all soil is it?  Are they lined?  Sorry for all the questions. :)
Lucas 830 w/ slabber; Kubota L3710; Wallenstein logging winch; Split-fire splitter; Stihl 036; Jonsered 2150
Online Peter Drouin
    • A&P Saw mill LLC
« Reply #6 on: December 30, 2013, 08:56:40 PM »
John M. not lined made of pine and hemlock 4x6x16s and 4'.. pre drill and use 1/2 rebar. I filed 1/2 way with gravel then loam. made the first one fill it with the  John Deere and worked my way out then made the G house.
Sawing since 1987
Online Peter Drouin
    • A&P Saw mill LLC
« Reply #7 on: December 30, 2013, 08:58:46 PM »
I did put old bed rail from side to side to hold the sides in too
Sawing since 1987
Offline JoeB
« Reply #8 on: December 30, 2013, 11:52:47 PM »
thecfarm, the secret is to run a very small blower inside the two layers of plastic, as an air cushion. You'll save heat that way, also look into a bigger tank for your oil. Cheaper rate. HTH, JoeB
Online Peter Drouin
    • A&P Saw mill LLC
« Reply #9 on: December 31, 2013, 07:18:02 AM »
And run pipe through the raze bed with heat. A lot of guys heat the air . Should heat the bed. Hot air will rise.then put a line in for water, one that weeps.
I would run the green House year round but how much can Ann and I eat. :D :D :D well If we had kids, were to old for that now  ;)
Sawing since 1987
Offline thecfarm
« Reply #10 on: December 31, 2013, 08:17:17 AM »
We went around to many small green houses and got ideas. I knew about the blower between the plastic. I just never did it. Bottom heat on the plants make a big diffenace too. All gone now. I put the OWB where the greenhouse was. I should of got the OWB first. Than the greenhouse.
The Smell of Spring and Summer
Started by Gary_C on The Outdoor Board
Last post April 10, 2010, 09:02:16 AM
by Raider Bill
That smell?
Started by blackfoot griz on General Board
Last post July 13, 2012, 12:56:12 AM
by Left Coast Chris
What is that smell?
Started by Brad_bb on Bluecreeper
Last post September 05, 2010, 11:13:07 AM
by customdave
What do you smell?
Started by Kirk_Allen on General Board
Last post September 29, 2004, 04:45:38 PM
by karl
